beko1987
Well the DC03 is waiting glue, Turbopower Plus is awaiting me to do something with the coil and the I couldnt be bothered to do anything with the DC24
So I grabbed the 262, whose motor slows in use
From Hoover 262
From Hoover 262
From Hoover 262
Looked very clean...
From Hoover 262
Ah
From Hoover 262
From Hoover 262
Wow
From Hoover 262
DC04 had its work cut out cleaning that up
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
The wires were very brittle, and cracked when I bent them so sorted that out whilst it was easy to get to
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
All yummy so far!
From Hoover 262
Eventually pulled the armature out
From Hoover 262
From Hoover 262
Looking at the coil, the 2 plates were covered deeply with rubbish! Took ages to scrape it all off, and polish up the contact faces!
From Hoover 262
Before (it did run!)
From Hoover 262
All cleaned up
From Hoover 262
From Hoover 262
From Hoover 262
Span like a dream when back together, and a healthy amount of oil in the bearings.
Runs like new now, thunders across the carpet. All I need now are 2 new carbon brushes and a lightbulb! Possibly new brush strips too as they are a bit soft, but not critical
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262Looked very clean...
From Hoover 262Ah
From Hoover 262
From Hoover 262Wow
From Hoover 262DC04 had its work cut out cleaning that up
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262The wires were very brittle, and cracked when I bent them so sorted that out whilst it was easy to get to
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262
From Hoover 262All yummy so far!
From Hoover 262Eventually pulled the armature out
From Hoover 262
From Hoover 262Looking at the coil, the 2 plates were covered deeply with rubbish! Took ages to scrape it all off, and polish up the contact faces!
From Hoover 262Before (it did run!)
From Hoover 262All cleaned up
From Hoover 262
From Hoover 262
From Hoover 262Span like a dream when back together, and a healthy amount of oil in the bearings.
From Hoover 262
