What do you use as a bench vac?
niclonnic
Platinum Member
Bonney Lake, WA
Here's a curious subject that I've been casually meaning to post about for some time. What is the one vacuum that you use as a "bench vac" to clean out other vacuums with?
Lately, I've been using a Craftsman Clean n Carry 2-gallon shop vac for this very purpose. Owned by my stepmom, it has been nothing but a workhorse. This machine has been serving me well as a bench vac to vacuum off bagless bins and filters with. However, the filter is very messy to clean off afterwards, sending this dust flying all over the place. Since this shop vac can't use disposable bags, it sort of defeats the purpose, despite the fact that I only empty it in the garage.
Because of this messy emptying process, I keep thinking about buying a Eureka Mighty Mite. Since it's a bagged canister, there are no cyclones or filters to get plugged up with dust from other machines. I can simply throw the bag away after it gets full. Although the Mighty Mite sounds like the perfect bench vac for me, I kind of don't want to introduce another vacuum into my household, due to a rule in which I can't hoard vacuums.
I'd love to hear what you prefer to use as a bench vac.
    4.6 MB
A central vac, or whatever bagged canister with decent suction is closest. When I have a proper bench setup, which I do not, as from 2006-2021 I worked in a vac shop and would just go in an hour or so early, or on a slow day just work on/clean up one of my vacuums. Could use a bag from the open packs for free, or buy a pack and the belt for wholesale if needed. So I never bothered setting up a bench at home. Now I don't really use a bench for work, unless a folding table at the job counts, so I'm missing that badly.
At home, usually my Shop Vac. Sometimes I'd go over to a local car wash and use one of theirs to clean out my vacuums if I'm already headed for that direction anyways. At the first vacuum shop I worked at, I used an MD Silent Master that was custom where I'd turn on the switch from my bench instead of reaching down to turn the unit on. And then at the others, I used canisters either a Filter Queen or a Tristar that were also custom where I'd turn on the switch from my bench.
Yeah that's another easier way to do. I remember the hose on the MD wasn't an actual central vac hose, whether it looked like a Panasonic Jet-Flo upright hose already plugged in the inlet on the bottom and the central vac unit itself wasn't really mounted but sat on the end of the bench like a trash can. I can't remember, it's been so long when I worked there and that shop has since closed down.
I have used the Shop Vac I use in my car, but it doesn’t filter well. I then used an old hose on my Electrolux Olympia. If it’s minor amounts of dirt, I’ll use my cordless Metro Vac. Usually I use a Dc07 as my bench vac, mainly for convenience. I just plug the DC07 in and uncover the end of the wand, I’ll attach the crevice tool to the end for bags and fabric. If I’m just servicing one of my main vacs that get used to clean the house, I’ll use my D4. I’ve tried my V8, but it never has enough suction and it’ll aggravate me.
I just finished some projects this morning.
I use my 1982 Electrolux D338 with its NZ specific shakeout bag. That also has a blower, I use it with a crevice tool on the blower when I need an air compressor. I just empty the bag and shake it outside. There is a little handle on the end of the bag for when it is inside out. Just have to watch the wind direction. I sometimes use my Tineco stick vac with either the little motorised upholstery tool or the crevice tool, on filters that are very small or light.
I use this Model G for vacuuming vacuums. It's had the hose chopped short since this photo due to damaged ends, and someone custom painted it. Got it from Seattle when I first started collecting vacuums. The horsehair brush is good to get into crevices and loosen dirt and I also use a compressed air gun in tandem with the vacuum to get other debris out.
Pretty much I use my daily drivers as my bench vacs. At the moment those are my Kirby G7 and my Dirt Devil Breeze bagless. As long as a machine filters well and can preferably use 1 1/4 in. Attachments, then I'd use it. Though, as of recent I'm moving towards using this Eureka Toolbox vac for that job, as it's 10x more practical. I just hope that I can get it some HEPA bags (much to Huskyvac's dismay). I also have a 4 gallon Shop Vac while I primarily got for miscellaneous workbench clean-up/wet pick-up jobs, could also be used for cleaning out other machines if I needed to.20260107_214226.jpg20260107_214226.jpg20250120_212512.jpg
Rugsucker would approve !
The value of using a central vacuum, as stated very early in this thread would be that it already has a built-in low-voltage activation system. With a simple low voltage wire and almost any switch, you could activate it from the bench-top. (And you have the advantage of removing the noise from the work area.) I've heard quite a few guys using a WallyFlex or VacPan type device for quick cleaning. Also using gate-valve similar to what's used on an RV waste system is really handy so that the suction can be isolated and the suction can be used elsewhere.
I use a Proteam tailvac as the bench vac and I also use a Metropolitan omnivac as a blower. 6 qt capacity with decent power for the tailvac,
    412.9 KB
Not all vac shops have a space one can remotely mount a machine, where I worked for years we did, and there was only one bench for vacuums, so one inlet. Worked well to just leave the low voltage hose plugged in and just have a switch handy when you grab the hose end.
If you can not have a central vacuum, a lot of people forget or do not even know this exists. It's a good alternative. The hose is something like 20 or 30 feet. If remote operation is needed just leave it in the on position and then hook it up to a remote controlled socket dongle.
"--Model G--" I use 3 in different areas but have an Olympia under the bench as I can step on the front mounted on/off switch. All use the same 4ply self sealing bag that can be changed in 3 seconds. Years ago I was in an older vac store that used a GE RollEasy as a bench vac.
I use whatever tank or canister vac that's handy at the time I need it. I do have a GE Swiveltop VIIC3 under my workbench, but sometimes something else is closer at hand. Interestingly, when I was selling Electro-Hygienes in the 70's, we had the same model under the bench in the service department! here's a pic of it, and yes, it has been cleaned up and the hose has been repaired since this pic was taken.
We bought a Walmart wet dry vacuum, one of the 3 gallon Hyper Tough models. It's cheap and flimsy but with the disposable bag it's my go to for cleaning just about everything up 😂 I'm not disappointed with it at all
Out of curiosity, is there a way to convert my Craftsman to use disposable bags? The hose attaches to the motor cover, so there is no intake pipe. Is there some kind of adapter that I can buy to accomodate said bags? I've tried searching all over the Internet, but can't find anything worthwhile.
    1.5 MB
    1.9 MB
I usually use one of my Miele canister vacuums. Since there is a lot of fine dusty dirt when servicing vacuums, that works best for me as the Original Miele bags don't allow the vacuum to lose it's airflow and suction easily. However, when I need a vacuum with a pistol grip hose, then I reach for one of my Electroluxes.
