n0oxy
I'm getting this vacuum for Christmas for a friend of mine and had a few questions. First, what does everyone think of their Felix. I've done a search on the forums and many seem to think that it's one of the best uprights available.
When it comes to hard floors, do you find that it cleans better to use the hard floor brush or to just use the power head, switch off the brush roll and set the height to the lowest setting?
I've seen some mentions about a modification you can do to the hard floor brush to make it work better, I think you remove the front brush strip? If so, what is the advantage of doing this and will it still work if this is not done? Could someone describe this modification for me in detail since my friend is not mechanically inclined. Also I'm a blind person so a detailed description would be helpful. I've seen a video where this was done and I think you remove a yellow tab that holds the brush strip in. Does one tab hold both strips or does each strip have a separate tab?
I think she will like the new machine, right now she is using a 30 year old Hoover and it's definitely starting to show its age.
Mike
Mike
