Hot & Cold Fill UK Washing Machines
sebo_fan
Scotland, UK, member AKA ukvacfan, & Nar2
Here's a thought I'm puzzled about currently.
At the moment I'm running a test based on a cold fill washing machine compared to my old faithful LG washer that has a cold & a hot fill system. The hot tube runs off the mains water supply that my gas boiler has, when it is used and the washer is used maybe once a week if Im lucky. The LG uses 2100 watts in total and has a 6.5kg load. It offers a variety of programs including 1600 rpm top spin speed and a quick wash of which I usually use the most of.
The new machine uses 2225 watts in total and has a bigger 9kg load. It too offers a variety of programs including a quick wash. However it also offers 1600 rpm top spin speeds as well as others and though it should be more eco-efficient based on the cold water fill alone, the 1800 watt water heater inside the machine requires the water to be heated up. Thus, doesn't this fact make this machine less eco efficient than the older machine even though it is cold fill only?
The stats online for this machine tell me one thing that it is eco efficient with its A+++ rating but then my old LG was also rated A for performance, thus an older system granted its 8 year old age. But still, the water that the LG uses is no where as big for the larger 9kg load that this newer machine offers.
Hi Ryan,
Interesting point. I know, generally speaking, gas is more costly to run than electric. Lets also not forget that your boiler is electricity powered, even if it's just to control the timer and inner workings (I'm no boiler expert, but when I have a power cut, the boiler goes off. Therefore it is electric lol!).
Hot & Cold fill machines still have to heat the water, just not as much as a cold fill only. With the cold fill only washer, it may use more electricity to heat the water, but it's not using any gas and not using electricity to power the boiler. The A+++ rating will also be based on water consumption as well as power consumption. So if it uses less water, no gas and is using less electricity just to heat the water instead of heat the water AND power the boiler, then in theory, that would make it greener?
Out of interest, which LG do you have?
Chris
That thought was precisely what I thought regarding the cold fill only versus the hot & cold fill. The only aspect that seems to be more greener, or perhaps more efficient is if the hot water has been channelled from another source, such as solar panels.
I have an LG WM16220FD *(link to old review). It has never required any repair and its just a fab machine that does what is asked of it. Now with a more modern A+++ washer with a much bigger 9kg load capacity, it uses a drive belt compared to the direct drive of the LG and though generally quiet, the new washer is a bit noisier than expected. Last night I thought the "vacuum truck" was passing by my house only to realise it was the new machine doing a spin lol
http://www.dooyoo.co.uk/washing-machine/lg-wm16220fd/1054497/
Oh, so you've actually bought a new machine? Is there any particular reason you got a new one?
I *think* my godparents have that older LG, but don't quote me on that. It's definitely similar and about the same age. That is a fantastic machine from what I remember.
Are you telling us that in the UK, you are just now getting washing machines that hook up to both the hot and cold water faucets? Our washers in the USA have always done that, and none that I know of have had a heater inside. My Maytag Bravos is an excellent washer that is very energy efficient, holds 25 pounds of clothes in one load, and while a top loading machine, has no agitator. I've had it for almost six years and no problems.
^No. Historically, UK and European washers were all hot & cold feed, but it is far more energy efficient to have them on cold fill only. Since about 2000-2002 ish, all UK washers have been cold fill only.
NOTE: NOT GETTING INTO YET ANOTHER DEBATE ABOUT TOPLOADERS VS. FRONT LOADERS.
As Chris says quite rightly, up until 2000 or so, brands started to offer cold fill only. My family in India have an excellent LG top loader though. Very quiet, quite space efficient but by god it takes a lot of water. Took me back to the days of when my parents had their ever faithful Hoover Twin-tub - those were very popular in the UK.
Mind you, it does the job it is intended to do and I was very impressed with it. My uncle tried to explain to me how to work it until I said I have an LG already - the controls are very similar, so that was good to find.
Luckily in Scotland, in most areas we don't have a separate water bill. Parts of England do though as well as the famous "hosepipe" ban when water is low. We never have that issue in Scotland as it rains all the time!!
hot and cold fill washers
my old washer was a hoover H&C fill but by the time the hot water came all the way down from the hot water cylinder upstairs the machine was full usually with cold to tepid water so the heater came on anyway just my tuppence worth guys
Cold only / Hot & Cold fill
I'm not sure, but I think that some of the 'efficiency' attributed to cold-fill-only washers, is that they may use slightly shorter cycles, due to the 'soak time' available while the water heats, plus the compilers of the data will probably assume all-electric heating- hence the economy of only heating the precise amount of water required for the load.
But.... On the subject of efficiency/eco-friendliness... Why does no manufacturer INSULATE the drum?????
All best
Dave T
Well you say that ......
Firstly I should point out for Americans and Canadians there is a fundamental difference between how your machines (front loading) work and European machines work.
