What was Your Worst Vacuum Experience?
I can honestly say I have never had a bad vacuum experience. Then I knew from a very early age that vacuums were my friends.
Now my Aunt on the other hand has taken three falls over the hose of her central vac resulting in a broken arm on all occasions. My Uncle bought her a Hoover Windtunnel, harder to trip over or get your feet tangled up in a upright.
I had a Bissel DigiPro canister and it was horrible. The 'Intelligent Suction Contro' didn't recognize dirt half the time on my darker carpets, and it was extremley noisy. I now have an Oreck Graphite, and while it's noisy too, it does a much better job. I couldn't have been happier - and it's made in the USA.
Worst vac for me--A Premeir made Master craft upright vacuum sold from a Janitorial supplier sometime in the 70's-ordered it for a radio station.Its duty was at the manned transmitter site-the place had indoor-outdoor carpet.At transmitter sites vacuums have to contend with screws and other peices of hardware.A Sears Kenmore canister was its companion-it vacuumed out the transmitters.That Premeir was horrible-the plastic base cracked twice,the fan broke twice as well-and a STEEL fan at that.Finally the Mastercrafts motor died-and it met a crushing death in the neighberhoods Ez-Pak trash truck.Crunched it to plastic bits.Replaced it with a commerical Royal-Much better!Then the Sears vac died-liked that little thing-worked good.Replaced it with an NSS M1 vacuum.Somewhere around I have the bag for the Mastercraft-still packed somewhere.Was black-and could use F&G type bags.
Worst experience
In the mid 80's I had some sort of nasty K-mart purchased canister. I can't remember if it was a cheap Hoover or a Bissell. However, it was a nice spring day, and I decided to vacuum out the winter grunge from the car.
I had it outside, on a rubber mat, plugged into a GFI outlet, and was merrily "vacuuming" away (actually, it got the grit, but I had to stuff the fluff into the nozzle for it to suction it,) when the machine stopped working. I got out of the car to investigate, and noticed my neighbor shouting and madly gesturing from her window: The cord had shorted out at the junction to the machine, and a small fire had started!
I managed to extinguish the fire with an old blanket from the trunk, and was going to throw the whole works into the trash, when Mr. Cheapskate (my husband) insisted on tearing down the machine and fixing it, even though my plan was to just go buy another cheap machine to replace it until I could afford a decent machine.
That took him four weeks, and plenty of nagging, to do. I had the piece of junk for another four years.
When our dog yakked on the carpet and I "dry-cleaned" the carpet it obviously developed nasty odors. The canister seal had long since dried up, and you could see puffs of dust when you used the machine. I'd like to say "vacuum," but it wasn't doing much of that: I still had to stuff dust bunnies into the wand tubes.
I was on the verge of moving home with mother unless we got something that actually worked, and told him to go ahead and live in the detritus of daily living if it didn't bother him. He finally capitulated and bought me a Fantom Fury as a replacement.
It was an improvement, but nothing special. It bit the dust after about three years. And I didn't like having to empty the dust cup. Unfortunately, it bit the dust on a Sunday, the only place that was open was a WalMart, and I ended up with a Bissell power force upright for $40. Even that cheap machine did a better job than the Fury, with the advantage that I didn't have to dump the dust cup.
I still have the Bissell (Mr. Cheapskate can't bear to toss anything that still remotely accomplishes its function,) but after slipping a disc and needing surgery, I was able to loudly proclaim that, according to the neurosurgeon, vacuuming was one of the most dangerous things I could do to my injured back, unless I got a very lightweight upright that I could use without twisting, horsing it around, or having to bend over to operate (or stuff dust bunnies into the tube.)
That's how I ended up with my new Riccar RS4. For the first time in my life, I actually like to vacuum. And even Mr. Cheapskate commented how it has made a noticeable difference in how the old wall-to-wall carpet looks.
Really???
A Fantom did that? I LOVE Fantoms and have never had that problem with my Fury. And yeah the K-mart bissell canisters are terrible cleaners filter wise. Becuase the bagless ones filters get so clogged that airflow is terrible.
My worst experience
We had a Kenmore Progressive canister (white casing) and the power nozzle height pedal broke the first time that I used it. The internal mechanism broke in the PN. We replaced it with an Electrolux Nimble for 6 months, never had a problem with it.
As far as I know that model is made by Panasonic, normally a very reliable brand but when you build a machine down to a price you have to cut corners somewhere.
