Thoughts on the Dyson DC25.
The Dyson dc41 and dc39 are much better compare to the dc25 the dc25 is not that bad of a vacuum cleaner
DC25 is powerful
HAs stiff bristles
Agitates quite good for a Dyson
Has great, powerful suction
Sturdy
5 year parts and labour guarantee
You will own it for a minimum of 5 years if you wanted to :)
Quiet
Durable
Stylish
parwaz786 :)
DC41 is powerful
HAs stiff bristles
Sturdy
Durable
Stylish
the dc41 Cyclone technology is far far better.2012 model I had for a year and used every single day and I never clean the filter the filter stayed so clean.people complain that the handle twists that only happens if you take off the wand the dc41 probably one of the best Dysons I've ever seen it much more manoeuvrable
Lol you just copied and pasted what I typed, but DC25 has stiffer bristles than the DC41. The DC41 has the same stiffness bristles as a Helix DC33 brushbar. The DC25 grooms better, it has a better brushbar. The suction is powerful too, and I repeat, there is less things to go wrong with the DC25 than most of the newer current 2012-2014 Dysons
PS The handle was stiff a bit flexible even when the wand was in place with the wand cap on. I think it was either that, or the body flexing, because there is a gap in the main body so when you take the cyclone assembly off, the hose can be seen. DC25 doesn't have this, The body does not flex, it is much stronger. If I could choose between the DC41 or DC25, It would be the DC25 because of what it is, not the value. It's just a better machine
I'm sorry but the DC41is a overall better machine is Got stiffer bristles better cyclone technology and better to stearate the DC 41 is so much better but don't forget I've had both I would take a DC 41 any day over a dc25 any day
I tried/had both. DC41 does NOT have stiffer bristles, ask anyone, the DC25 has stiffer and thicker bristles.
I'm going to curreys tomorrow so I'm gonna have a look and the DC41 HAS GOT STIFF bristles the DC41 has got nice long bristles the DC 25 Has got short stubby little things . So you went out and bought DC 41. So if you haven't why you said you have had both ???
I tried the DC41 for a week in my own home, Had the DC25 for a year. The DC25 bristles are stiff, long and fat. DC41 has the same bristles as a DC33. DC25 grooms better. It's also a better machine, even though the suction is less (only 35 AW less) but it's not that less!
Put it this way. What is more stronger and stubborn, a thick stick or a twig? The DC41 bristles represents the twig, and the DC25 bristles represents the thick stick. The DC25 bristles are less likely to get worn out and are more stronger due to being thick and the DC41 bristles will be more flexible, so it will agitate the carpet less
Was that DC 41 the one you fix for your friend because obviously that one was faulty had something wrong with it . Am sorry but the DC 25 bristles are not long .might be stiff but there not long to the DC41 bristles are nowhere near the DC 33 I've had all of them had a DC 25 two years and DC41for one year and the dc33 for 12 months and dc24 Four months. And got rid of all of them and got the DC 41 just cleaned so much better. By the way I have had loads if the DC 25 in for repair so many problems
DC 41 DC25 bristles are made from the same material that they are the same stiffness is just the 41 as long the bristles and more of them are not send the DC 25 is bad I'm just saying the DC 41 is a little bit better. I hope we can still be friends :)
