MORE STUFF TO GO...
electrolux137
Bronze Member
Los Angeles
<div data-contents="true">
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="bkm18-0-0">
<div class="_1mf _1mj" data-offset-key="bkm18-0-0"><span data-offset-key="bkm18-0-0"><span data-text="true">I've been doing more cleaning and clearing and have a bunch more vacuum cleaners to go to new homes at no cost. The only stipulation is that you -- or someone on your behalf -- can come get them. Sorry, but that's the way it has to be.</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="1ps8e-0-0">
<div class="_1mf _1mj" data-offset-key="1ps8e-0-0"><span data-offset-key="1ps8e-0-0"> </span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="79m18-0-0">
<div class="_1mf _1mj" data-offset-key="79m18-0-0"><span data-offset-key="79m18-0-0"><span data-text="true">ELECTROLUX</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="3rkuc-0-0">
<div class="_1mf _1mj" data-offset-key="3rkuc-0-0"><span data-offset-key="3rkuc-0-0"><span data-text="true">1205</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="1eumm-0-0">
<div class="_1mf _1mj" data-offset-key="1eumm-0-0"><span data-offset-key="1eumm-0-0"><span data-text="true">1954 XXX</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="8m040-0-0">
<div class="_1mf _1mj" data-offset-key="8m040-0-0"><span data-offset-key="8m040-0-0"><span data-text="true">LXI (rare, note flip-open cord winder)</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="mvg6-0-0">
<div class="_1mf _1mj" data-offset-key="mvg6-0-0"><span data-offset-key="mvg6-0-0"><span data-text="true">E</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="4i1o8-0-0">
<div class="_1mf _1mj" data-offset-key="4i1o8-0-0"><span data-offset-key="4i1o8-0-0"><span data-text="true">XXX</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="5jp2m-0-0">
<div class="_1mf _1mj" data-offset-key="5jp2m-0-0"><span data-offset-key="5jp2m-0-0"><span data-text="true">Grand Marquis</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="3qvkr-0-0">
<div class="_1mf _1mj" data-offset-key="3qvkr-0-0"><span data-offset-key="3qvkr-0-0"><span data-text="true">G</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="77ssf-0-0">
<div class="_1mf _1mj" data-offset-key="77ssf-0-0"><span data-offset-key="77ssf-0-0"><span data-text="true">T (rare)</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="beaa-0-0">
<div class="_1mf _1mj" data-offset-key="beaa-0-0"><span data-offset-key="beaa-0-0"><span data-text="true">Two factory-rebuilt Gs</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="b8t53-0-0">
<div class="_1mf _1mj" data-offset-key="b8t53-0-0"><span data-offset-key="b8t53-0-0"><span data-text="true">Canadian ZB89 w power nozzle & three hoses</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="bkglq-0-0">
<div class="_1mf _1mj" data-offset-key="bkglq-0-0"><span data-offset-key="bkglq-0-0"><span data-text="true">White L</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="anc97-0-0">
<div class="_1mf _1mj" data-offset-key="anc97-0-0"><span data-offset-key="anc97-0-0"><span data-text="true">F (missing switch cover; broken rear wheels)</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="1k569-0-0">
<div class="_1mf _1mj" data-offset-key="1k569-0-0"><span data-offset-key="1k569-0-0"> </span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="2njdp-0-0">
<div class="_1mf _1mj" data-offset-key="2njdp-0-0"><span data-offset-key="2njdp-0-0"><span data-text="true">Two Hoover 'coffee can' models - I have bags for both</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="84bi7-0-0">
<div class="_1mf _1mj" data-offset-key="84bi7-0-0"><span data-offset-key="84bi7-0-0"><span data-text="true">Box of misc Hoover stuff incl many brush strips</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="175k0-0-0">
<div class="_1mf _1mj" data-offset-key="175k0-0-0"><span data-offset-key="175k0-0-0"><span data-text="true">Two Hoover 28 bags, great condition</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="a1mfk-0-0">
<div class="_1mf _1mj" data-offset-key="a1mfk-0-0"><span data-offset-key="a1mfk-0-0"><span data-text="true">Regina hand-pumped</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="5b3sd" data-offset-key="6147c-0-0">
<div class="_1mf _1mj" data-offset-key="6147c-0-0"><span data-offset-key="6147c-0-0"><span data-text="true">Franklin Supreme</span></span></div>
</div>
</div>
Good Evening, I'm trying to restore my 94 year old mothers Electrolux model AF and in need of some parts for the pm-1 power nozzle. I see that you have one pictured, would you be willing to sell the one that you have pictured? I would pay you in advance for the power nozzle and shipping charges. Thanks for your time. Dave
