vintagerepairer
There is a way around of that light bulb problem. You just reconfigure the wiring so that the lamp holder is wired directly to the incoming 240V. My memory tells me that the Moulinex used a small brass & porcelain light fitting with the standard 220-240 v small bayonet cap fitment, despite being wired as a tap into the motor to use a bulb of much lower voltage.
James the green turbopower with autoflex sounds very much like the grey Electricity Board model, particularity as you say it had the Hoover plug. Thinking back to it carefully, was there a headlamp? You would not be the first to mistake the colour of this cleaner for green, as it was such a strange colour and liable to fade.
