SEmigewerbliche BOdenpflege Felix Vogue ECO!
I don't really want to know. I won't mention Dyson anymore. I know what works best for me it's all about personal preference
My preference is now Dyson.:-)))))
I find that a bit ridiculous. You've found ONE Dyson vacuum after years of admittedly mediocre machines. Fair enough if you're preference is that particular model, but what about the 21 years of Dyson vacuums previously that were all a bit crap, and the rest of the Dyson vacuums still on the market?
I need to clear up a few points made here.
I asked the Sebo lady and she said the tests at the moment are down to the manufacture. This is very unreliable as each manufacture is going to use different carpets. There is no say in how slowly or quickly the vacuums should be passing over, but she said she has seen a glimpse of how sebo test them and they throw their vacuums in at the deep end as it were and especially for hard flooring, they cover the floor with a grey mix of powder and crumbs, like a very thick amount. All in all it is very unreliable.
In fairness, when I had my s7 and Felix, as the bag filled it can loose suction but as mentioned, the difference is negligible.
The sebo and Dyson are very much on par in terms of carpet performance. I would say the sebo deep cleans better. The bristles on the Dyson dig deep kind of but the sebo pulls itself forward and really grooms the carpet. The Dyson cleans hard flooring better, but you get the kombi tool with the Felix which I will post a picture if later.
The Dyson looks as if it pulls up a lot of dust although I don't really know how much the sebo pulls up as you cant really see in the bag without tearing the bag open.
I have always loved the Felix as a bagged vacuum and for the reasons I have mentioned, I am preferring it as my daily vacuum. Its an improved version of the standard Felix.
The other dyson machines on the market today are fantastic They have very little differences.
Haha I really don't care about previous Dysons. What's past is past.It's the present that counts. Anyway I don't want to talk about it anymore.
Happy vacuuming :-)
Well everything else aside thanks for uploading the pic of inside the floor head!
Very interesting to see given its the same head thats on my D4 (I don't want to go pulling mine to bits)...
That motor looks a beast! Makes Dysons brush motors look like kids toys.
Oh and I also noticed the suction motor on the D4 eco has a kind of airflow wooshng whistle to it as it starts up / slows down like you mentioned on your Felix.
Enjoy your new machine :)
...alright then. We'll just carry on without you...
Oli, you should vacuum the whole house with the Dyson and the suck up the contents of the full bin with the Sebo hose and then have a nosey inside the bag. The white, high efficiency bags are quite easy to see in. That should give you some kind of idea as to what a fill bin of dust actually looks like when it's compacted into a bag
Oh, another question, what is a semigewerbliche bodenpflege?
Just a heads up regarding the exhaust filters, they're NOT machine washable. I've just got my Felix back off my Mum and washed the filter on a wool wash, no less, and it's still fallen apart. The blue cover has come away from the filter so it's a bugger to get back on properly. The black carbon dust hasn't come off either.
What a pity the outer cover came off.
The black carbon won't come off the filter, but it will be clean enough (should be dark grey) to use again.
Meanwhile use CIF on a sponge to clean the main plastic of the inner plastic - best chance of giving the Felix a cleaner chance of being used again either with existing filter or a new outer one.
I have washed them, as have my two other relatives who have Felix's and they have come out fine. Spotlessly clean and no damage at all. We put them in a small items bags, on a fast wash and low intensity cycle. Do it at your own risk anyway.
There has been no problems with removing those metal bars at the brush roll. They are there to stop the fleix from chewing rugs. It would have nothing to do with "balancing the brushroll". It works for me anyways.
No I do love this machine. It just has a couple of improvements over the older felix and the same performance. Win win !
It may have improvements. But having used both the Felix and the Dyson I know which cleans better manoeuvres better filters better has a better hose assembly and no bags or filters to purchase. I have owned the Felix for 2 years and have been very impressed with it but the Dyson takes vacuuming to another level :-))))
And I would not be washing the exhaust filter as it has not been designed to be washed. If you are going to own a bagged cleaner change the filter after 10 bags as recommended.Also don't empty the bags and reuse them as they will not give the same airflow because the electrostatic membrane will become clogged
Well, it has worked for me and others I know who have done it. If it was causing damage of any sort of wasn't working properly, I would not be doing it, but so far, it is working.
If you want to be able to wash the filters and empty the bag/bin choose a cleaner that has been designed for this purpose. A bagless.
If you have a bagged cleaner change the bag when its full and change the filters at the recommended intervals.
Removing anything invalidates the warranty
Oli - respectively - SEBO advised me in the early days not to remove anything from the soleplate that can damage the motor. The brush roll is held in by the side plate and the fly wheel. If the brush roll gets damaged and the vacuum has been registered for the 5 year warranty, SEBO will not honour the warranty IF grids or anything else is removed from the soleplate. Be warned. I really don't care whether you find it improves anything. It shouldn't really - the ACTUAL SCIENCE of vacuum air between brush roll and carpet has a fine layer of space between the carpet pile and the brush roll as it spins. Having the grid in place allows carpets to be properly vacuumed by pushing against the pile - by removing the grid, you're in danger of the brush roll UNBALANCING against the pile.