I have three good ones. I have only had a handful of vacs die while in use. The first was a Dirt Devil newer style vision of some type a neighbor gave me. I knew the motor was on its way out, but I used it once and the next time I turned it on and within 10 seconds got a couple big arcs from the motor and it went up in smoke. Another is this little Eureka mighty might I have. Aparently the bag wasn't trapping dust too well, and the motor sucked up a lot of fine dust, which in turn caked up on the carbons and caused it to loose almost all power within a couple minutes. It took me a minute or two to realize there was something wrong with the machine. Cleaned the motor out, put a better filter and bag in it and works fine now. Last one was with a shop vac brand shop vac. I was working with a friend and he was vacuuming up some dust and that drop ceiling material that falls apart all the time. Well we both had our backs to the shop vac. Well, everything it picked up went right out the exhaust and nearly sprayed the whole building with fine dust because the filter fell off. Needless to say my friend is just too cheap to buy a $15 filter. Also some how snapped a blade off a Eureka fan once just cleaning out a furnace air filter.
Wow
Those Eurekas like the mighty mite are decent but not a good seller in my town. We had 2 of them sit at Walmart here and they didn't leave for months and months. Then I went to buy one and of course then they are gone! But just recently I was using a Ultra Super Shark on the shoulder vac. After about 3 minutes into vacuuming the strap broke off and it fell to the floor.
Bissell "Zing" ! I don't know what I was thinking buying it, but it was £19.99 in Tesco and I thought well it's very small I could just use it for the cars. It was so noisey my ears hurt, the filteration was terriable there was a coating of dust on the exhaust grill despite the air passing through three filters. Tried using it in the house but the plastic tubes would bend so much on carpet I expected them to snap, it was thrown away soon after.
The Vax Widetrack V0-45
I bought this one many years ago for £39-99 online for a friend who had just got a dog. The machine worked well for the first couple of months then she brought it back to me saying that she had followed the user manual and "cleaned" the filters. So I looked at the Vax and discovered that whilst she had cleaned the outer mesh filter, the paper cone filter was completely caked in dog and dust. This is when I got covered in dust from head to toe cleaning all the dust off.
After cleaning it off with another vacuum cleaner and then washing the filter and waiting to dry, I put a new fresh filter in and the Vax still wasn't working. This was because the main central telescopic suction tube that also acts as the main spine of the upright was completely clogged up with dog hair, biscuits, cat hair and cat litter all jammed up. Took about five attempts to knock it all out and thus also got covered in pongy pet hair. I Have to say then, it was probably one of the worst experiences of my life!! Thereafter the upright worked but then a year later, bits of plastic started to fall off it.
I think the U.S have had this upright as a Shark/Euro-Pro. Aside from the filter design, it is one of the worst uprights I've ever used as it is very heavy, has cheap plastics and quite noisy.
Bissell Zing
<span style="font-size: large;">I had a bagged Bissell Zing for a while but I returned it due to the fact that I just didnt like it much. The reason being is that the tubes are way to cheap like you mentioned. Also, the bags were terribly made and even with the other filter within a few hours the filter was already getting pretty dirty. I did not find it very noisy though. However, I returned it the same day.</span>
Ryan
Yes, you are correct about that bagless upright being sold under the Shark/Euro Pro names. They also sold it under the name "Fantom Power Pet" at Zellers stores here in Canada. Oh, what a disgrace to the Fantom name this vacuum was!!
I've had a few....
Bissell PowerForce bagless and Kenmore bagless canister. Filters clog and suction is gone in minutes of cleaning...I also had a Dyson DC14 for six years that was great for tool use and cleaning hard floors, but it was awful for carpet!
Bissell and Kenmore
<span style="font-size: large; font-family: 'arial black', 'avant garde';">Well a Bissell Powerforce is not going to be the best cleaner. And the Kenmore Bagless wasnt too bad of a vac. I have one and used to use it a lot until I got a Kenmore Lime Green canister to replace it.</span>
Some years ago I was doing some prototype testing on a new Motor to be fitted to a Shopvac style vacuum cleaner. We had about 10 prototypes running in various stages of assembly. We were having some trouble with Motor failure when one of the half bodied units exploded sending bits of motor everywhere. The cooling fan shot off and hit me in the head making some nasty cuts.
It was later found that the batch of sample motors sent out by the manufacturer had a faulty brush mount causing the ruptures. Just one of the many reasons that prototypes are tested so vigorously.
