A question about TriStar different years ...and
And here is the model number from my CXL Tristar. Its 2-1000 which does not match the one that Kenny has. I once sold a Tristar DXL with a geared belt nozzle on Ebay and I needed a belt for it. I went to the Tristar distributor in my town and the guy said that there was not a silver Tristar with a geared belt. So it just goes to show you that even the vacuum distributors don't even know their own product. I know that there is also an all black power nozzle with a geared belt sold with the DXL that looks different than the CXL nozzle and not at all like the nozzle sold with the EXL.
Chad Cunningham
Easy Answer!
Folks:
In my first job out of high school, I learned why you see products that don't match any known records of what a company produced.
The job was in a watch and clock repair shop that handled warranty service for Westclox and Seth Thomas, both then owned by General Time.
Several large store chains, like Rose's, Rexall Drugs and Ben Franklin, would periodically box up large shipments of customer returns and send them to us for repair and reboxing.
What would happen is that we would normally have exactly what was needed to repair each clock exactly as it was designed. But sometimes a shipment was very large, or an uncommon clock or two would be in it - and then there might not be the exact parts needed.
What was done in those instances was to take the nearest equivalent part and substitute it. A face designed for one clock might replace the damaged face of another, or a clock normally sold only with a blue case might get a pink one that was identical, but intended for another model.
The stores didn't care, so long as they got back salable merchandise of equal value to what they'd shipped. Consumers had very little way of knowing that a particular clock's face was "wrong," or that the hands on it didn't "belong" to that exact model - so they bought the clocks anyway.
So, if you see "oddball" stuff, there is a chance it was repaired either before sale, or under warranty after having been sold. Repairing merchandise before sale used to be much more common than it is today; such merchandise is usually marked "refurbished" now, and sold at a reduced price.
That geared belt model is original to tri star. When I worked for them for a while, the man I worked under said that when they came out with that (which was the first geared belt experiment ) it was a disappointment because the belt would get to hot and somtimes melt the housing. Then they went right into the all black one which also had the geared belt and still they had problems. So after that they fixed it by using the Electrolux style nozzle on the EXL.
The 2-1000 & 2-101 PNs are the same thing; some TriStar PNs may have been converted from flat-belt system to geared-belt system, perhaps for user convenience.
Is there a GEARED pulley that can fit a Eureka VGII brush roller? I'm about to convert my red PN to a geared belt soon.
Is the white dot a reset switch?
Here is a link to Tristar USA's parts page, with a diagram of the 2-101 Power Nozzle illustrating the geared belt. Right below it is a diagram of another model with a smooth belt. I wonder if they they discontinued the geared belt and reintroduced a flat belt before switching to the black nozzle that Phillip mentioned.
http://www.tristarvacuumscausa.com/pdf/parts/EX_20_Powerbrush1.pdf
Or TriStar was just using the last of the two-piece (black plastic husing & alumnum cover) to make the 2-101 PNs beore they went to the all-plastic one-piece housing for the 2-51.
I remember growing up around Compacts & TriStars; I was only 3 yrs old when my parents bought the 2-speed CXL back in 1985. Ever since then, I just CAN'T LET THE TRISTAR CXL GO! It even put my Dyson dc23 to shame; the TriStar has MORE suction & MORE durable than the Dyson. :P
I'll be using this for as long as I'm here. :)
"Is there a GEARED pulley that can fit a Eureka VGII bru
From what I've been told, nope, plus, a proper VGII in a Tristar PN is surprisingly ineffective, the beater bumps do not protrude from the rugplate, so it doesn't beat as it sweeps, it has to be a 4-row VGII roll (with modified VGII end caps) with VGIII strips, or like I did with my Eureka Rotomatic PN, an actual VGIII roll fitted on a modified VGII axle, it's not standard fitting, so either way it requires modification... :)
And yeah, that's an overload reset button (if you pick up a sock or the edge of a rug, etc.), something that isn't required on the flat-belt model as the belt slips enough to not cause the motor damage, thus the belt would fail first... :)
The Vibra Groomer is supposed to perform its exclusive triple-action "beats-sweeps-cleans) principle; however, it depends on the type of carpet being vacuumed. It may work nicely on tacked/stapled down or carpet with padding underneath, but might not work on glued-down or commercial type carpets.
This is the style of brush roller that I sometimes use on the TriStar PN; depends on my cleaning needs, I use the 4-brush wooden roller or the VGII.
http://www.totalvac.com/ER-2030ES.html
Well, in a Eureka PN, the VGII does as it's supposed to, but in a Tristar PN, all you're getitng is the sweeping, with no beating as the beaters don't protrude from the nozzle, so it's not as effective as it would be in a Eureka PN or upright vac... :&#92
The brushroll that's in my Tristar's PN, as fitted by it's previous owner, is a generic 4-row VibraGroomerII brushroll fitted with VGIII brush strips, and it works superbly, you can add VGIII strips to your proper VGII roll, but to be honest, it'd still effectively be just a 2-row non-beating brushroll because of the above issues with VGIIs in Tristar PNs...
These are my two PNs, top is the Tristar PN with it's black 4-row Generic VGII, and bottom is my Eureka Rotomatic PN with a proper VGIII brushroll (note the shallower angle of the strips and the raised beater section), the best part is that they're interchangeable, so they fit in either make of PN, it just takes a bit of grinding of the end caps to allow the extra 2 rows to fit a VGII axle, and after that you're home free and ready to beat the dirt out of your carpets... :)
yeah
I have a Beam Rugmaster power nozzle that has the same setup and I didn't have to modify anything. Do I see a Kirby belt in your nozzle?
Personally, I like the soft brushes of the original brush roll. Thanks for posting your modification.
floor-a-matic:
I love your red two speed! I have one too. Altho Im jealous, you have attachments, I'm still without those :(
But I want to ask you, does yours leak alot of air around the Hi/Lo switch? Mine does quite badly. It doesnt bother me, because all the filters are infront of the exaust, but I would think if there was a way I could seal it, it would be a little queiter. Also, on high speed, my power switch/handle starts rattling around. Its rather annoying. Anyone have suggestions on fixing that?
"Do I see a Kirby belt in your nozzle? "
It's either Kirby or Royal, haven't opened the PN up for a while, they're pretty much the same belts anyway, and you can get generic ones which say they're for all three (Kirby, Royal & Eureka/Tristar PNs)... :)
Yes, sometimes the Hi/Lo swtich are leaks air, there's carbon brush residue around it. Those tools are the new ones; the clear glitter tools have been put away just for display.
