<div data-contents="true">
<div class="x1e56ztr" data-block="true" data-editor="ds6pe" data-offset-key="5hste-0-0">
<div class="_1mf _1mj" data-offset-key="5hste-0-0"><span data-offset-key="5hste-0-0"><span data-text="true">This past weekend I met a man whose grandfather worked for Electrolux for many years. He bought a box-full of memorabilia for me to look at. </span></span></div>
<div class="_1mf _1mj" data-offset-key="5hste-0-0"> </div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="ds6pe" data-offset-key="f5v4v-0-0">
<div class="_1mf _1mj" data-offset-key="f5v4v-0-0"><span data-offset-key="f5v4v-0-0"><span data-text="true">One thing that stood out was this page from a 1941 issue of Electrolux News, clearing at least partly the mystery of the Model XX. </span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="ds6pe" data-offset-key="eufsk-0-0">
<div class="_1mf _1mj" data-offset-key="eufsk-0-0"> </div>
<div class="_1mf _1mj" data-offset-key="eufsk-0-0"><span data-offset-key="eufsk-0-0"><span data-text="true">It was intended to be a lower-tier companion to the Model XXX and also to serve as a "bait and switch" to compel people who wanted a Model XX to spend more for the deluxe Model XXX.</span></span></div>
<div class="_1mf _1mj" data-offset-key="eufsk-0-0"><span data-offset-key="eufsk-0-0"><span data-text="true">(I'm sorry the scan is so lousy -- apparently the Vacuumland website down-samples images. The original is much clearer.)</span></span></div>
</div>
</div>
