VacuumFacts, why don't you install a central vacuum? You can get MD in the UK. https://www.centralvac.co.uk/index.html . You harshly critisize central vacuums but you have never tried one.
Electrolux EL25A. That was their last power nozzle sold here before they exited the North American market.What power nozzle is that?
It's only true when everything else is equal. @Vacuum Facts suggested it's much more nuanced than that, which allows the vacuum to perform similarly with lesser suction. His lecture says it all.VacuumFacts, turning down the suction reduces cleaning performance. I see so many dysons in for service compared to sebos or kirbys or even an electrolux. If you say dysons are the best and very durable while saying those who repair them, are wrong, fix one yourself to prove it. A vacuum is thrown around and used until it is dead. Dyson can't handle hat others can. Verysimple.
It's derived from first principles right at the very beginning and there's an entire chapter heading on it. Technically a summary of the lecture is post 1 here. I will be a doing a rev 2 of that lecture at some point next year probably to clarify and optimise (and correct) a few things.Yes that is in your lecture but is not stated clearly (IMO) "The speed of the air portion through the pile." More specifically, the speed of the air upon the dirt/dust particles.
Yes. This is explicitly covered in the lecture.The one exception or clarification is dirt particles that become agitated and removed/suspended from the pile. If there is no airflow to capture and remove these particles they can simply fall back into the pile. If the dirt is found outside of the pile due to agitation; an infinite amount of airflow at the pile will not remove any dirt if no dirt exists at said pile.
Hard floors are different in that they offer very high air resistance on fully sealed heads, maximising suction (minimising head pressure), and cutting off flow—hence the need for bleed relief. Poorly designed heads that leak don't clamp or need bleed relief, but they're poor on carpets.For hard surfaces the concept is essentially the same, just trade the "pile" for the "surface."
And you were right about that, which is why I didn't correct you—you called the sky blue and water wet in that case.I've stated mytheoryhypothesis in this very thread before:
You should know this is common knowledge here now; I even derived it from first principles like a scientist rather than just looking it up like an engineer. The entire lecture revolves around it.V-F, speed and airflow have an inverse relationship on a vacuum cleaner. Look at an airflow chart for any vacuum motor made and you will see that as airflow increases, suction decreases.
Orifice size controls air resistance, which is more fundamental.If you graph airflow and suction against orifice size
All this changes once you put the head on the floor, since various floor types offer different air resistances (equivalent to orifice size changes) and the system responds accordingly. Same if you change tools. How that affects airwatts and the situations that this is important is covered in the lecture.you see as you go from a closed orifice where suction is maximum and airflow is zero, as the orifice increases suction falls and airflow increases. Where they cross is the point where you have the most cleaning power and where calculated air watts are maximized.
You're understanding isn't quite correct. You need some flow, but it's total volumetric magnitude isn't important. It's speed is. This is governed exclusively by suction. Science in lecture. Large airflows are bad because they reduce suction, the speed of the flow, and therefore cleaning performance. Large airflows occur on low resistance flooring (rugs) so can't be avoided. High large air power is required to sustain suction in the presence of large air current to maintain the air speed. Again, see lecture.There needs to be a balance of both suction and airflow, along with good agitation to move the dirt up out of the carpet and suspend it in the airflow so it gets removed.
This is not always true. I recommend you understand the science better. Head suction pressure determines cleaning performance (or at least is the primary aerodynamic factor—the rest are also discussed). Head pressure varies based on the air resistance from the flooring and the resulting magnitude of air current. More air power is needed in response to situations where large air currents are present in low resistance situations.VacuumFacts, turning down the suction reduces cleaning performance. I see so many dysons in for service compared to sebos or kirbys or even an electrolux. If you say dysons are the best and very durable while saying those who repair them, are wrong, fix one yourself to prove it. A vacuum is thrown around and used until it is dead. Dyson can't handle hat others can. Verysimple.
As above: it depends what the head pressure is.Turning the power down when the carpet is deep is the wrong choice. All wrong. Get some air under the nozzle !
Because I don't have £9 million or the space. I've also no good reason to and many that do revert anyway.VacuumFacts, why don't you install a central vacuum? You can get MD in the UK. https://www.centralvac.co.uk/index.html . You harshly critisize central vacuums but you have never tried one.
