anontemp123
CleanMax is the commercial version of the SupraLite (and former Simplicity Freedom) vacuums. So I know about the warranty situation, but I was curious about other differences. Here is the pricing of similar models at my local shop.
R10E $300 ZM-200 $280
R10S $500 ZM-500 $330
R10P $800 ZM-700 $380
The main difference I can see just by looking at them is that the CleanMax models don't have a light.
The R10P and ZM-700 have metal brushrolls. The R10S also has a metal brushroll, while the ZM-500's is wooden. The Simplicity S10S has a wooden brushroll, too. Can I just replace the ZM-500 brushroll with the metal one myself?
So I know the R10P and ZM-700 have lifetime belts. The R10S also has a lifetime belt, while the ZM-500 does not. I can't just install a lifetime belt in the ZM-500, right? I was hoping maybe, because it has the same 2-speed motor as the ZM-700, that I could.
Is there any issue with the 2-speed motor? I mean, is the single speed motor less likely to break down? I like that the 2-speeds have the on-off switch on the handle.
The single speed motor seems to make more noise than the 2-speed motor, even on the high setting.
Does the auto-height adjustment wear out over time? If so, can it be renewed?
Lastly, I like how the brushroll propels the vacuum forward. However, does that mean these vacuums should only be moved in a forward direction? Will moving in a backward direction harm the vacuum in any way?
I'm excited to read any and all responses. There's quite a difference in price between the home and commercial models.
