Update of when I started this post........
Well, I actually have went two months with only using the Rainbow. The only difference is I did buy the newest Black Rainbow with the lighted basin. I have to say either Rainbow reduced the amount of dust in my home. Where I noticed it the most was also on my black stove top and cherry window blinds. I would notice the dust shortly after I had cleaned. While I do have vintage machines as well as Miele's, Electroluxes, Sebo's, and Filter Queen, I was only using the Miele's at the time I was noticing the dust. My Miele's have hepa filters in them and are near new. On hard surface floors, I vacuum into them so as not to stir up any dust.
What did this prove to me. It proved that I should just use the new Rainbow period and I would have much less dust. I am really considering this. I know there are times when you want just a quick touch up and pulling another bagged vacuum out is the easiest and even though people that own Rainbows and love them, usually have another around for these jobs, but I decided to just see how inconvenient it was to pull the Rainbow out.
Well it takes me less than 10 minutes to clean the water basin and separator and wipe the flange on the bottom of the Rainbow. The only reason it takes me that long is I kind of like the water basin to look brand new when I put it on the storage shelf.....if I would just dump and rinse, it would be no more than 5 tops. I know it says you don't have to clean the separator each time on the new machine, but I have always cleaned the separator each time on my SE PE and there is never any dust in the exhaust port.....so I will continue to clean the separator each time, even on the new machine.
So this ends my story. I did buy my Rainbow from Ken Bashford from Texas. Great guy to do business with and as Rob said, everything came double boxed and fast. I know there is a lot of interest on the forum for the new Rainbow and if you can afford it, you won't go wrong. It is just a wonderul machine. I still like my SE PE, but the new Rainbow with the longer hose and newly redone power nozzle is awesome. Between the hurricane motor and new power nozzle, the airflow is much better than on my SE PE.
PS, I do want to make one more note here. Before I started this I was only using TOL vacuums, such as Miele's and Sebos, both of which have hepa filters and are both fairly new....I had not used the Rainbow for about 6 months and when I emptied the water basin the first time, it was much dirtier than I expected it to be. Not saying the Miele's and Sebo's are not good cleaners, but.......
Ok that is how my test worked out for me and again thanks for taking time to read it.
PS, Thanks Rob for answering some of my questions about the new Rainbow and for  all of your wonderful pictures and comments about the new Rainbow. I knew I wanted one, but after you awesome post, I just had to have one and boy am I glad I did. I did just order the 14ft hose from Ken on Friday, as I have vaulted ceilings and ledges in my home. This will allow me to keep the Rainbow on the floor and still be able to clean up high.
Sincerely,
Bud Mattingly
PR-21
