Electrolux 1205 Motor Rebuild
sekess
US
Hello,
We are the original owners of this Electrolux 1205 from 1975 and I had a few questions as to sourcing good quality parts:
1. Where would you guys order the (I think #608) fan bearing from? Is there a supplier that you know of that carries these bearings that are of known good quality?
2. Is there a specific oil that you guys like for the sleeve bearing on the other side of the armature?
3. Where do you guys get those armature dressing sticks that I see people using to clean up the sections that the brushes come in contact with?
Thanks,
Steve
Personally, I have always bought my bearings at the local Auto Parts store.
Armature sticks should be found at any QUALITY vacuum repair shop. Where in the US are you located? Many of our members have sought out good shops in different parts of the world, and can make a recommendation.
For the bushings, I always use 3-in-1 MOTOR oil (in the BLUE label bottle). Do not use plain 3-in-1, it will gum up the bronze sleeve bearing
Hi vacuumland650,
I'm in Northern NJ.
Really - autoparts stores carry bearings for electric motors? There is an Autozone close to me. I wouldn't have thought to look there.
Most urban.....
places have bearing and seal shops now. Just go there....tell them the application and they will measure the bearing. Stay away from Chinese bearings if you can.
The product mentioned above is specifically for small electric motors. It is 20wt non-detergent oil. Pretty easy to find. I use it as well in bushings, although I make no claim that it's the 'best' product out there.
I would certainly test your armature....plenty of YouTube vids on that. Also get the correct brushes. Commutator sticks are out there....I found mine on eBay....although shortly after I bought mine, the seller doubled his price so I don't recommend him anymore.
Kevin
Hey Kevin,
"Most urban.....
places have bearing and seal shops now. Just go there....tell them the application and they will measure the bearing. Stay away from Chinese bearings if you can. "
Yea - I don't know of any of those types of shops around here.
"Commutator sticks are out there....I found mine on eBay....although shortly after I bought mine, the seller doubled his price so I don't recommend him anymore. "
That lousy bugger. Well, at least you got one before the price went up.
Thanks,
Steve
Perhaps
A local Aerus branch can help you. I know there’s one in Denville and another in Fairfield...not sure where in Northern No you are but my parents live in Morris Plains and I grew up there so I know these branches still exist. If you need to locate one go to Aerusvacuums.com and try the store locator.
We tool our Golden Jubilee to the Denville branch long ago when the bearing was making lots of noise and the guy there just told us the motor was on its way out. We didn’t keep it because we had 2 more newer models to replace it with.
Jon
Hi Jon,
I used to work in Morris Plains. It's about an hour away. I'll check out Aerusvacuums.com.
Thanks,
Steve
Honestly, if your motor's commutator is torn up enough that you really need a commutator stone... it's probably shot. It doesn't really need to be perfect. As long as it doesn't have any major grooves and isn't burnt, a ScotchBrite pad is generally good enough.
For the ball bearing, read the trade number on the old bearing and order one of a reputable bearing maker on ebay.
The idea....
of the commutator stone isn't to reshape/rehab a commutator. It's simply to dress up the segment so your new brushes break in correctly.
Note that these Aerus places are very geographical as far as being 'helpful'. The one here 45 miles away, has people with accents that I can't even understand. Propose anything about older Elux's to them and you get silence....then a pitch for a new vac.
I was talked into that Beyond "Guardian" air purifier by a 'roving' Aerus salesman.
$3,000+ unit. Probably cost the factory $500 or less to make. It did everything they claimed it would do however. This is the third yr with it. The filter is supposed to be changed every 6 months, $120. My UV light went out and that alone was $50. They would argue that over three yrs, that's a bargain.....only if you're rich and/or have someone with severe respiratory problems.
Same technology that NASA uses yadda, yadda, yadda. It's really a way for Aerus to get their foot in the door and sell you their other products. My fan makes more noise than it should. You should see that sucker....huge thing, sealed. I don't think I've ever seen a continuous fan quite like that. Salesman said to just go outside and blow the dust off it.....doesn't make any difference. I would bet money he's never fixed one.
Kevin
Hi Madman,
Yea, I'm guessing it's not in horrible shape. I'll know more when I open it up. I was thinking of actually using 660 grit sandpaper while I spun the armature in a drill - to clean it up.
