Electrolux 2100 Problem (help needed!)
eurekastar
Amarillo, Texas
I have an Electrolux 2100 that turns on but immediately turns off when the hose is attached. The bag change light also comes on. With the hose off, it runs fine until I place my hand up against the intake. It then immediately shuts down, with the bag change light also coming on. I don't think the bag is the problem because it is brand new.
I don't know anything about these newer models. I've only serviced older models. But I'm guessing there is a problem with the airflow sensor.
I bought it from a lady a few years ago who rarely ever used it, because her housekeeper usually brought her own vacuum. It still looks almost brand new. I use it from time to time and have never had a problem until now.
Any thoughts would be appreciated!
You
don't have to take it all apart to check. The dial will come off from the top and expose the auto valve. When you unscrew the dial from the assembly you will find one of the two O-rings holder is broken. Buy a new valve and just put the dial back on the assembly . Let me know if that is your problem and I will make sure you can get it back together.
The
valve problem is something that I came across just in the last two years. Taught how to fix by Franchise Owner that was a Service Manager first.
Electrolux 2100
I have that same vacuum and the same problem. I suspected that dial had something to do with the problem. My 2100 will run for awhile if you lay it on its side...I gave up trying to take it apart though.. I will have to try taking the top off again.. Dan
Jimmy told me on a previous thread that it is best to take these apart face down. Then you won't have to disconnect the wires on the top. I found out the hard way when I first took one apart with the control panel on top. After the tank is disassembled, check to see if all the hoses are connected and clear. Those later Elux plastic tanks seem to have a lot of power.
Look
at the dial on top. Pull it up then you will see the control underneath. No need to take the body apart to check the problem. I will try and locate a diagram to take body apart. If you take the body apart a don't know what you are doing you could be in big trouble.
Those valves always go bad.
Great vacuum but the whole control valve set up in there is useless. Worked great in the metal tanks. Rather than replace it or I try to repair it I just remove the tube going from the control valve to the switch block. Then it can't shut off. The motor has a thermal switch so it's not needed to protect the motor in the event of a clog. And we are all smart enough to know when the bag needs changing.
It is best to remove the bottom from the rest of the vacuum and not the top cover. Once the bottom is off just move the bag chamber out and the valve switch and all the little tubes are right there.
The
valves do not always go bad. As a youngster I can understand what you think. I have been in the business 58 years and never say always. Some do go bad but not that many. As a man in the business you are just beginning . Over the years you will find new stuff to say needs changing but the manufacturer will be the determining factor as well as the customer. If I had a problem on my automatic I would want it fixed. If you don't want to fix yours fine.
I'm surprised no one has suggested the obvious first remedy. The clear air tube that goes from the automatic control dial to the intake tube in the front cover, should be removed and a thin wire (like a bread twisty tie with the plastic covering removed) should be inserted to clean out the very tiny hole. It always clogs, and the machine shuts off as soon as any kind of restriction is placed over the front intake opening.
How much do they cost? Depending on your Aerus dealer, $800+ for a brand new 2014. But the base model, the Lux Classic, does not have an adjustable control valve and probably doesn't suffer from this problem.
Furthermore, I've not come across very many of these threads mentioning control valve problems. In my personal collection are 8 models dating from 1968 to 2014. All of them have the control valve, and none of them have had any problems. Electrolux has been using control valves that are essentially the same since the beginning of time. They grew their reputation on the innovation and reliability of their products. If the original control valve design was flawed or unreliable, there would be no Aerus today, period. I wouldn't be afraid of them because of the valve.
Hmmm, my Epic 8000 apparently doesn't have this feature. There are three motor speeds selected electronically by a switch on the handle. That is it for suction control. It's plenty.
I know this is an old post, but I am having this issue with my Epic 6500. I recently purchased a new control valve online, but the vacuum would cut off as soon as the hose was connected. The original valve malfunctioned at some point and I just disconnected the bag full indicator and this fixed the problem. The new valve did not correct the issue when it was installed. I was thinking that as dysonman mentioned above that a thin wire should be used to clear out a small hole. Where is this located? Can anyone provide a picture so I know what I am looking for?
I think what is meant is to take a pipe cleaner or twisty and make sure there is no obstuction in any of the tubes. I have this problem with mine and was able to fix it. Let me know if you need anything else. Also, basic question. When you put the new dial in, you made sure the dail was turned on to the middle of the dail correct? If you have the dail set on the lowest setting it would most likely cause the same problem. Hope that makes sense.
Thanks Lux14. Yes, I tried all settings on the dial, but I will take it apart and try it again and make sure the clear vacuum tunes going to the control valve are cleaned out.