Marcus - a nice point there regarding the washing of filters. One must remember that not all buyers are going out to buy Dyson because of the expensive prices - and lets face it Dyson vacs are even more expensive than SEBO with some models. Buyers may no longer have to deal with the dust bag but they'll have to deal with washing filters whether they "want to" or not.
Washing the filter every 3 to 6 months is no big deal. Takes a couple of minutes. Yes Dysons are overpriced no denying that but you will save around £200 in filters and bags.
Anyway I have gone on about this topic for too long now. We all have our preferences what works for me might not work for someone else. Point is I have respect for Sebo very few have respect for Dyson even tho the DC41 Mk11 is extremely well engineered machine. I'll get off my soap box now :-)
Infact when I think about it, bagged vacs traditionally didn't require filters - its only been the appearance of allergies that filters were introduced on clean air vacs and in some ways in the early days, another thing to buy for the vac to keep it ticking along.
As far as I can see there were two main loyal owners of two particular brands - one brand didn't bother with upright filters whilst the other was far ahead of its time and required a filter to be replaced.
Now, even on a price competitive bagged upright such as Panasonic models or even Hoover's Purepower uprights, the filter care is a low level concern compared to those on a bagless vac. In short, bagless vacs aren't exactly that much of an improvement even if they do eliminate on buying dust bags.
I think Sebo did a good thing by putting the S class filter before the motor on the X series and the K series as it not only filters the dust be it also gives excellent protection to the motor ensuring a very long trouble free life. :-)
And I was comparing the Dyson to the Sebo not Panasonic or hoover. And if you're an allergy sufferer as myself then good quality filters are essential. There are millions of allergy sufferers in the UK. And these filters have to be changed on a bagged cleaner. Miele HEPA filters are £20 plus £2.50 each bag.
It doesn't really matter regarding what bagged upright you compare to Dyson, though in my experience. The filters on SEBO may be higher than ones fitted to Hoover or Panasonic, or even any other brand - what matters more is the fact that ANY bagless vac requires far more filter care which is useless for anyone with a dust allergy.
I don't agree that filters have to be changed on a upright with every brand though, Marcus. The only manufacturer who brainwashes short cost consumable parts is Miele in my experience.
With the SEBO X, the microfilter can be brushed clean, giving it a bit more time before it needs to be replaced. However, on some models I know some owners don't even bother changing the microfilter, undoing the computer ties and giving it a wash before installing it back onto the plastic grid sock and using fresh computer ties to keep it on. A few sellers on Amazon UK are now selling SEBO microfilters in this way to cut down costs on selling the complete unit with the plastic grid sock.
I haven't ever done this, but I have had a microfilter that wasn't replaced for three years - I didn't notice any less quality of the vacuum air that the SEBO put out. But I did brush clean the filter at different times whenever it looked dirty. Did I sneeze when I came into contact with the dirt? No. I did sneeze however when removing the dog hair that got stuck up the cyclone bin of my Vax Mach Air!
Granted there is also a carbon filter for the SEBO X motor - but the carbon emissions are low and less harmful with the filter in place. Carbon isn't such a big issue from a vacuum cleaner when central heating systems produce far more of the stuff, just because you can't see it. Plus, other uprights on the market don't have a carbon filter like the SEBO, other than maybe a few Hoover bagless uprights.
I think if you have a dust allergy, then the first thing your home requires is a decent air purifier rather than relying on a vacuum cleaner with high grade filters alone.
Yes I have a Blueair air purifier which has made a big difference. I highly recommend them to allergy sufferers.:-)
That's a good combination a HEPA sealed vacuum cleaner and an air purifier. It can make a big difference.An air purifier is a good idea for anyone really as breathing clean filtered air into the lungs can help everyone in the long term allergies or not :-)
Well, truthfully, or more realistically, HEPA filters aren't really HEPA by design - the proper ones derived from nuclear factories have far more layers including metal based layers.
HEPA filters in vacuums tend to be just paper pleats to trap dust particles. There should be more added in my experience, but then I think the costs would go up and its about time manufacturers made the HEPA cartridges with gloss repelling paper pleats to aid washing of them better for long term care. Some brands like the Panasonic upright I bought have a completely manufactured paper pleated cartridge that can't be washed - otherwise it disintegrates, thus requiring a costly replacement.
Earlier this year Miele also changed their filters - the Active Air Clean filters offer better value than their HEPA ones IMHO and being on average £5 or so less expensive may have something to do with it. The new ones appear to have no charcoal layers fitted (though I may be wrong, but there was confusion on here due to some U.S members reporting that the HEPA filter does have charcoal fitted).
The Miele AAC filters have charcoal added AS WELL as the paper pleated cartridge - but as far as I know the newer HEPA filters have eliminated the charcoal layer now and have just added paper pleats.
