Think I have been converted to Dyson
richardc1983
Leeds, UK
Based on my previous post saying which should I keep the DC07 or the boss. I think I am now a convert to Dyson. Really nice machines to use not impossible to push across carpet and good pick up on the wooden floors and doesnt flick bits everywhere which a lot of uprights do when used on hard floors. Really good to see how all the dirt is contained in the bin rather than making its way to the filters so it just shows they really work. The boss well after 1 use lots of small bits were in the pre filter and it relied on a series of screens to stop that dirt getting to the pre filter however much of it made it past.
Always said before I would never have a dyson given, well this one was given and I think since now Dyson offer a 5 yr warranty on their appliances it gives you confidence to put your trust and money in them. However their motors are so loud coming from Kirby, Henry etc and they heat the room up when your using it lol
The only thing I dont like is having to to use dyson tools. Its hard to use the kirby rug rat turbo brush on the sofa I am having to use one of the metal tubes from the Henry into the hose of the dyson then the rug rat turbo tool on the end of that but it doesnt secure in place it keeps moving about. The suction though nearlly disintegrates the turbo tool lol! Even henry isnt that powerful!
Will still keep the henry for dirtier of jobs as wouldnt like to use the dyson to suck up stuff like plaster dust etc or cleaning the shed out.
Does anyone know if there is an adapter that I can put in the dyson hose that will allow me to use other manufacturer 32mm tools on the end?
No adaptor for the hose
The DC07 uses a 32mm fitting anyway, so most 32mm tools should fit onto the wand/handle, but the actual fitting on the hose end does not go inside the tool as I am sure you know, it sits over the top. So it's just a case of trial & error seeing which 32mm tools are thin enough around the outside edge to fit inside the hose. Having said that, I am curious to know which tools you would like to use on the hose which didn't already come with the DC07.
Have you tried..
The small black plastic adaptor that allows you to fit tools directly to the hose?
It may not be a tight fit, but should allow you to connect to tool directly to the Dysons hose.
Pattern tool sets can be picked up for Dysons really cheaply fom eBay.
Hope that helps!
Hi Shaun
I've got spare tools from eBay on the way in the post for the Dyson. £1 each lol.
The Kirkby turbo brush doesn't have a pipe to attach to the Dyson u see it needs a pipe to go into it. So I need some sort of small black pipe that can secure into place in the Dyson and then into the Kirkby turbo brush.
A small piece with 32mm opening at each end would do it.
Hey,
Sorry, I'm typing off my phone and didn't realise I hadn't put Henry! I will try again.
Have you tried the small black adaptor piece that comes with Numatics and allows you to attach the tools directly to the hose?
That works with the Dyson. I think!
:D
The Henry adapter is too narrow unfortunately for the Dyson cuff. I am sure the Hoover Turbopower extention tube will fit, but it needs to be the type with the ridges around the top of it.
Why not use Dyson tools? DC01, Dc02, 3, 4,5, 7, 14 and 15 use 32mm tools, the rest aren't, they use A click fit tool decign
Vintage Repairer is right - the extension tube from the TP2 will fit into the DC07 hose cuff - and its a tight fit as well, just tried it with mine. You can get the Dyson turbo tools on EBay anyway, such as the one below, which I use on my DC07. They are just as good as any other turbo tools and this is the design that Miele use on their own vacs:
http://www.ebay.co.uk/itm/DYSON-TUR...Vacuum_Cleaner_Bags_Parts&hash=item3a8119a57e
Shame. Is that the Dyson you drove to Stoke to collect?
I've stripped loads of DC07's down, its very easy, and an aftermarket DC07 motor is only about £20 to buy.
The YDK screamer motors fitted in the DC07 and DC14 are the same, but are not the most reliable, and yours has blown the armature windings by the sounds of it - producing a popping sound when on, and an extremely bad electrical burning smell.
I have bought a few like this as spares or repairs, replaced the motor and sold them on again.
DC07's are 2 a penny on EBay, and parts are plentiful, and cheap. They were about the most popular Dyson ever made, and had a very long production run between 2001 and 2008.
They have the same power as the DC14, but the DC14 has more vent channels in the floorhead, so making it easier to push around than the DC07.
Older DC07's were renowned for fragile and brittle plastics snapping off all over them, and also for the cyclones clogging up, necessitating the removal of the top of the cyclone housing for cleaning. They also suffer from torn stretch hoses, and rips in the lower duct hose from the floorhead to the changeover valve.
Clutches are reliable, but the clutch belts stretch over time and eventually start slipping, requiring a new clutch as only one of the belts is replaceable (the one from the clutch to the motor).
Yes it is. I replaced the cyclone to one of the improved ones to avoid the clogging and no brittle plastics on this one. I've heard the cheap motors overhear easily and trip out a lot?
The motor feels stiff and I could smell this smell recently particularly when turning off and back on straight away... It makes a grinding noise!
Motors only overheat if there is a blockage or the filters are dirty. The high wattage motors always run fairly hot anyway, and I have never had a DC07 trip out as they always ran with clean filters and clean cyclone assemblies.
The DC07 normally smells of electrical burning when switching on for the first few seconds or so, this is the initial arc on the commutator of the high current passing through the brushes producing a large spark. Many high wattage motors do this, and on the DC03 clear you can see the large spark through the casing when switching on, but it should only do this for the split second when the power switch is pressed on.
Does your motor actually turn at all when powered on?
You say the motor is hard to turn - are you turning the spindle with the belt off, or just turning the brushroll?
When the motor powers down it normally takes 4-5 seconds till you hear it stop now it is stopping within 2 seconds and makes a grinding sound when turned on. Like the bearings have seized.
