electrolux137
<div data-contents="true">
<div data-offset-key="266gq-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="266gq-0-0"><span data-offset-key="266gq-0-0"> </span></div>
</div>
<div data-offset-key="edmdu-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="edmdu-0-0"><span data-offset-key="edmdu-0-0"><span data-text="true">This is one I've never tried before. I adapted it from a recipe in Reminisce Magazine. The crust is light, fluffy and airy.</span></span></div>
</div>
<div data-offset-key="86iqt-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="86iqt-0-0"><span data-offset-key="86iqt-0-0"> </span></div>
</div>
<div data-offset-key="6ogjk-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="6ogjk-0-0"><span data-offset-key="6ogjk-0-0"><span data-text="true">FLUFFY PEACH COBBLER</span></span></div>
</div>
<div data-offset-key="10at-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="10at-0-0"><span data-offset-key="10at-0-0"> </span></div>
</div>
<div data-offset-key="29g1o-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="29g1o-0-0"><span data-offset-key="29g1o-0-0"><span data-text="true">THE COBBLER</span></span></div>
</div>
<div data-offset-key="fn3r7-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="fn3r7-0-0"><span data-offset-key="fn3r7-0-0"><span data-text="true">3 large eggs</span></span></div>
</div>
<div data-offset-key="4b178-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="4b178-0-0"><span data-offset-key="4b178-0-0"><span data-text="true">2/3 cup milk</span></span></div>
</div>
<div data-offset-key="f9ah-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="f9ah-0-0"><span data-offset-key="f9ah-0-0"><span data-text="true">1½ cups sugar</span></span></div>
</div>
<div data-offset-key="aqgvt-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="aqgvt-0-0"><span data-offset-key="aqgvt-0-0"><span data-text="true">¼ tsp salt</span></span></div>
</div>
<div data-offset-key="69ra9-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="69ra9-0-0"><span data-offset-key="69ra9-0-0"><span data-text="true">3 tbsps melted butter</span></span></div>
</div>
<div data-offset-key="chnmu-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="chnmu-0-0"><span data-offset-key="chnmu-0-0"><span data-text="true">1 tsp vanilla extract</span></span></div>
</div>
<div data-offset-key="f8see-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="f8see-0-0"><span data-offset-key="f8see-0-0"><span data-text="true">½ tsp cinnamon</span></span></div>
</div>
<div data-offset-key="14ir7-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="14ir7-0-0"><span data-offset-key="14ir7-0-0"><span data-text="true">5 cups fresh peaches, pitted and cut into one-inch chunks (do not peel)</span></span></div>
</div>
<div data-offset-key="9tdih-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="9tdih-0-0"><span data-offset-key="9tdih-0-0"> </span></div>
</div>
<div data-offset-key="223ql-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="223ql-0-0"><span data-offset-key="223ql-0-0"><span data-text="true">Preheat oven to 350 degrees F.</span></span></div>
</div>
<div data-offset-key="483qo-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="483qo-0-0"><span data-offset-key="483qo-0-0"> </span></div>
</div>
<div data-offset-key="bttml-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="bttml-0-0"><span data-offset-key="bttml-0-0"><span data-text="true">Beat the eggs in a large electric mixing bowl. </span></span></div>
</div>
<div data-offset-key="9jd2e-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="9jd2e-0-0"><span data-offset-key="9jd2e-0-0"> </span></div>
</div>
<div data-offset-key="5jb6a-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="5jb6a-0-0"><span data-offset-key="5jb6a-0-0"><span data-text="true">Add milk, sugar, salt, melted butter, vanilla and cinnamon. Mix well.</span></span></div>
</div>
<div data-offset-key="10uo7-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="10uo7-0-0"><span data-offset-key="10uo7-0-0"> </span></div>
</div>
<div data-offset-key="dbdnj-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="dbdnj-0-0"><span data-offset-key="dbdnj-0-0"><span data-text="true">Add chopped peaches and blend, then pour into a liberally buttered 9x13 baking dish. </span></span></div>