I just wasn't sure if it would then have to be run in with a dressing stone or not.
Thanks for the info,
Steve
Hi Real1shep,
I know what you mean about those kind of sales techniques. When I was younger, I bought a few Thermogard replacement windows because a similar sales tactic. After living with them for a while, I came to the conclusion that they are overpriced and they don't keep the cold out the way I expected they would (from the sales pitch). They also gave a lifetime warranty against breakage - no matter what. But, the creeps went bankrupt a few years later and then start up again under a slightly different name.
Lesson learned.
Looks like I should replace that tubing that is parts of the dirt sensor mechanism. It's getting yellow and it's not as pliable as it should be.
Do you guys know what size (diameter and wall thickness) tubing that is? I can measure it. But, I thought maybe it's some standard size that's used in there.
That tubing you......
can find at any good hardware store.....just try to make sure it's not from China. Their tubing has lumps and irregularities.
Make sure you replace all of it. I usually take the mechanism completely apart and examine/clean the diaphragm etc.....but you don't have to.
You could dress the armature with 600 grit, chucked in a drill. But it's more reliable to have the motor running and dress with the stone. People do both....I prefer the stone.
Make sure the brushes move freely inside the holders...if they bind even the smallest amount, your carbons won't wear evenly.
I'll reject an armature if the segments are significantly worn down and you can see a wear line indent where the brushes have been running.
Also make sure there's a significant groove between the segments. If the groove it too shallow, you'll get arcing.
Kevin
Hi Kevin,
Thanks for the info.
Is it possible to take the dirt sensor mechanism totally apart? I removed the geared screw section that has the 2 o-rings. I lubricated the o-rings and then screwed it back into the diaphragm body.
I wanted to disassemble the body so as to clean out the dust. But, the two halves looked like they may have been glued together in 2 spots - not sure about that. I didn't want to start forcing things. So, I left that as is.
But since you mentioned it, is there a way to separate the two halves without cracking anything?
Thanks,
Steve
Hi Kevin,
My mistake. You meant the diaphragm on the other side of the tubing. I thought you were talking about the clear plastic section that does the dial adjusting.
Wow Steve
Small world. My parents moved to Morris Plains in 1966 and are still there. I was born in 69 and lived there until 1993 when I moved to Dallas for a job. Rarely do people know Morris Plains so I usually just say Morristown and Parsippany areas since Morris Plains is so small. Anyway., 8 think both the Denville and Fairfield shops are the old school more helpful types than some that have changed ownership more recently. You can also try rvacacuums.com and ask to speak with Ray’s son. Ray Satterwhite is an Old school Electrolux now Aerus dealer in Richmond Virginia and his son rebuilds and restores old machines. Take a look at the web site, give him a call perhaps he will get you what you need!
Nice that you want to save your Golden Jubilee. I remember when the one my Grandmother had was brand spanking new! Wish I had more to offer. I have a Silverado and the motor has gone out this year. There is a guy on here that rebuilds these motors. I’ll have to look at the thread and see if I can find his member name and perhaps you can email him for additional info. Not all me members check in regularly.
Jon
Sekess - 660 grit will work fine. (Personally, I'd use a ScotchBrite after the 660 anyway.) Be careful chucking the armature in a drill. Especially with the end of the shaft that goes in the sleeve bearing, as that needs to be perfectly smooth. What I do is clip a piece of rubber hose in the appropriate size and put it over the shaft before chucking it into the drill. Since most people won't have spools of vacuum hose in 4 different sizes, a couple wraps of masking tape will work (clean off the adhesive with alcohol afterwards). And chuck it in gently. Or just chuck the other end of the shaft lol. Still try not to mar screw threads or anything like that.
Also, 2nd on Real1shep - clean the grooves between the commutator segments. Run a box knife through each groove. The carbon powder buildup will be removed as easily as you'd imagine. However, some motors (in general) have the grooves filled with some kind of plastic or epoxy... which won't yield to a box knife, just a heads up.
When it's all done, the motor will have to be run for some time to break in the brushes, if not using a stone. But like... that's easier anyway lol.
Thanks Jo,
Yea, I was in Morris Plains some time ago. It was a nice town.
I'll definitely take a look at rvacuums.com and call after I get it all apart and get more organized as to what I need.
Hey MadMan,
Great info - thanks.
