Sebo X4 Pet ECO BOOST
So are those light switches or something else above the ostrich fellow duster? Your electrical systems are a little different than ours. :-)
Yes, it's a light switch, but the are dimmers so you turn them and it adjusts the brightness off the light, surely you have those as well as standard on off light switches.
Yes Alex,
we have those types of dimmers. Some are push on/off, some turn full left for off.
Sliding dimmers are also available, and finger touch dimmers.
You can even wire in a 24 volt DC transformer such as a doorbell has and equip an entire home with low voltage remote controlled lighting. I've only seen it in more prestigious homes, as the cost nearly doubles. You still need 120/220 volt AC current for appliances, but it may pay for itself in power savings over several years.
Yep, hat one I have there has the push on off with the revolving knob to dim the light, we also have the sensor type and the ones that you turn right to th left and they "click" off...Not sure if we have slider ones though.