I cannot think of a European designed machine that does not have a built in heater. Traditionally on hot and cold fill machines the machine will generally only take in hot water on washes of 60C & more, which reduces the time taken to complete the wash rather than wait for the water to heat from cold. All other programmes and rinses use cold water - at least in my experience.
The only machines that I can think of which were not supplied with a heater (post WW2) were a few wringer washers and twin tubs.
Cold fill only machines are by no means a new thing although it seems to me that the largest trend to cold fill only was from German manufactured machines - not entirely, I can think of certain Indesit models that were cold fill, and one of my Hoover Keymatics (wide body not slanted - 1967) is cold fill only too, although the model was modified later for H & C fill. This was a surprise as the predecessor models were H&C fill - why they did this, who knows?
@sebo_fan - I know it is a common conception that current machines take a lot longer, but I am not sure I agree. My daily driver is a 2004 Miele machine which takes 1hr 46min for a cotton wash and 1hr 16m for a Minimum Iron (Permanent Press) wash. I have been surprised that my old autos (Keymatic 1967, Keymatic 1979, Philips 1981) take pretty much the same time to complete to complete equivalent cycles. These all run on cold fill only, as does the Miele.
I will add that I usually start the Miele and walk to do something else (and actually I usually run it at night) whereas with the vintage machines I tend to keep an eye on them (partly to make sure they are not leaking!) which makes it seem like they take even longer. Its not just watched kettles that never boil ...
Al
I cant say very much for the moment but my 8 year old h&c fill LG takes 2 hours 40 to do a full 60 degree cotton wash compared to the new cold fill only machine that offers the same program and takes 3 hours 15! Mind you, the LG has a 7.5kg capacity compared to the 9kg capacity, but that shouldn't mean the same when there are sufficient clothes not to overload the system.
Sebo Fan
The 60 deg cotton cycle is the one used to determine the machines energy efficiency rating and is usually the one that uses the least water. A lot of these large capacity washers have very long wash times to enable them to clean well using less water than automatics used in the past. Can I ask what washing machine did you get? Does it have a function to reduce the wash time? I always have the short option selected on my washer, I get great results and most loads are done anywhere from 50 to 90 mins, mind you, my machine is rated at 6kg.
I cant say what the machine is at the moment as it still going through the product test from the company. Put it this way, the total rating is 2525 watts compared to the 2100 watts on my hot and cold fill LG. In essence the bigger drum means it should be more economical to use since it uses less water but unless I use just the eco cold only temp washes or the quick wash functions, there's very little between them and I'd be more inclined to stick with the fab performance and reliability that LG have given me already.
I've never heard of a cold fill only washer, but they do sound like they would be a lot more efficient and I do like the idea of the washer not having to wait for the hot water to get all the way through the pipes from the water heater (even though the washer at my dad's house is in a closet that is next to the closet with the water heater, and my mom's laundry room is right above the water heater which is in the basement, but every house is different). My mom's house has a Whirlpool Duet Steam from 2006 or 2007 (house was built with a Panasonic which was replaced very soon after with the Whirlpool, I was too young at the time to remember why it was replaced now) which must have a heater in it, but the settings that use steam are very rarely used (I wash my sheets using the sanitize setting, to kill any dust mites. I don't think the sanitize setting uses steam, only the deep clean setting does but I'm sure the sanitize setting uses the built-in heater) and it is hot and cold fill. The Duet Steam dryer has a small tube coming from the cold water line that goes to the washer to the dryer for the steam settings (quick refresh and enhanced touch up) so I am wondering if the washer heats water from the cold or the hot line for the deep clean and sanitize settings.
Houses in the UK can have different systems where hot and cold fill are concerned - some houses have the older tube running off from the hot water system in the home, others have a water "tap" /faucet running from the heating system installed next to the machine where effectively the washing machine will only suck in the water when it is required, leaving the water dormant until the machine is required next. Feeder tubes are then connected either side of the water tap if, say a dishwasher requires cold fill only.
I didnt know all this until my LG was taken out to plumb the Hotpoint in and we discovered that the tap had seized up, thus requiring replacement.
I still prefer the LG - though it doesn't offer as many low energy wash programs as the Hotpoint - the LG is far quieter to put up with as well as being a far better machine to live with where just me is concerned. I quite like the Hotpoint for its ease of programs and for many of them - but the fact that it uses a drive belt as opposed to the LG's direct drive means I'll be questioning how long the machine will last on our kitchen floor.
Just reading your full review now - very interesting. One thing to point, the swing-open drawer is not a new feature and is actually a left over from the old Ariston machines that the first Indesit made Hotpoints were based on.
Really? I did not know that. Sadly Im not as involved with washing machines as I am with vacuums - though Im aware of several designs from my studenty life. Washers and dishwashers are pretty much average appliances though I know what brands I like and the brands that have let me down.
