Hey guys, a couple days ago I ended up replacing the dead Italian Motor that was in My Gaia 8000 steam Vacuum surprisingly it went smoothly although I did have to cut off one of the mounting Triangles from The Motor, the original Motor had also the same triangle cut off, probably as it uses the physical case as the third mounting leg
The replacement Motor is a Ametek Shanghai 240 V Fully metal two-stage tangential discharge Motor
On a related note has anybody had decent luck with Shanghai Ametek motors? And I’m just hoping the hundred watts isn’t the difference in between a working Vacuum and one with a burnt out speed control
