Electric Carpet Sweepers—G-E's model SV-1, Premier's model SV-1A & Emer's "Princess"
Eureka Style "T" bags for the Easy Glide (from old eBay listing):
    440.5 KB
Unlike the GE the Eureka could have an attachment set similar to the bigger F&G upright.
Wow….a hose and attachments? I can’t imagine that the fan in the Easy Glide produced much airflow. Would be interesting to find out how powerful the motor was - ie amperage. Even the full size Eureka Super Automatic 260 from the 1960’s only had a 3 amp motor which really did not produce a lot of airflow through the optional attachment hose.
And here’s a good example of a bagless powered carpet sweeper that has no suction fan. It’s a rechargeable sweeper from Black & Decker:
Yeah all that is is Black & Decker buying up the expired Swivel Sweeper patent and resurrecting its corpse. Thats 100% the Swivel Sweeper and they removed the rearside brush and changed a few designs with the mold.
Once a patent expires that's it. Anybody can copy something once the patent expires. No need to pay the original patent holder.
Hey Brian,
I know you have much of the following information; but I include it in case you are unaware and for others unfamiliar with such Eureka minutiae.
All:
While I am unable to attest to the Easy Glide's airflow, the motor is rated at 4.1 amps (as far as I know there was only Type A). The standard blender motors used in the 1400 Series in the 1980s were rated at 4.0 amps, for comparison.
And just to clarify, Brian was referring to the pastel green-base model 260 with a gold headlight visor that was made from 1957 to 1960. Its rating plate lists the motor rating at 350-watts (3.04 amps at 115 volts).
The Lagoon Blue-base 260 (Types A, AK, B, BK, C, D, DK, E, and EK) with the silver headlight visors that were launched in December 1960 all used the pancake 3.5 amps motors that were apparently used in the 2000 Series (and early 1400 Series) until 1978 when the 6.0-amp ESP motors were used in the Brandywine 2000 Series uprights.
    380.9 KB
