Royal 6005 Dial
jawj
missouri
Newbie. Have been enjoying reading these forum posts.
Fifteen years ago I purchased an "older" Royal vac, avid thrift store shopper that I am. It cost $20. Thought it might replace my 1970s maroon Eureka (with wind-up cord feature I loved) should it ever go out. Might mention the Eureka was a "used" model I found in a vac shop around 1978 for about $75.
Royal sat in basement gathering dust, cobwebs, and the requisite mealy bugs till 2 years ago when the Eureka finally bit the dust after I sucked up a coin (not the first time) and the repair shop put in a plastic motor fin. I hated the whinny noise it made so I figured it had paid for itself after 35 years.
Pulled the Royal out of hiding. However, twist the Royal dial adjustment as I might, it always "lifted" to where it was not getting the carpet as clean as I wanted. But I loved its easy handling. Had decided I'd have to take it to a shop to fix the "lift" problem.
Not until TODAY while reading another post did I find out the vac has to be ON while turning the dial (I never knew what that little rubber grommet was sticking out of the front plate.) So I was finally able to set it to clean the carpet after these many years. Even though I dislike having to deal with a cord always in my way, I love my Royal even more than I ever did the Eureka and at age 73 (me, not the Royal) it's not likely this one will need to be replaced before I'm put out to pasture.
One question: on several websites, this model is listed as a "Preferred Collection Series". Can someone explain why? Thanks. Good stuff here.
jawj
Yes, this was the "master dealer" equivalent of the model 885, sold only at qualifying Royal dealers who sold a set amount of machines. This machine has no headlight.
If your machine was made before March 1990 it would have a six-blade impeller fan (if original), otherwise it will have the nine-blade impeller fan. What is the serial number on yours, please?
Ben, Thanks for your response. Yep, no headlight. Serial #B910669720, 6amp, Plant A. I don't suppose the impeller fan may be viewed without disassembling the vac?
I can't believe how much "fluffier" my carpet is today since I discovered how to properly adjust the height control. And the bag contents almost doubled so that's how I know it is doing a great job!
If this Granny can do a cursory cleaning, removal/cleaning of brush bar, belt, etc., you know it has to be a great appliance. Someone mentioned an oil port. I'm certain it needs a shot. Can you show photos of how to access and oil type? Manual? Anything else I can do without dealer intervention? Thanks.
jawj
The impeller fan can be seen if you remove the Adjust-O-Rite plate. A flashlight would also help you in your case.
And because the serial number on your machine states it was made in February of 1991, it would be nine blades and unlike the original, it also actually slips on instead of screwing on in reverse.
Yes, all pre-1995 Royals have an oil port (ball bearing motors have only one cap at the rear of the motor). Royal says to oil the motor at least once a year for general household use. To oil, remove the red protective cap over the tube and apply 3 or 4 drops of medium grade (SAE 30) motor oil -- never use lightweight sewing machine oil. Make sure the oil does not overflow down the edge of the tube.
