Sean
Make sure when you go to the store, that you specifically get 3 in 1 "Special Blend for 1/4 hp Motors Or Larger" SAE 20 Motor Oil. The SKU on the barcode is 6153601045. The bottle is white & blue. This 3 in 1 oil is specially formulated for motors & bearings inside motors that will see heavy-duty usage, & unlike regular 3 in 1 oil, won't run dry as easily. They should both be right beside each other & cost the same.
