Royal 501
Look at the picture, the center hole on the plastic fan is just a little bit bigger, that allows it to screw on the shaft farther, that allows the thread's to come through the center hole, then allowing the shaft to screw on
Karl
Karl,
I went back and checked all the replies to this subject (by vacman1961 and human) and it appears you are correct that the plastic fan was used (but on the very last machines).
But... your 501 also does not have the guard by the motor switch, so that is why I still think yours has had the metal fan before. If you could please give me the serial number from yours (provided it is still legible), that would help me further.
Karl
Karl,
Your 501 was built in September 1987.
I would have to guess at this point that the plastic fan also uses a different motor shaft than the one that was for the metal fan.
Therefore, if you need the proper motor shaft to go with the metal fan, it would be part no. 1-501261-000.
Issue
So the metal fan doesn't go down far enough on the shaft to tighten? I have never drilled a fan. It may be okay if it's slightly drilled out. I may get no he should never do that but do maybe a 16th of an inch out. Put old fan on to make sure grooves are still usable. You can per say drill out center but risk losing threading. I'd say to hell with it either put plastic fan back on or make metal one work. It's not recommended you may not get metal one to work but if you want metal one to work shave small very small pieces of checking threading with old plastic one. There is even worse advise put metal one on heat it up torque it on but you would have to make sure armature shaft doesn't twist or it could be bad. So if you want metal fan slightly cut out middle section. You should keep threads and it would work. I know everyone will say don't but slow and steady it should work. I know people don't agree don't roast me. He has a metal fan either it works or it doesn't. If it doesn't you seen I have armature and fan. If it doesn't work if you cover shipping I'll send you metal one with bearing plate and fan. I have about 8 royal hand vacs. Motor and fan are parts I only needed switch for 1930s or older hand vac. I have 3 1940s royal electro hygiene ones I had 4 80s-90s ones. I had one for sale in supermarket plack with red and black bag. I gave it to my father because hand vacuums are handy. I get most at thrift store ranging from $3-$8. I have a Kirby vacuette a Douglas busy bee but royals seem to out do Kirby ones. Idk so try that don't roast me it's iffy if it works but you already have the fan it doesn't fit so worst case scenario metal one won't work. Try what I said it should work as long as drilling out is slow not slamming it in chunking metal pieces flying everywhere.
I also thought about filing that bottom part of the shaft so the metal fan will go down over that part.
Right now that hole in the center of the fan will not go over that part of the shaft like the plastic one does.
Hey
The fan doesn't have to be flush with bearing plate. You can grind it down that wouldn't affect it at all.
Grind it just measure difference and make a mark to know where to stop. This wouldn't affect anything at all.
Are you sure you're not having a depth problem, rather than a diameter problem? Before you jump the gun, why not get a cheap digital caliper from Harbor Freight (for like $15, good thing to have around), and measure the depth of the shaft hole in each blade, and then the diameters as well. And if the hole has a 'step' in it, you can measure the depth to that as well.
Also, is the fan itself threaded? Or is that only the belt shaft that acts as the nut that holds on the fan?
Hey
Listen to the logical poster. He has a point. You don't need a caliper. You could turn fan on its side marking areas on a piece of paper.
Wow! I don't know what I was doing wrong but I tried putting the metal fan on this morning and it went on, the belt shaft went on just fine. Sorry everyone, but thank you all for helping me.
Oiling...
Mine does have an oiling port... Instructions detail how to oil. Additionally (see pics for instructions) there is another access point (with bag removed) at the top and rear of the motor casting.