@Vacuum Facts I really hope you're V16 review go viral and become extremely popular. That should teach stupid reviewers a lesson!It's derived from first principles right at the very beginning and there's an entire chapter heading on it. Technically a summary of the lecture is post 1 here. I will be a doing a rev 2 of that lecture at some point next year probably to clarify and optimise (and correct) a few things.
Is it like this?V-F is a Brit and has no idea what American and Canadian homes are like inside.
Not quite sure what factual claim you are making, but I welcome the evidence for it from you, once you've figured out how to form a simple factual statement.I have lived and traveled widely abroad including a large chunk of western Europe and UK. Lived for a time in Australia too. I stayed in people's regular homes including a nice two story one in a town north of Southampton that belonged to a relative of my motorcycle riding partner on that particular trip. North America uses very different carpets and rugs than one finds in Europe. I doubt his place in the UK has a "mud room" for changing in and out of winter gear, a room that is perpetually sloppy and dirty for months. And I am sure he isn't dealing with the fine clingy desert caliche my vacuums have to deal with in our high desert home. No true deserts anywhere in Europe. What works in a European home doesn't work so well in an American home. Europeans often get by with an air powered turbo brush, but those won't cut it in deep pile carpet. V-F lacks the hands on to know this. He has never seen the kind of deep pile carpet my first home came with and the problems associated with keeping it clean in a desert with dogs running in and out of a dog door. That kind of carpet is not used in Europe. V-F needs to see the real life cleaning challenges of American and Canadian homes. The problem is he doesn't know what he doesn't know but thinks he already has all the answers.
The first factual claim is that you have never lived in the US or Canada and have not seen our homes, our floor coverings or the dirt and pet hair we have to clean. As a result you have no way to accurately judge what we in the US and Canada need by way of a vacuum cleaner. You cannot create an accurate test if you don't know the environment to be simulated.Is it like this?
Can you present the evidence of how you've determined this with respectable certainty that wouldn't constitute a justified claim of stupidity or idiocy etc.? I suggest you don't know anything about me or my experiences, which would therefore make it pretty idiotic to imply you do.The first factual claim is that you have never lived in the US or Canada and have not seen our homes, our floor coverings or the dirt and pet hair we have to clean.
So this is BS and nothing to do with anythingThe first factual claim is...
Explain why in detail in a coherent way, with evidence. I disagree.The second factual claim is that you need to test North American market 120 volt vacuums on typical deep pile carpets found in US and Canadian homes to make any kind of informed opinions that are applicable to the US and Canada.
We'll ignore the next claim was several nested claims. OK, no contention here. Not sure why you raised it.Third factual claim, North American 120 volt, Japanese 100 volt and rest of the world 220-240 volt Dysons for example have different motors from different manufacturers and perform differently.
Show explicitly that your factual claim is true. The cordless machines use battery powered motors that are universal.The test of a European Dyson is meaningless to someone in the US because the products are different.
Hmm, your reply to 'me' was that you were referring to some elusive 3rd party.People get hypersensitive if I suggest they are stupid. However, let's take this one claim:
I also question if he has any long haired females, children, or pets in his household. Or if he/his family has any moderate to severe allergies.Can you present the evidence of how you've determined this with respectable certainty that wouldn't constitute a justified claim of stupidity or idiocy etc.? I suggest you don't know anything about me or my experiences, which would therefore make it pretty idiotic to imply you do.
You talk about "mains power" which is not a term used in America. It is a British term. In the US it would be called household current or residential power. "Line power" in North America is 480 volts stepped down to 240 volts at the local transformer and this is tapped at each end with a neutral at the center. The potential between either pole and neutral is 120 volts. For a 240 volt appliance like an electric range ( what you Brits call a hobb ) or electric dryer the outlet has ground, neutral and both poles of 120. The electrical potential between the poles however is 240 volts and the appliance uses the two poles to power it where a normal household 120 volt outlet has ground, one 120 volt pole and neutral. You talk about prices in Pounds. Not even Euros, but Pounds. That tells me you are Brit. I spent a year with the British military on a British base to know your idiom pretty well. It is pretty obvious, not just to me but many of us here, that you don't know our homes and our dirt. It is painfully obvious. You do not have the slightest idea what is needed to clean an American home.
