Riccar 500 Any Comments
Bump Entry level
Riccar msp is $300
It is white so I guess its the
R500.
I haven't checked it.
Says its dirty
but comes w some hepa bags
Arrrgh
Like I need a another vac..
Wood brush roll plastic bottom plate
Must be worth $20?
If it's clean and has a good working motor, you can always upgrade it to the steel agitator with new brushes for very little cost. You can also upgrade the soleplate by adding the steel cladding (held on by two screws). You can even upgrade post-motor filtration to HEPA by adding the HEPA filter. Used with HEPA bags, it's a good, solid, reliable vacuum that will clean very well.
