Hi. New member here. I work in the commercial and residential rental property business and am in charge of facilities for three moderately large apartment buildings. We have historically used Sanitaire commercial upright vacuums, but in the last few years I have been running into some major problems with them. Mainly, the upper fan chamber gets eaten through during the course of a winter. This is minnesota and we do have harsh winters here but the problem is compounded by management's rediculous sidewalk snow removal expectations. They want lots of traction grit used. This means a lot of it gets tracked into the building, vacuumed up and it eventually destroys our vacuums. I know that the problem has been made worse by switching to crushed granite last year. That stuff has to go as that'll eat through a fan blade and housing in a couple of months of use! But we still had the problem with sand or crushed limestone. I have fixed several vacuums several times by JB welding the holes in the housing shut, I have even coated the entire upper fan housing in a skin of JB weld, but this only lasts for a while. If I don't inspect the vacuums regularly, holes open up, and my caretakers won't let me know till the flying debris takes out the motor.
So I already know I need to change back to sand on our sidewalks, but I would also like to know if anyone makes something like the commercial Sanitaires with with a metal upper fan chamber? Currently we have SC899s and as with all sanitares I have seen the upper chamber that the motor mounts to is just plastic. Otherwise is there another machine out there that could take the abuse? One of my caretakers is using an old Oreck XL 2600 that I found in the trash. I was suprised that that thing actually made it through the winter with no issues, So I'd almost consider switching to commercial Orecks... But I just can't bring myself to believe that that is the best option. Also they don't make oue with a wide path. I have one at home that I am quite satisfied with, and most of our carpet is low pile which is what it's made for. I have used, and was always very impressed with Sebo's Windsor vacuums, but my management can't be convinced that the extra money would be worth it in the end.
Any other suggestions any one has are welcome. Do any other property superintendants in snowy climates have similar problems?
