Turbopower Boost U2716
beko1987
Stokenchurch, United Kingdom
This jumped to the top of the pile recently, I tripped over it once too many times in the garage, so bought it home last week. It's creaking alot, so I thought a strip-down and clean was in order.
From Boost
From Boost
The remains of a bojack air freshener!
From Boost
Removed the bag door
From Boost
From Boost
Sadly the bag door is going the way of all the boosts I've ever had. Have one or two pieces of it though, will repair as best I can
From Boost
From Boost
Stripped out the rest of the bag compartment
From Boost
From Boost
From Boost
Wires next
From Boost
From Boost
From Boost
Then the tool holder. Tried to get the hose holder off, but the bottom screw rounded off on me, so had to leave it on
I have the missing piece, another bit to glue
From Boost
Fading much?
From Boost
From Boost
Moving down
From Boost
baseplate
From Boost
How the plastics should look, un-faded
From Boost
From Boost
This has had a Hoover Repair at some point (sticker on the handle), so that must be when they siliconed the fan case. It's something I always do, but never see on an un-touched cleaner
Belt guard
From Boost
From Boost
From Boost
From Boost
From Boost
Could finally get the wires out the way
From Boost
and pull the heart out
From Boost
Front room looked ok I thought (SWMBO was at work!)
Every screw
From Boost
The boost has a lean, but the brace looks ok. I have the one from my parts vac which stood up fine though, may compare and see if it helps
From Boost
Then it all got washed and put upstairs to dry. Just polished the hood, need to glaze and wax it next
From Boost
From Boost
From Boost
Will update when I next do anything. Going to try and get the motor sorted tomorrow night, so I can take it over to my mums and re silicone it together, and find a large cable-tie!
Hi Mr
Hi, Nice Hoover Boost. I use to have two of these but I got rid of them a year or two ago as they was in poor condition. Well....really yellow. I could not of put them on display in my museum so they went when I moved nearly 2 years ago now.
My how time flies:o)
Look forward to seeing more pictures:o)
James:o)
Cleaned the motor
tonight.
From Boost
From Boost
Fan looks clean considering
From Boost
From Boost
From Boost
Mean anything to anyone?
From Boost
From Boost
From Boost
From Boost
Slightly worrying. Think I have a spare set with more meat left in the garage, or I'll just put these back in, since it won't be used much
From Boost
Washed the plastics up after doing the washing up
From Boost
Gave the chassis and back a good polish, got rid of all the marks and scuffs. Shame about the fading though
From Boost
However, in the right light it looks good
From Boost
So, need to find spare carbon brushes, hinge pivot thing and maybe swap the brushroll to my better spare. Then just re-assembly and she will be good as new!
You have done wonders there sam! I may have to pay you to give some of mine your magic touch ;-) I cleaned the dirt searcher up today and after about four hours she came up a treat but my god the rubber handle grip was a challenge but worth it in the end. I always find it a shame with turbopowers re the weak plastics..That is my only gripe with them and other than that i think they are amazing. I have a boost also.Has some cracking but works ok. Yours is much nicer tho.
You would be surprised how easy it is to strip them down and clean them up. I would be happy to do one for you, but I think you should get hold of any old vac and give it a go! Just note all wiring, label all screws (I punched a hole in one years ago by using the wrong length screw)
I wouldn't get started on your turbomastrer though, find a scrapper somewhere!
Back together last nigh. Not many pictures, but
From Boost
From Boost
Cable ties were 50p from the carboot, perfect size for bellows!
From Boost
And the damage, crack in the handle, goes right through but doesnt flex in use. Covered in glue from the inside which soaked through
From Boost
The base of the back is going in the corners. Glued and re-inforced from the inside, hidden by other parts
And the afters
From Boost
From Boost
From Boost
nasty one on the base, re-inforced and solid again
From Boost
bad repair to the front of the handle, but it works, so don't want to make it worse
From Boost
old service sticker
From Boost
From Boost
damage on the top of the bag door
From Boost
From Boost
And with my Autoflex Plus, the only other headlit TP I have that isn't in storage
From Boost
From Boost
Thinking of passing it on now, it doesn't really do anything for me, I feel no attachment. Will get a for sale thread up soon
You,ve done wonders there sam. It always gets to me how the everyday people of this world miss treat things. If you do sell i will be interested.
Will.
I'd say I've mistreat it a bit too, I got it over 5 years ago now, and it sat in my bedroom as a clothes horse for 2, then in the garage getting moved around and knocked over for another 3!
Getting in the mood to sell it, need to get some bubble wrap and a good box first thought before I offer it for sale.