So much to unpack here so I am leaving some of it alone...You're understanding isn't quite correct. You need some flow, but it's total volumetric magnitude isn't important. It's speed is. This is governed exclusively by suction. Science in lecture. Large airflows are bad because they reduce suction, the speed of the flow, and therefore cleaning performance. Large airflows occur on low resistance flooring (rugs) so can't be avoided. High large air power is required to sustain suction in the presence of large air current to maintain the air speed. Again, see lecture.
As I am sure you know and I am sure is in your 'lecture,' flow, speed, & "suction" (correct term would be pressure differential...) are all interrelated. Given a fixed orifice size an increase in flow will increase the speed. If you are being pedantic, then you can't blame others for correcting you here...You're understanding isn't quite correct. You need some flow, but it's total volumetric magnitude isn't important. It's speed is. This is governed exclusively by suction. Science in lecture. Large airflows are bad because they reduce suction, the speed of the flow, and therefore cleaning performance. Large airflows occur on low resistance flooring (rugs) so can't be avoided. High large air power is required to sustain suction in the presence of large air current to maintain the air speed. Again, see lecture.
So much incorrect here... Head suction pressure: In theory you could have zero head pressure (a complete vacuum) with zero air speed, if the "orifice" is closed, or in vacuum cleaner lingo, the cleaner head is "clamped" allowing no air movement. In those conditions there is zero air speed/velocity.This is not always true. I recommend you understand the science better. Head suction pressure determines cleaning performance (or at least is the primary aerodynamic factor—the rest are also discussed). Head pressure varies based on the air resistance from the flooring and the resulting magnitude of air current. More air power is needed in response to situations where large air currents are present in low resistance situations.
There's enough here for my target audience to see this is a dead end. It's not in anyone's interest to continue.
I am sorry but you always seem to be going against the grain and being very hypocritical. Like, for example, when you complained that in my explanation of my testing methods that I said "spread evenly" then I explained exactly what I meant then you linked back to the same earlier comment. Then I point out that you said "spread evenly" in your " full and thorough explanation of testing procedure" within your review videos. Very hypocritical.
@Vacuum Facts I had to correct the AI multiple times, while at the same time I also had to teach the AI to understand the science and everything. So far I've come up with this corrected set from Google Gemini 2.5 Pro (with human intervention this time), which came up with this possible take:
- Possible issue: How the V16 connects to the dual-cones floorhead used to test deep cleaning. The data pin(s) may be the problem.
- Possible fix: Block the ID connection (by using a small non-conductive tape) but keep the power. The machine would treat it as a typical powered tool instead of the specialized one that the floorhead has been designed as.
Google Gemini 2.5 Pro but corrected by human intervention said:The modification is to block the data communication pins between the wand and the main body, while still allowing the power pins to connect.
- The Method: The connector between the wand and the V16 body has large pins for power (to drive the head's motor) and small pins for data (for identification). The fix is to use a small piece of non-conductive tape to cover only the small data pins.
- The Resulting "Fixed" State:
- The V16 body turns on.
- It sends power to the wand, and the Piston head's motor spins (it's receiving power).
- However, the V16 body's data request gets no reply (the pins are blocked).
- The firmware now faces an unhandled exception: It has a powered head (it can feel the electrical draw) but no ID.
- It does not default to the 458W Carpet limit (it doesn't see the Piston head).
- It does not default to the 725W Tool limit (it knows a powered head is attached, not a non-powered tool).
- With no specific "throttle" command to execute, the firmware defaults to its absolute maximum, uncapped hardware profile.
I'm not convinced you can be helped, but the information to help you is available already.I am sorry but you always seem to be going against the grain and being very hypocritical. Like, for example, when you complained that in my explanation of my testing methods that I said "spread evenly" then I explained exactly what I meant then you linked back to the same earlier comment. Then I point out that you said "spread evenly" in your " full and thorough explanation of testing procedure" within your review videos. Very hypocritical.
How dare you ask any questions to the one and only ultimate authority on all things vacuum. (sarcasm)I am sorry but you always seem to be going against the grain and being very hypocritical. Like, for example, when you complained that in my explanation of my testing methods that I said "spread evenly" then I explained exactly what I meant then you linked back to the same earlier comment. Then I point out that you said "spread evenly" in your " full and thorough explanation of testing procedure" within your review videos. Very hypocritical.
