Electrolux AP-100 not running
quebecois
Waterloo, Canada
I recently bought an AP-100 at a very low price because it didn't run at all. I haven't had a chance to see it before I bought it, so I took a chance.
When I got the machine, it was opened and I could see that the wiring has been modified.
I will post pictures of the wiring later if needed.
The other thing I noticed that was wrong was the small rubber thingy under the front cover (see picture). It was totally flattened. I worked hard to reshape it round, with minimal success.
The machine didn't want to run after I put it back all together.
My first question is: could that rubber tube prevent the motor to run?
yes it wil lclose the path way to the check bag indicator and close the flow and shut hte machine off as if theres no bag posibality one
second thing your wires are messed up time to open her up plz message me on here i restored my ap 200 same thing
Hey
I might be wrong but that looks like the exterior of what once was a power cord it uses the plastic sleeve to slide through opening. I'm probably wrong but idk.
Listen to compactc9guy
Resto ap 200 pic
This is from when i open up my  Electrolux ap 200.Ap200 and 100 are same here is the wires motors some thing must be block or messed up for it not to work.Make sure the hose from dial to door is not clog it attach to bag door and bag light if its wrong  wont turn on whit out bag is the motor making noise or switch or carbon brush ???Msg me
Antoine
If the rubber tube is the culprit, would the bag light brighten up anyhow or would it cut the current to the light too?
The bag light was OFF when I tried the machine.
Hey
Notice his wires there organized. If you also notice clips on wires very smart. If you don't have yours like his I'd route wires and run like his. If and when in the future will be easy.
If you have little pieces of tape label wires. These little details make a huge difference when you or someone else works on it. It will take a few minutes instead of hours.
If the light is off means the vacuum must have a bag .If LIGHT IS ON means No bag no power electrolux ap serie shut the light off and turn on whit a bag only ru n whit a bag never runs whit no bag odd give mea pic and more info
Hey
Switches don't usually go out. It's a switch. You could connect to wires see if off position no power should go through open switch power goes through. You can test but it's operator error usually not switch.
Hey
Dude your Motor looks like it has been around the block and put away wet. The copper coils are loose, carbon brushes look like they have never been changed,corossion mildew and rust. It's every where. Tell me the old motor is pic 7 and it goes backwards otherwise Im no expert but if that motor runs it won't for long .
All pictures are of the same motor, ahah ! Picture 7 shows the more how bad it is , hey !
I even wonder if I should spend time trying to fix it, what do you think ?
Hey
Idk I'd unwire it blow the crap off. Get sandpaer and clean metal parts of motor. Just clean all rust and build up off. You can pressure wash it. The key being make sure it's completely dry. Once dry then try it.
It honestly looks like somebody replaced the motor (with a really nasty one), but chopped and spliced the wires instead of just unplugging them.
If it's a one speed motor, just find the two wires that run it and hotwire it directly to 120v, see if the motor does anything.
Hey
The coil looks done for. Idk might need new motor but cleaning it up and drying it will help alot. I am going to mention something weird. Go to parts store get best degreaser they have. Go to car wash dump degreaser all over everything and power spray. Continue this a few times and the motor would look Clean and brand new.
I mean shiz look at it. It will make motor work if it's going to work. It will clean up wires.
Wash at car wash a few times until motor is in excellent condition. Dry it completely.
Then wire it and it should work.
Don't listen to mad men he's crazy. All up in here talking like he is an electrician.
Oh and if you have any skills rip old wiring out and rewire correctly.
I have another AP-100 in the basement that runs good, I think I'll open it to compare the wirings and see what is wrong, if it's the wiring or the motor itself. I'll post pictures of both side by side.
Well , I put a good motor in the machine and a good tube with a good rubber tip and
no go, no light bag door light. So I thought the motor isn't the main problem.
Actually, it's a broken cord problem (see picture).
It doesn't mean the motor runs, but we'll know when the cord is fixed. I feel quite a bit dumb I didn't hink about the cord at first...
Les, I've completely rewired 3 houses. I've solved electrical problems that real electricians failed to. I've also rewired entire cars. So I think I'm allowed to talk like I'm an electrician. Also, yes, I am crazy.
quebecois - Don't feel bad about not noticing the broken cord. I did the same thing a couple months ago! The cord was all chewed up and I was taking apart the motor to see why it didn't work lol. Always remember when diagnosing something - anything - start with the basics.
Also, never apply power to the brush connectors! You want to apply power to the field coil wires, and even then, only if you know which ones are which. Most one speed motors will only have 2 wires going to the field coil (not counting 2 more wires that come out of the field to go to the brushes).
