SO lucky, Tseg
I've heard those have really great reviews. It looks great ! Even has a folding handle.
Is there two separate water tanks? Are they both removable?
What about the brush action: does it go back and forth like a rug doctor's, or does it spin like most of Bissels carpet cleaners?
And is it easily removable?
This is what I'd probably get, if only I had more messiness.
I rented the Rug Doctor two weeks ago and as usual, it did a great job. One thing I've learned is to pretreat and not put much detergent in the machine itself and to go over it a second time with just water to rinse.
Just a suggestion for you, about that carpet just inside the back door: if it were me, I think I would get some used, or even cheap, new twin size bed sheets and use them as rugs/floor sheets. Something that can be changed daily. Then all the mess is on that which can be shaken out and laundered. It will save you a lot of hassle and you can have instant clean just by change the floor sheet.
Unlike rugs that may or may not be able to put in the washer, sheets can easily be washed in warm or hot water and dried in a normal drier. Can even bleach treat if need be, something you can't do with a rug. Also, rubber backed rugs shouldn't be put in a heated drier so floor sheets are more versatile.
Next time, take some pics. We'd love to see them.
