Does anybody use their Kirbys to shampoo carpets?
have you tried a diffrent
Carpet? Perhaps the problem is not in the machine!
the above pic is the sticky residue
i was talking about if the carpet is allowed to dry with this lot in it it feels sticky afterwards so what i do is rather than have to dismantle the Kirby then fit the carpet washer i simply use the hoover scrubber that dose a far better job them remove the dirt and water with the vax the results are exellent .I did a test some time ago with a offcut of cream carpet i poured honey coffe gravy and some black treacle on it then left it out in the garden in the sun all day till it was totally dried [i didnt clean it straight away like they do on those silly tv programes ]next i tried to clean half of it with the Kirby it loosened all of the dirt and even managed to flick some of it into the suds tray but the big brown stain was still there i then left it to bake in the sun again till it was dry then i did the other half with the Hoover scrubber rinsing with the vax the lot was gone in one go a couple of hours later the carpet is dry and more important not sticky
Hi
<span style="font-size: medium; font-family: book antiqua,palatino;">Hi, As I've mentioned before I get that same residue on many makes and models of vacuum cleaner coming in for repair.</span>
<span style="font-size: medium; font-family: book antiqua,palatino;">Most if not all don't own a Kirby. Many own Vax and Bissells shampooers. Some don't have any carpet shampooer at all. </span>
<span style="font-size: medium; font-family: book antiqua,palatino;">Also I don't get any residue like this on my Kirby rug plates. Nor are my carpets left sticky.</span>
<span style="font-size: medium; font-family: book antiqua,palatino;">James
</span>
Sounds like...
<span style="font-size: medium;">Too much foam was laid down. Possibly the toe-touch control was not all the way down.</span>
<span style="font-size: medium;">What kind of shampoo was being used? Was it Kirby shampoo?</span>
Sounds like...
I further agree.
I primarily use Electrolux Turbo in my Kirbys mainly cause it's what I have on hand. Not any more expensive then Kirby but I am used to it. My dogs like it. I've used Kirby as well as other commercial dry foams with good results. For rentals, I use Franklin Dry Foam which is more concentrated so it can go further or produce good suds.
I actually use my vintage Kirby Dual Sanitronic 50 w/ its original Rug Renovator w/ satisfying results compared to the big "G" series. Not better, just good for its age. I empty 1 little tank per room but it works. Just a note, this would be the 1st running model of 1965 where we are introduced to the, then called, "Rug Renovator" known now as the Carpet Shampoo System. Notice the same basic design exist today. I don't mind using this in small room s since the stay is shorter so you can get closer and more snug fit up against ways where tray can't get.
Be sure to store your shampooer tray in its box properly in the fitted cradle so not let sit on its soft rubber guides. This, if deformed, will cause uneven foam spreading. The older kits didn't sit in bottom but take care to set down so not to let other items lean against the rubber. Keep facing to side of box.
Easy to clean up as said many times. Not the quickest, but easy. To help dry out the brush I lift roller and let spin for a moment, usually 30 seconds, before taking apart to help make clean up a little easier. If brush is dry, you can simply comb out dry foam & dirt by hand so you are not waiting a long time to put away. Avoid putting away with a wet brush.
a Flat shampoo cap!?
Well, look who's the new Kirby expert on the block!
Even I didn't know of a Flat cap, wonder how the shampoo was supposed to be measured?
I wonder if the housewife used the measuring cup she kept handy after another successful cake!
Rug Renovator measuring cup & cap
The cap is same fitting as the later with cup built in. But the 1st runs used this flat cap but supplied a matching 2oz measuring cup seen in photo. Notice the small cut out to assist in pouring. Everything else about this 1st generation take is the same. Suds filter scree was a tighter woven fabric so clogged faster. The intake foam dirt filter sponge old style foam broke down with age so count on getting a new 1 if using it. It's smaller in diameter then the "G" series but same thickness so you can trim 1 down just fine. I'd use a newer suds filter screen as this made for better suds. These "2" components are essential in producing good suds or putting out too much water too fast. Check liquid tube to make sure it flows freely. Fill tank in sink and tip foreword. water should slow steadily out the suds nipple with screen removed. Use new foam dirt filter sponge, clean if dirty. dirt hair and fuzz will be stuck here.
Kirby D50 Rug Renovator
Here's the Rug Renovator on the D50 going to work. Handled very well. With the right suds screen you can get a nice steady slow peed of suds lay down as to not have to move so fast to keep up.
RE: in a Kirby system,
Lol, yes, It's what I had on hand for regular use. I do like and use Kirby shampoo when I have it.
When I had a classic 3, I did use it, as it was the only shampoo machine we had, I do have all the attachments for an Omega but no Omega, so yeah ive used one, it got all the stuff out of the carpet, carpet was slightly damp still but even my Bissel leaves it just as wet so...
I've got four Kirbys with shampoo systems--a Legend II, a G7 Diamond and two Sentrias, but I've never used any of them. I offered to try one out on a friend's carpet where her young nephew spilled a soda, but somehow we never got it together to do that. The G7 Diamond had obviously been used extensively with the shampoo system and the original owner apparently tended to be impatient to finish the job because the floor nozzle was absolutely caked with dried-on debris and the belt lifter was rusted out from vacuuming wet carpet.
I have to agree that while Kirbys come with an impressive array of tools, re-configuring the machine is a bit of a pain. When attachments are needed, I'm far more likely to pull out one of my trusty Electrolux canisters.
I also have a Bissell Little Green machine, which is great for small spot cleaning jobs on carpet or upholstered furniture, but it certainly would not be satisfactory to try to do a whole room with it on one's hands and knees.
Ew
Using a kirby to shampoo carpets is akin to vomiting on them.
The fan with all that FILTH rotates the other direction, still coated with FILTH and you use that to clean your carpet?
