Shampooer/Polisher History (Electrolux and Others)
View of the underside. Note the radiating brush strips and circular ring made of carpeting material.
[this post was last edited: 6/8/2013-23:15]
Now, here's another oddity: The Red Devil electric polisher. Why am I including this with my postings about the Eureka air-powered polisher? You'll see in a minute...
Yep! The brush configuration is NEARLY identical to that of the Eureka!
There are slight differences, such as the color and material of the outer ring (carpet material for the Eureka and felt for the Red Devil), and the way the brush strips are attached to the metal disk, and the configuration of the little holes (purpose unknown - perhaps for aerodynamic considerations - the holes might allow for air flow through the disk and thus less resistance against the wind as the brush revolves.)
Here's a closer view of the Eureka brush so you can more clearly see the slots that the brushes slide into. Note where the yellow lines are pointing.
And the same close-up of the Red Devil brush.
Okay, now, really! There HAS to be a connection here. I mentioned that the Red Devil polisher was made in New Jersey, nowhere near Michigan (the original location of the Eureka factory). Perhaps there was a 3rd-party company who made the brushes for both companies. Fuller, perhaps? Those brush strips do look like the Fuller brush strips used in many attachment brushes including for the Electrolux combination floor tools.
I love the hedge trimmer attachment. I wonder how many people use it amd actually took their vacuum outside to trim hedges with it.
I sometimes use the Rug Washer for scrubbing floors (with "scrubby" pad) before using the FloorMATE; it does really nice job.
This unit has a unique sound, which I refer to as the "buzzing bees" sound.
Charles
I am confused about how the Eureka Polisher worked. Did you
use it attached to the exhaust ( hose attached, where the cloth
(1930's style) would go ? Is it attached with the suction
tools to the front of the upright Eureka. Maybe it was used
for a Tank (? 1930s )Eureka? Thought they only made uprights
back then ?
Thanks for the help.
Norm Brown
Norm, it attaches (via the hose and wand) to the blower end of the motor. I don't know whether or not it was sold with tank machines or not. The only illustrations I've seen of it, as I said, show it with the Model M upright.
Eureka polisher
Charles is right.I also found one with a one owner Eureka upright.(I think G instead of M).Mine had box and instruction folder with picture mentioned above.The window is a simple but great idea as was Brooks Stevens first clothes dryer window.Unlike dryers I can think of no other air turbine see through vac atts until the modern tools with tinted plastic.I think this was gone by the time of Eureka tanks.- Eureka had a bit of a problem in the early days of tanks as they wanted a Eureka customer buying the upright and wanting atts to also purchase the tank to get them.The government called this an unfair sellig practice.