My Dyson is almost 2 years old. Still works perfectlyA centralvacuu isn't that much more expensive than a dson and you tend to use a Dyson for a year and then replace it.
I would love to see a DC01 work on American carpet, or even a Dyson Ball Animal Multi Floor (looks like an Animal 3 Extra, but it has the really cool telescope wand setup instead of the DC41 wand design). It would be interesting to see how they perform, just out of sheer curiosity.The first factual claim is that you have never lived in the US or Canada and have not seen our homes, our floor coverings or the dirt and pet hair we have to clean. As a result you have no way to accurately judge what we in the US and Canada need by way of a vacuum cleaner. You cannot create an accurate test if you don't know the environment to be simulated.
Third factual claim, North American 120 volt, Japanese 100 volt and rest of the world 220-240 volt Dysons for example have different motors from different manufacturers and perform differently. The test of a European Dyson is meaningless to someone in the US because the products are different.
Wouldn't the installation costs make a central vac more expensive? Plus, I'm sure trying to retrofit a central vac system into an older home would be a major pain in the ass.A centralvacuu isn't that much more expensive than a dson and you tend to use a Dyson for a year and then replace it.
ha, it's so obviously absurd that most of these comments can be ignored to avoid feeding the trolls. The problem with this place is it's full of bad actors that make untruthful claims they never back up with evidence whilst simultaneously denying and poo-pooing the evidence provided for them that conflicts with their wonky worldview. It's why it's generally dead, sadly.My Dyson is almost 2 years old. Still works perfectly
I'd love to see some strong evidence showing there's some difference between an "american" carpet (which has not been defined in a manner that commands any respect on here so far, naturally) and any other carpet, given that the range is so wide, regardless. It's so obviously a dumb and nonsensical label. Of course, the proponents of such silly terms will never provide any because they're too busy denying and smearing facts that are easily checkable.I would love to see a DC01 work on American carpet, or even a Dyson Ball Animal Multi Floor (looks like an Animal 3 Extra, but it has the really cool telescope wand setup instead of the DC41 wand design). It would be interesting to see how they perform, just out of sheer curiosity.
We have a DC33 and it works pretty good on US carpets, when the clutch/belt isn't worn out (like it is on ours right now) Hard to quantify objectively on "dirt removal" but it definitely outperforms (or did with a good belt/clutch) a V15 & a V7. The largest gripe I would have with it is the bulkiness of the head (can't get close to corners, under things, etc).I would love to see a DC01 work on American carpet, or even a Dyson Ball Animal Multi Floor (looks like an Animal 3 Extra, but it has the really cool telescope wand setup instead of the DC41 wand design). It would be interesting to see how they perform, just out of sheer curiosity.
Of course it would be. A simple fact check shows this. What's important going forward is you identify which sources spout nonsense of this nature so you know what to generally ignore on lack of credibility grounds. Don't let poor sources get away with nonsense and don't let them troll. Some are just beyond help, sadly.Wouldn't the installation costs make a central vac more expensive? Plus, I'm sure trying to retrofit a central vac system into an older home would be a major pain in the ass.
Here is an example of a typical carpet found in the USA ~13mm soft pile height, PET or Polyester, ~42oz weight. I think this example is pretty representative of "American" carpets. Note this specific example is problematic with a V15 in terms of "clamping" and brush roll stalling.I'd love to see some strong evidence showing there's some difference between an "american" carpet (which has not been defined in a matter that commands any respect on here so far, naturally) and any other carpet, given that the range is so wide, regardless. It's so obviously a dumb and nonsensical label. Of course, the proponents of such silly terms will never provide any because they're too busy denying and smearing facts that are easily checkable.
This was pathetically weak evidence attempting to formally and convincingly quantify any meaningful difference between an 'american' carpet and any other found elsewhere on the planet. I remain wholly unconvinced the term is anything other than an indicator of sources of nonsense.Here is an example of a typical carpet found in the USA ~13mm soft pile height, PET or Polyester, ~42oz weight. I think this example is pretty representative of "American" carpets. Note this specific example is problematic with a V15 in terms of "clamping" and brush roll stalling.
For a wider view on "typical" USA carpets, google can be your friend: https://www.homedepot.com/b/Floorin...o-0550-in/Indoor/N-5yc1vZarl0Z1z17lgmZ1z1wkrt
