Tristar CXL Help
fantomfan57
Austin Texas
I am looking for a wiring diagram for my new machine. After inspecting it I found only one problem. The power cord was loose from the unit body.
I took the machine apart and struggled with keeping the two halves steady while I worked on the cord. I cleaned and re-glued the cord stress sleeve back where it had separated. I am pretty sure I reconnected everything back as before.
When I plugged it in, I tripped the power strip. I took everything apart again, stripped the power cord from the stress sleeve and replaced the cording in that section with cording from beyond that point.
Tried it out and the fuse blew again. I bypassed the switch and nothing.
Did I ruin the motor? did I incorrectly bypass the switch.
Does anyone have a wiring diagram for a Tristar CXL vacuum?
Here's a simple way to remember one speed canister vacuum wiring.
There are two leads from motor. Two from cord. Two from switch. Two from power nozzle receptacle.
Connect in this order:
One cord to One motor and One receptacle
One cord to one switch
One motor to one receptacle to one switch
In the end, there should be three wire nuts holding the eight leads in the above connections.
Got it!
So, I followed the wiring schematic (will make a note of Tom's instructions), and it works fine. I fabricated a cord retainer (broke to old one having glued it in place using Gorilla crazy glue). Wires nutted up, plugged in and she hums. Now comes the task of getting those two clam halves back together properly.
NOW, since I have the motor exposed, I want to lubricate the bearings. It is an Ametech Lamb. I have searched online and here and have not found anything yet.
I know some motors have ball bearing and sleeve bearings and certain lubricants for each.
I will keep searching. I washed the hose out yesterday, so I can stand to wait to ensure the hose dries out thoroughly.
Thanks Antoine & Tom!
Happy to help
Nice im glad that it helped i saved it for mine as well remember that site they have parts and schematics for mg2 and cxl ect im soo happy to hear your vacuum is doing well this is what this site is about post pic when your done here is my Compact IEC Electra C9.
Oh no no oil never
Never touch or lubricate that motor from c1 to ex 20 as is c1 c2 c3 c4 c5 c6 c7 c8 c9 c80-2 cxl dxl ex 20 no lubrication requiered ball bearing motot if touch void earanty do not noooo il no motor kaput if u oil it says so on the b otom plate ty not touch that motor !
The Ametek "Lamb" motor used in the Tri-Star was also used in many other cleaners (Filter Queen, Air-Way, Kenmore, Eureka, etc.). I learned how to take them apart and work on them years ago. It CAN be done, but experience is needed to do it properly. I ruined many at first before I learned. You can replace the ball bearings almost as inexpensively as greasing with high-temp bearing grease. The ball bearings are (last time I bought any) about $3 each. Most Tri-Star "Lamb" motors are double ball bearing motors.
Thanks again, guys..
Antoine, I really like that blue Electra. Also, both, thanks for the advice concerning the motor. As I see no issues at this time, I will leave it alone.
To all, I will make the time to finally take pictures of all these new finds soon. In particular, the Hoover Celebrity Chrome Commercial. That one I am interested in selling to a member, not to the gen. pub.
G.
Many thank you for the kind words about my Compact IEC
Hi im glad you like it my grand mother had a blue c9. So i got the same one took me, over 20 years to find my beloved Compact Electra C9 vacuum cleaner .As you see in the picture ,shes in very good condition runs ,like the day she was made .Cant beat a Compact in my opinion.Here are some pictures of her.Rebuilt the power head new motor and brush roll ,in the power head ,new original factory correct hose ,floor tool metal ,of course 95$ later all in all 400 into it runs like a dream.
Vid when i got my new hose yayy
http://https//www.youtube.com/watch?v=VBJFpQR17A8&t=12s
Looks good!
With the exception of sealing the strain relief on the cord better, I think I am done. Tried it out just now, works really well. Was nice to find part of the badge (tar-IEC) in the bag of accessories & filters. Gorilla Crazy Glue made quick secure work of it. Here are the pictures.
QUESTION, I only had the basic exhaust cap on and I noticed the blue lighting coming from the motor...just blue, no smell, no orange/yellow.
I thought I read that this is normal? Is it?
reply
Nice Trstar CXL you got there good job !
The lgiht could be your carbon brush taht need to be set properlyy id say use sand paper and file em down a tiny bit should be ok im sure some other members have more knowledge is it alot of arching or just mininmal
