dial set Olympia One
I don't own an Olympia One, but I have two 1205's, a Super J, a Silverado Deluxe, and a Diamond J. All of them I keep set in the middle, about 3 or 4, and they all seem to work just fine. My suggestion is to use the above setting, see how things go, and then make adjustments as necessary.
A comment from Gary Saarimaki that can be found here;
https://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?43594
"Just so you know...the dial settings from 1 to 6 are not for suction...they control at what point the machine will automatically shut off depending on the type of dirt being vacuumed. Setting 1 is used when vacuuing fine dust (which will clog the bag pores sooner and restrict airflow) and setting 6 is for coarse dirt. The higher the number the longer the delay before the machines automatically shuts off.
Gary "