You just clean it with a ScotchBrite pad manually? Or, do you also have the armature spinning in a drill - like when you use the 669 grit paper?
and
Can't you just clean off the armature with contact cleaner instead of the abrasives? Or, is that not enough?
Thanks again guys,
Steve
I don't want.....
to be misquoted here. I NEVER chuck a shaft up in a drill...too easy to mar or put a burnell in the shaft. I said you "could" do it that way.
I used to gently rotate the shaft in my hands using 600 grit paper only to get the charring off....then use the stone to help set the new brushes.
There's a whole technology thing on how deep the gap depth should be between the segments. Depends on the diameter on the commutator, brush width etc. That's too much bother for me. I've only seen it matter if the grooves are too shallow.
Kevin
Ohh....
and if you do need to deepen the segments grooves, MM is correct as there will be an epoxy like substance there. You need like a draw knife of the correct thickness. They make commutator knives that are made for this purpose. I've always been able to find just the right blade size from cutting knives I have. Even so, it takes time and patience.
Kevin
Chucking an armature in a drill is sort of the fancy way of doing it. It's good for folks like me who have all the tools at their disposal, and random things like rubber hose laying around.
In my experience, most motors won't need more than a ScotchBrite pad, just to freshen it up. With or without a drill, but yes, if you do the sandpaper, I would do a second pass with the ScotchBrite afterwards. It's probably not absolutely necessary, though. You could get away with just the 660 grit.
As for contact cleaner, it really depends on the condition of the commutator. It it's in great shape, a wash with contact cleaner or brake cleaner would be plenty (and unnecessary). But most motors after having been used a while could use some freshening up with abrasives that will actually remove an oxide layer and possibly even out some very minor surface imperfections. Then you get motors that have more pronounced grooves which basically need to be machined to be perfect again.
It all depends. You don't *need* to do any of this. I bet the motor runs fine as it is. The goal is really just a thorough inspection, and responding to anything that needs attention.
Mind you, there are people that frown upon the use of abrasives. They are the same people that say no to abrasives on electrical contacts, and will tell you that you need to use an electrical contact cleaning strip... which is legit just a fancy piece of 500 grit. So yeah.
Hi MadMan,
Yea - that's what I will do. After opening it up, I'll decide how far to go with cleaning up the commutator based on its condition.
At the very least - I'll lubricate the sleeve bearing. Too bad it's not possible to grease the ball bearing. It would be nice to get some fresh grease in there - even if it is still spinning freely.
I'll know more once I get a little time to open her up all the way.
Thanks MAdMan,
Steve
Depending.....
on the ball bearing, you can re-grease them. Most have covered sides to keep the grease in. Those covers can be pried off gently with a dental pick by the outer edge of the seal, if they're not metal.
However, if you put a finger inside the inner race, push and rotate......and you feel any roughness whatsoever, I'd replace it.
Using a drill is not fancy, just convenient. Chucking up in a milling machine and doing a true 90 degree clean with a jig would be fancy. Most commutators are easy to clean with just the the sandpaper method and/or Scotchbrite. But even with Scotchbrite there are green, purple, brown(maybe more)....all have varying degrees of abrasives.
I think you get the idea. This has become sort of a pissing match of 'do this', 'do that'. All have their own range of usefulness and none of them really 'wrong'.....so just pick your poison....lol.
Kevin
Hey Kevin,
Oh - that's potentially good about the ball bearing - that I might be able to grease her up. And yea - if there's any roughness - I'll replace.
Now - One issue that I know I have is with the the sheath for the power nozzle wand. At the top where the hose gets inserted, there is a springy circular metal piece of metal that catches and holds the hose end. That piece of metal is broken. there is no spring to it. There is the same gripping mechanism at the power nozzle itself. That one still works as it should. So what happens is - the hose doesn't stay in the sheath when you pull back, it easily slides out.
So, is that repairable? The spring steel piece doesn't look like it was meant to be repaired.