</div>
<div data-offset-key="ded5d-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="ded5d-0-0"><span data-offset-key="ded5d-0-0"> </span></div>
</div>
<div data-offset-key="e2r74-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="e2r74-0-0"><span data-offset-key="e2r74-0-0"><span data-text="true">THE CRUST</span></span></div>
</div>
<div data-offset-key="6ieuk-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="6ieuk-0-0"><span data-offset-key="6ieuk-0-0"><span data-text="true">2 cups flour</span></span></div>
</div>
<div data-offset-key="f6cqt-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="f6cqt-0-0"><span data-offset-key="f6cqt-0-0"><span data-text="true">4 tbsp sugar</span></span></div>
</div>
<div data-offset-key="72as2-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="72as2-0-0"><span data-offset-key="72as2-0-0"><span data-text="true">3 tsp baking powder</span></span></div>
</div>
<div data-offset-key="91nde-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="91nde-0-0"><span data-offset-key="91nde-0-0"><span data-text="true">1 tsp salt</span></span></div>
</div>
<div data-offset-key="4h1t6-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="4h1t6-0-0"><span data-offset-key="4h1t6-0-0"><span data-text="true">1 tsp cinnamon</span></span></div>
</div>
<div data-offset-key="eq8o9-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="eq8o9-0-0"><span data-offset-key="eq8o9-0-0"><span data-text="true">2 cups milk</span></span></div>
</div>
<div data-offset-key="caf1b-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="caf1b-0-0"><span data-offset-key="caf1b-0-0"><span data-text="true">3 tbsp melted butter</span></span></div>
</div>
<div data-offset-key="fmcrl-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="fmcrl-0-0"><span data-offset-key="fmcrl-0-0"><span data-text="true">1 teaspoon vanilla extract</span></span></div>
</div>
<div data-offset-key="4bojr-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="4bojr-0-0"><span data-offset-key="4bojr-0-0"> </span></div>
</div>
<div data-offset-key="23tvu-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="23tvu-0-0"><span data-offset-key="23tvu-0-0"><span data-text="true">Sift flour into a large mixing bowl. Add the other dry ingredients and blend.</span></span></div>
</div>
<div data-offset-key="fsg8m-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="fsg8m-0-0"><span data-offset-key="fsg8m-0-0"> </span></div>
</div>
<div data-offset-key="6rdbj-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="6rdbj-0-0"><span data-offset-key="6rdbj-0-0"><span data-text="true">Add in the liquid ingredients and mix until thoroughly combined (but don’t over-mix).</span></span></div>
</div>
<div data-offset-key="9biqh-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="9biqh-0-0"><span data-offset-key="9biqh-0-0"> </span></div>
</div>
<div data-offset-key="78l4g-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="78l4g-0-0"><span data-offset-key="78l4g-0-0"><span data-text="true">Pour the crust batter evenly over the peach mixture.</span></span></div>
</div>
<div data-offset-key="1ev1j-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="1ev1j-0-0"><span data-offset-key="1ev1j-0-0"> </span></div>
</div>
<div data-offset-key="d4kgv-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="d4kgv-0-0"><span data-offset-key="d4kgv-0-0"><span data-text="true">Bake for 45-50 minutes or until crust is golden brown.</span></span></div>
</div>
<div data-offset-key="h4cb-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="h4cb-0-0"><span data-offset-key="h4cb-0-0"> </span></div>
</div>
<div data-offset-key="4lb62-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="4lb62-0-0"><span data-offset-key="4lb62-0-0"><span data-text="true">When done, remove from oven and cool for 20-25 minutes.</span></span></div>
</div>
<div data-offset-key="k0d9-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="k0d9-0-0"><span data-offset-key="k0d9-0-0"> </span></div>
</div>
<div data-offset-key="5337t-0-0" data-editor="35ra" data-block="true">
<div class="_1mf _1mj" data-offset-key="5337t-0-0"><span data-offset-key="5337t-0-0"><span data-text="true">Serve with vanilla ice cream or fresh whipped cream.</span></span></div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
