hoover convertible flickering headlight bulb problem
bnsd60m9200
Akron OH
i took apart my convertible 1076 tonite to fix the flickering headlight bulb. i sanded the bulb contacts, and the contact recepticles, but when i turned the vac on, the bulb still doesn't have a constant voltage. it still flickers between on and slightly less bright (not totally off and on flicker). what else could be wrong? the bulb looks in good shape and not burning out. i want to weed out other possibilities before replacing the bulb, they are not cheap.
Will
Sounds like a loose wire to me...
Could even be the bulb, I've had iffy bulbs flicker because of a poor connection within the glass, the only test for that is substitution, and 15-25 Watt appliance bulbs aren't that expensive, you're just going to the wrong place to buy them... :P
Is there an ebay version of "Let me google that for you"? 1 minute of looking and hey presto, 8x 15w appliance bulbs, $12 (S&H depends on your location though), keep a few as spares, sell the rest on:
http://www.ebay.com/itm/370380483104
morgan thanks a bunch! i found them at lowe's for $3.78 a piece and bought two. sure enough it was a $hit bulb. headlight works great now. thanks for the store suggestion!
will
john i did get them at lowe's. i bought 2 15W ones. soon as i replaced the bulb, the flickering stopped.
Will
Vintage Kirby and Hoover guru
