Twin Fan Uprights - physics question for engineers out there
eurekaprince
Bronze Member
Montreal, Canada
In the 1950’s, Singer came out with their sleek revolutionary upright that offered a sideways-positioned motor with a fan on each side. This “twin-fan” upright design survived well into the 1970’s in the form of upright vacuums branded as Singer, Kenmore, Lewyt and Sunbeam. But these uprights never seemed to top Consumer Reports ratings for deep carpet cleaning….they were always outperformed by competitors’ uprights created by Eureka, Hoover and Panasonic.
Which brings me to a bit of a science question maybe someone could answer: is it possible that having two fans each creating a suction pull on each side of the brush chamber is actually counter-productive? In other words: is it possible that this design actually creates less effective air flow in the brush roll chamber because each fan is trying to pull air away from the other fan - thereby negating the suction pull on each side?
Thoughts?
Thoughts?
I suspect that other aspects of the vacuum's design led to it being less competitive. Without reading the tests however I can only speculate. Panasonic would be a clean air model with a higher amp motor than those old Singer's used and because it is clean air it would have more suction. Hoovers had especially aggressive brush rolls. Tacony makes a modern twin fan model of their own sold under the Carpet Pro brand name that I have been tempted to buy.
Thoughts?
Off the top of my head, I know that the Singer Magic Carpet series has a floating brushroll that doesn't make contact with the carpet super well, so that may put it at a disadvantage.
I feel like the air in a twin fan setup is more likely to take the path of least resistance through the nozzle rather than pull against the other motor, but I am not 100 percent sure.
I don't really know the physics behind it but I've tested at least 2 vacuum with a twin fan setup, that singer as seen above and a piranha upright which was made by tornado, based off of the bissell prolite design.
Usually in parallel settings the flow is boosted but this is a unique case where we have parallel airflow sources powered by one motor meaning that motor is getting all of the resistance in addition to that they also funnel all of the air into a single channel.
It's been my experience so far that there's not too significant a benefit to this design IF there even is one. The Singer I tested scored below many direct air single fan machines like the hoover convertible or Eurekas, The piranha though did slightly better than most if not all of the other lightweight direct air machines I've tested so far but only by about 5-6 cfm
The design *may* lead to better distribution of the airflow across the nozzle but that's speculation.
I'm not sure I'd say it's counter productive fluid will follow the path of least resistance and being powered by the same motor their suction should be equal I will say it definitely seems less efficient than just having one larger fan and a single airpath.
On that note, maybe I'll run my Power-Flite wide thing and see. To me it seems similar in airflow to something like a Sanitaire that uses one large fan. I always thought the height adjustment and to a degree the bottom plate design could have been better, and slowed for better use of the airflow it does have.
Pretty sure the Bissell Prolite is a Tacony product. Carpet Pro, Tornado and other Tacony brands have their own versions.
It wasn't when it was a Bissell. Tacony and Bissell traded intellectual property a while ago. Tacony used to use the name "Healthy Home" on the bags for Simplicity vacuums and EcoPure on the Riccar ones. For whatever reason, Bissell was dead set on using the name Healthy Home on their new bagless machine at the time, and Tacony had the issue that the SupraLite, which was originally developed by and for Powr-Flite so they could retire the old Singer twin fan style machine they had been selling to compete with Orecks for light weight commercial machines, had been taken over by Riccar and Simplicity, and dealers were feeling they had the right to tell Tacony to not let Powr-Flite sell it, or at least not at the price they were. Ultimately, Bissell traded the Prolite's manufacturing rights, molds and design for the name Healthy Home.
I had no idea any of that happened.
I have always thought the twin fan was a great design in that you have even suction across the entire width of the nozzle but in the case of most Singers poorly executed. If you look at the S3 that thing is all metal and exquisitely well made. The materials and machining are really eye popping, better than a lot of car engines from that era. Compared to 1980s Hoover uprights the Singers didn't have much power, only 6 point something amps where Hoover Elite variants were 7-12 amps depending on the model so naturally they made the Singers look kind of weak.
