Tristar/Compact Thread
Also, if you ocasionally turn the microlined bag (and the outer cloth bag if you want) 180 degrees, after it starts to fill up, you will get improved suction.
Be sure to WASH the outter filter bag ocasionally also.
Swish it around in some hot sudzy water several times, rinse and wring out as best as possible, and let drip dry outside in the warm sun, if possible. Hang in out to dry on a clothesline would be perfect.
Also wash out the motor dome filter the same way, just let dry on a towel.
The TriStar/Compact after filters are a must, if you are into filtering as much as possible.
Having all new, fresh filters on a TriStar/Compact is like a walk in the park on breezy fresh warm spring day!,,just nothing else quite like it!
I just got a TriStar DXL with a Model #2-51 PN (no hose, wand or other tools; it also had a crevice tool & tool holder)
The vacuum motor makes a loud rumble noise during start & stop cycles, but runs smooth after it starts until I turn it off; should I rebuild the motor or get a new one?
Erik....if it is making a rumbling noise when starting & stopping, that sounds to me like the motor has dry bearings. If it's something you are experienced in & can do yourself, by all means rebuild the motor.
HOWEVER, if not, & you would require a repair shop to rebuild it for you, don't bother. Assuming your TriStar has it's original motor that is being rebuilt, it would have only 1/2 it's life left. The original carbon brushes should be fairly worn out by now, so a new set of brushes will be required soon for the second half of it's life....most Ametek double-stage motors will last between 30 to 40 years on 2 sets of brushes. Considering a new motor will run between $75-$100 depending where you buy it from, & to have the motor professionally rebuilt will cost about $40-$50 dollars, depending on which shop you take it to, don't bother. The slight extra cost will get you a brand new motor with double the life expectancy left on the original motor.
I found a MG1 TriStar! It was my recent curbside find; viciously abused before I got it. The previous owner ran it without the paper or cloth bag & filled the bag chamber with dirt; the dirt was also backed up halfway into the hose. The PN also had hair wrapped on the brush roller.
I just bought a Compact C2
from Shopgoodwill.com.  It's supposed to be delivered next Friday.  Can't wait, as it will be my first Compact.  These are pictures of it from the auction site:
It seems to me that one of my aunts used to have one of the green models.
And do the vintage models actually perform better than the more recent models?
And are the central vacuum powerheads (like the Sweep'n Groom and the ones from Wessel Werk and Lindhaus) really compatible with the Compact's and the old Tristar's without an adaptor?
Hey
I have a c8 and a c9. I have a Wessell werk 360 and it works with it. It can be used with no adaptor. I bought an adapter for $14. It with compact truly clean very well. I recommend adaptor and Wessell werk. The compact original power nozzle is good Chevron brush b maybe b- but Wessell werk is a+.
Compact C9
My rebuilt refurbish Compact electra c9 .New hose filter bags cloth and paper and alao a new paint and new cord also the manual my built like a thank vac.
