Filter Queen needs help
camelotshadow
Active member
Valley Village
so do I
LOL
Want to hook up a power cord to a vac without any
The switch is wired
but there is one set of wires out of switch not capped
I found 2 loose black electric caps in the top
so trying to figure where they go & how to hook up the cord to the unit
I have a 2 wire cord w white & black wires
trad black is negative so assume white is positive?
Now I;d like to test motor w my cord but have to attach it
thinking the red gray in pic which are together but not capped are the swtich connections
so the loose red & black must be power cord leads?
guess I could try but don't want to cross wires
...anyone know which way to proceed?
ooh maybe a hesco diagram could help
yippee
let me see
Emailed my brother who is a electrician
but the vac is on the gurny & like to get it going or not
LOL
well the grey receptacle is the power nozzle power so thats not a switch...but is on swtich or else it would be on with unit off so guessing the leads of power cord have to be before it then the switch placed in line to control it
thoughts still go to loose red n black wire
to hook up cord
not so concerned about power nozzle port now anyway
anybody?
does that sound right?
http://www.elkypro.com/hoops2005/vacuum_parts/filter_queen/d31x.html
lamda motor this is model 31
serial number has a d on collar n serial # starts X9...
its motor top view is similar when I peak thru top to my model 33 1978
the mod d31x 1986 looks different
I see 2 brush holders from above say x axis
then there are 2 red plastic extensions on the other y axis
hmmm?
this is the 86 filter queen very rusty! but i cleaned it up a bit after this pic
least it is not rusty like the 86 d 31 x
wish I took pic of external wiring
but only got under motor cover n don;'t want to take it apart to match wiring
the cordless motor
same config as ametek lamda motor though its rated at 8.9 amps
rubber gasket is broken
so far missing the handle on exhaust cap & the gasket & screen for secondary filter
& cord..LOL
learning & hope to get it working
could this be a `1975 unit?
got it
got it
opened another motor
red n gray of power nozzles goes to red out of motor & that connects w neutral white
black of wire goes to black on switch
well now to hook it up n test
thanks
well motor is together
it works
but hi lo switch is broken
it still works w trouble sliding as piece of plastic is gone
so needs a switch
needs parts to complete exhaust cap cover like the handle & gasket
needs secondary filter rubber gasket & screen
then it would be whole
not bad I guess especially since motor is the most important part
may use parts from the newer machine w the rusty motor to test it complete
& work on derusting that motor while its apart
took the 78 filter quuen apart to get wiring
so now I see I need a top filter & I;ll clean that like new while its apart
this unit has now had everything inside the motor cleaned all gaslets
$ gorilla glue fixed that break in top motor gasket almost like new
here it is with its new long 30 foot bissell 12 amp vac cord
Not bad for a novice...
LOL
only works on lo speed
hi lo switch is broken though so maybe the missing part is not making the contact
still I checked wiring on the on off switch & its correct
oooh well
now got really good suction on low & you have to pull plug to shut it off
add on off switch to list
LOL
blue wire to hi lo is bent
looks almost off on top pic in thread
its connected but half bent out
what goes wrong with step on switch?
can get that for $5 from total vac
well its operable
my hose, secondary gasket rubber n screen & exhaust cap
I'll clean the others thru n thru
now that I know how
maybe pop in the switch from the other one
I had the switch out
its simple but have to rewire it
then I;ll know if its the switch or what
It looks nice & it has great suction
even if it says its on low
it sucks the rug off the floor...
Here it is all happy to be together
4 the electrically inclined
i matched the wiring to the 78 with similar motor
it was the hot wire of power cord on outer black wire of step on switch
opened the newer model & to my surprise the hot power cord wireis attached to the other black wire on the inside side black wire of the push switch
odd as both these units push switch works
so I am wondering why the difference
