Dyson DC24
beko1987
Stokenchurch, United Kingdom
My first and skeptical foray into modern dysons, having only been exposed to DC14's and below so far!
From Dyson DC24
Picked it up last night for £20 (how the mighty have fallen) and the brief look I've had of it, and the subsequent googling thereafter show the brushroll motor may be scrap, but I haven't stripped it down yet.
From Dyson DC24
It's tiny. Missus took the piss out of it when I bought it home, thought it was a toy for Eva, and told me off for spending £20 on a toy! She too kthe piss even more then I turned it on and heard the horrible noise coming from it!
Still, £20, what have I got to loose! Will try and start stripping it down later
Oh MY GOD!!! Where did you get it? £20?!?!?! Lucky! I want one :D at the carboot yesterday I saw the DC24 cleaner head for sale with brushbar etc for £10, dunno if it was burnt out or not though
Our local facebook selling page. Woman wanted £35 for it, I offered £20 and she said come round! Think she was moving.
Shame I didn't get it before you went to the carboot then, looking on ebay good heads are commanding high prices, and forum posts from ManchesterVacs seems to confirm this.
However, I can find nowhere on the net where people have tried to repair the motors, so who knows, I may be able to strip it down, or just smash it up with a big hammer and find a cheap working motor!
Oh no, :( Im sorry, I would have bought it for you though, maybe you can get it modified. :]
PS just to let you know, that is a later DC24 because of the plug, /Early Models of DC24 and DC25 had the grey square ones till the late ones had the triangular plugs that match the vacuum's colourm (iron) and lol it was funny when you told us how your missus blazed the Dyson. :P
The local shop
Has had a few of the 24s in the plastic shaft that connects the brushroll and the gear for the belt tends to snap i think i've seen about 3 of them now with that issue
They seem to be made of chocolate, mine certainly creaks alot. It also doesnt like standing upright and locking itself up, have to push really hard. Hopeing a good stripdown will sort it. Looks like a proper in-depth job though.
Can get a DC04 in bits within an hour, Turbopower in about 15 minutes. Imagine this will turn into a long term project, must remember to take pictures of everything so I know where it goes!
Whwn I repaired the dc41animal, the build quality was like a polystyrene dyson and the thing also needed to be pushed hard for it to stand upright and the suction was not even as good as a dc04
demons dc37 onwards are total barber toy pieces of junk apart from the digital slim dc 44
dyson will never make a vacuum better than their dc 01 to dc27 models
Not enjoying this very much!
Stupid fiddly thing
Started off by actually seeing whats wrong with it (turn your speakers down for the vid!)
However, by doing that I found out it's the main motor thats making that horrible racket, the brushroll spins ok!
So I had it apart
From Dyson DC24
brushroll out
From Dyson DC24
lots of teeny tiny torx screws later the cover comes off
From Dyson DC24
Motor and gubbins out
From Dyson DC24
The last pic of this alive...
From Dyson DC24
Tested it by plugging the motor into the unit, holding it in my hand, closing my ears and turning it on. Motor span a treat
A DC04's worth of screws already
From Dyson DC24
vent hole full of fluff
From Dyson DC24
From Dyson DC24
Pile of stuff for washing
From Dyson DC24
All washed up and dried, I put it back together. I then had the bright idea of taking the cog out to get to the bearing beneath to give it a clean up to avoid premature expiry
From Dyson DC24
Buggar... Anyone know where to just get the plastic cog and housing that clips onto the motor?
Put the head together so I don't loose anything and left the sodding thing alone for now!
You're a braver man than I am. Stripping normal Dysons is easy enough, but having seen what it takes to disassemble the Ball models I decided early on not to even go there. The ball itself is a treat, with lots of thin, easily broken wires running at sharp angles and getting pinched :o)
The 24 is a cool looking vacuum, and once you get over how hilariously small it looks, it's quite nice to use. Really wasn't too happy about the build quality though, or the fact that it's far too complex in design for the job it does. Three weeks later mine went on eBay, and fortunately I made close to what I'd paid for it. I've since come to the conclusion that late model Dysons are not my thing.
As for the brushroll motor drive housing, as far as I'm aware these are not available as a spare part, rather the whole thing is sold as an assembly. Your best bet in this case would probably be Manchester Vacs. They break Dysons for spares, and may be able to sell you just that part alone. Failing that, they will have the complete assembly available for a much lower price. If you speak to them they are usually very helpful and will do their best to find what you actually need, rather than trying to upsell you.
I'm hoping to not spend too much on it! Got the motor out and everything cleaned yesterday, need to bring my socket set home to get the motor apart and see whats up with that, it spins fine by hand!
Got the main chassis to do now, and looking at all the springs and valves scares me a bit! May put the motor housing back together first.
There's also thousands of screws, just had to order a nice little set of long torx bits to get at some!
Listening to that, it sounds like either the fan has something trapped inside it (was used with the pre-motor filter missing, or something was put down the inlet tube to the motor), or the worst case scenario is that the motor bearings are shot.
Usually with the DC24, its the brushroll motor assembly that fails rather than the suction motor - they were renowned for it.
I'm sure all will be revealed when you remove the suction motor?
The DC15 I have is one model I never took apart, as it too is very complex, and actually has the control module built into the airflow pipe between the cylinder and the motor inlet so that the airflow cools the components.
The filters were comically bad, am hoping it's something simple like that!
Once the motor is all stripped, I'll put it back together to check progress before I strip the rest of the machine! The fan blades are caked in hair and other rubbish, but dont think that would cause that noise surely. Can't feel anything catching when spinning by hand, although the bearings feel a little dry
I think it worked its way through the filter, judging by the state of it.
ManchesterVacs came up trumps, new cog assembly for a smidge under £6 delivered! If all else fails I can hopefully flog the working brush assembly for the cost of the machine!
I have the patience, just not always the time!
Stupid thing
Had another go at this last night. Bought my socket set home and tried to take the fan off and the thing wouldnt budge. I was bending the fan slightly doing it so left it in the end. As it spun ok by hand I thought it would be ok, so spent 2 frigging hours fiddling the bottom half of the machine together, plugged it in and...
No better, the motor is shot.
Put the thing back together so I dont loose anything, and will either look for a new motor for peanuts or sell the thing as broken and try to get my money back. Bought a new part from ManchesterVacs for it, which is useless now, however might be my best chance of getting my money back for the machine, since working heads are rare!
On a more positive note I picked up a DC14 All Floors in great condition, just needing a clutch rebuild last night for £11, so hopefully that will be alot nicer to rebuild!
I did take more pictures of the 24, but cba to upload them now. Even if I do get it working, I wouldnt want to sell it anyway, to oscared it will break on the new owner and lumber me with a bad reputation, so it'll probably go to amys mum anyway!
Whoah, good job you didn't pay the full £35 for it! good job haggling :D I love doing it too at carboots, and where did you get the dc14 from for how much? :D Ty because i got a dc14 blitz it blown up for £16 off eBay
Ps Hows the dc01?
Ps Hows the dc01?
