The Electrolux 502 cleaner - cleans better, faster
Does anyone have a spare adapter plate for the 170? I have the hose for mine but no plate to hook it up. (I have the dusting brush too but got it after this picture was taken)
Hi Folks
I dont often frequent this site, but I need help.
I have just purchased a Electrolux 504 upright. Although it didnt come with any hoses, there is no suction from the outlet on the rear, even when putting the palm of my hand over it ! Without dismantling the hose leading from the beater bar area, there doesnt seem to be any blockage whatsoever. I know that uprights from this area werent renowned for high suction, but there is NO suction from the outlet !
Also, there is a numbered dial on the top of the housing containing the bag, but although it turns round, it isnt connected to anything inside the cleaner.
So could someone tell me the reason for this knob, and what is SHOULD do ?
Also, can anyone suggest a reason for no suction ? The motor sounds suspiciously quiet and the beater bar although spinning freely, can be stopped rotating if you push down on it.
Thanks for any help !
Derek
UK
The little knob on top of the bag door is the bag full indicator whistle. Turning it sets it to how “sensitive” you want it to be.
If there is no suction at all, I would suggest checking the suction ducts up the back of the machine for blockages, changing the filters (there is one that is screwed in so you’ll need a screwdriver) and seeing how that goes. Failing that, the motor could have a build up of dust and fluff around it.
I’d also suggest searching on eBay for a set of replacement brush strips. They make the world of difference to pick up on carpets.
Electrolux
We had these years ago as Vikings. It may be normal to not feel suction at outlet until specific hose end is inserted. With many uprights you can feel suction at top of a new bag before lid is closed. The brush stopping is probably a simple matter of needing a new belt.
These were sold as Dometics in Canada and Vikings in the USA. After acquiring Eureka in 1976, Sweden’s AB Electrolux was still restricted in using that brand name in both countries. In the USA, they were able to sell these European Electrolux cleaners through their Husqvarna power tool division, and they branded these Husqvarna vacuums as Vikings. Since Canada’s Eaton’s department had a long history of selling their store brand Eaton Viking vacuums - the majority of which were made by Eureka Canada - they could not use the Viking name so they used “Dometic”.