Thanks,
Steve
No
It’s better to change the upper wand altogether. The new style uses a click lock that locks in to the slots on the hose handle metal. There are two of those on the hose handle. The wand does come out and it is removable by putting a small screwdriver in the slot just below the spring clip release and pulling the clip upward and holding it upward while then pulling the wand out of the sheath. When you start this process however you have to push the wand in while pulling the little locking clip up with the small screwdriver. Also if your sheath is cracked near the power connection (typical) the newer ones were better reinforced snd thicker m so they won’t crack as easily so you may wish to change that too. How is your hose? I’d it’s the old braided one it may be due for replacement, there were notorious for coming apart internally and then leaking. You can test it eventually by covering the end of it with your hand while the vac is running. Open the blower door and see if there is air coming out with your other hand. If there is, the hose is leaking. Virtually no air should come out the exhaust if there are no leaks when the end of the hose is blocked off from suction.
Jon
Hi Jo,
Yes - it's the old braided style hose. I started taking some of the vac apart. So, I'll have to test it after things go back together. But either way, I was thinking about replacing the hose since I have heard that the rubber will most probably deteriorate if it hasn't already.
The plastic on the sheathing by the lower (and upper) is still intact - no cracks. But since the spring clip is broken, I'm going to need to replace it anyway.
Is there a particular place (online) that you guys like for buying hoses, wands, sheaths, etc?
Steve
To get......
OE, buy used on eBay or someplace similar. Check out old vac shops in your area if applicable.
You could ask here too in the Super Market forum.
Kevin
Usually ebay
You’ll find in other threads about Electrolux hoses that opinions vary in the generic hoses. Personally I prefer the OEM ones. Used OEM vinyl hoses come up periodically on eBay and there are a few for your machine available now. The way you can tell the difference from an OEM versus generic is the hose handle. Only the OEM will have the round dial on the underside for the suction control. The generics will not have it or have some other sort of system. The vinyl hose is the only way to go, that you will find to be unanimous here. Aerus does sell the hose still for your machine if you prefer new and it’s $129.
You may not need to replace the sheath as the inner metal part that has the broken retaining spring for your handle slides out of it. But the new sheaths are nice as they also include a slide button on the opposite end should you wish to take the lower exposed metal wand off for storing. Again, here I’d go OEM...the generics do not have as high quality plastic.
You may wish to bypass the terminal block as you remove the cordwinder. You’ll notice it is attached to the inside side of the metal body and makes the electrical connection between the unit and the cordwinder.. Aerus sells a bypass kit. The terminal blocks became problematic and a known source of arcing and were discontinued for a direct wired system. It is something you can install yourself and is inexpensive. My Dad and I did it to our Golden Jubilee when I was just a teenage and I’m 51 now! The Electrolux rep was very nice and told us how to do it. All we needed was a drill and a screwdriver.
Just thinking ahead since you have the machine apart so you can give it a “full overhaul”.
Also replacing the brush on the power nozzle will do wonders for you if you’ve never replaced it. It will almost self propel itself with a new brush roll!
Bristle strips are available if your floor brush is worn. WD-40 works great on the rug and floor tool swivel elbow to make that swivel much better. Genuine horsehair bristles are available for the combination upholstery tool/dusting brush if yours is worn...you don’t need a whole new tool.
WD-40 is great for the wheels too especially the front swivel one to keep it working well and quiet.
The automatic control should be set between 2 and 4 for regular cleaning, a lower number will trigger it to open sooner and a higher number will keep it from opening too soon. However, the cleaner should not be run continuously in 5 or 6 as it will wear out your motor. Some people think the bag should be stuffed before changing and hence use 6. This is wrong and will burn out your motor.maths bag needs some empty space to pass air through effectively to cool the motor and should be changed when the system triggers in the 2-4 range normally depending on your cleaning needs. 5 and 6 can be used to override the system for fine dust such as plaster or ash to complete the job and 1 is usually for people who have lots of shedding pets. If you have a lot of carpet use a lower number, it will insure that your are not running the machine with low suction due to a bag being blocked by too much dirt in it. It will stop when the suction goes down enough to reduce the efficiency needed for thorough rug cleaning. Higher numbers are ok for hardwoods as you don’t need as good of suction efficiency for that type of cleaning so up you can allow the machine to run less efficiently for longer and bag with more dirt.
Make sure you are using genuine or 4 ply bags. The two ply generics are horrible and usually have a plain cardboard top with no printing on the top. The 4 ply multi filter brand ones are pretty good but Aerus claims their current 2 ply bags are far better but some debate that on here. I think both will be fine. But again, the 2 ply cheap ones are the worst and I’d stay away from those for sure.
Jon
