Numatic Henry HVR200A
Ha I don't have a pHd in anything!
My stepdad poked it witha multimeter and confirmed it was dead. Sadly, and I've jsut realised he hasn't poked the new board...
However, he did recall a yarn to me. He works in electronics, has done since the 70's. Apparently, once, some US manufacturer made a power supply for a computer. Worked well abroad, they started selling them here. He had a broken one in for repair, and found that a certain component was only rated to X value. X value was fine in the US, but too low for the UK, which has Y value. 80% of the time, the product will work well, but if the load increases above X value, it breaks and kills the product. A change was made and it was all fixed etc.
Maybe, since these machines now go all over the world, something similar is happening here. Some component on that board cant take the heat/hi-lo switching cycles/constant high power. Of course one would need to browse foreign ebay to see what the failure rate is, but I bet alot of the abroad use is from companies who buy fleets of them.Enough of the fleet dies in a silly amount of time and bam - dropped from the books due to unreliability. So we may never know, as I doubt they go to ebay!
The switch is very simple, and mine was spotless inside. When the switch is flicked, it contacts thecontacts, which send the signal to change power to the pcb. (incase anyone thought it might be the switch)
Happy to post my dead board to someone more knowlegable if wanted! I'm getting quite interested in this!
On that chip, the model id is only very different between the boards. Both made by the same company too.
That chip is my primary concern tbh. On my S5, the thermal fuse is very similar to that, just bigger. That had blown on the solder joints. But the whole module was replaceable (at eye watering cost from miele I assume!) as the chip was supposed to die first (after considerable red light of doom)
Same could be happening here either inadvertantly, or as a failsafe which is proving unreliable, hence the service item note on the new boards bag!
Manchestervacs, are you reading this? Any insight from a professional point of view? Know anyone who gets alot of henries in? Any trends?
I wouldn't worry about it, fitting a new PCB is cheap and easy.
I'm not too sure what that is, but whats funny is, in the Bertie, the PCB if facing away from the motor, but that piece seems to be on the other side facing the motor? I found it odd. I'll get some photos up tomorrow
I agree, as a general issue for us especially, I'd rate it no more tricky than getting a motor out of a 1334! 'Service Item', get some in alongside your belts and bags for the rest of the fleet!
If you skipped the washing, drying, posing for photo's etc you'll be done in 15 minutes! All screws out, lift off the hat and take cord rewind out, lift the next bit up enough to slide the pcb out, swap the wires over and slide it back in. Re-assemble, job done.
That part is still on the side facing the motor as it needs to be in the path of the cooling air from the exhaust duct, which suggests it gets hot in use and even after the board was modified, it remains in the airflow.
It looks like a large transistor - a kind of switching relay.
If the henry has a thermal cutout, this is likely to be built onto or into the motor housing, which I haven't yet had a good gander at. I only opened up my Henry to see what type of board it had in it.
Beko - with an electric screwdriver - turn the head over and remove all 7 screws, then lift up. The top comes off and reveals the board slotted in the ducting. I looked at it last night and its possible to change it in less than 2 minutes.
The big problem is that Joe Public wont know this and assume the motor has gone tits up when henry "just stops". Hence they will throw it out or sell it  on ebay without realising that they could get a "service item" for £20 or so to fix their Henry.
That's very true Steve. It's a shame people don't get things repaired anymore. *sigh*
Looking up transistor on Wiki, it seems that the component marked with ?? is indeed a power switching transistor. It has three legs. when a small voltage is applied to the centre leg, it allows a certain current to flow through the other legs. So it effectively controls the resistance of the motor circuit between the Hi and Lo states. When in Lo, the input voltage to the centre leg changes the resistance of the circuit to increase it - and this lowers the current flow to the motor. The transistor then gets hot as its offering higher resistance to the current flow - hence the transistor is fixed to a heat sink, and this is in the airflow.
I wouldn't be surprised if that big black 3 legged component isn't actually a triac. The design may well be chopping the AC waveform to reduce power to the motor as a basic high/low speed controller. They're often used in dimmer light switches and for switching heating elements (I work for a heating company and see Triac's in more products these days).
I've got an older pre Autosave Henry here with the red footswitch and a green side hi-lo switch. If these also had a similar board inside I'd have a look to see if the AC supply is being chopped like I suspect.
Yep, just as I thought. It's a Triac, 12Amp rated.
http://www.st.com/web/en/resource/technical/document/datasheet/CD00161295.pdf
The circuit board is like a dimmer switch, fixed to a lower setting, chopping the AC waveform to reduce power to the motor. It's either getting too hot (no heatsinking, poor airflow) or like others have suggested, the carbon dust has snookered it.
If it's just that component that's failed and it hasn't killed anything else on the board, the Triac's are sold for about £1.29 + VAT from RS Components, part number 687-0947. If something else on the board has failed too, you might as well shell out the £15 on a re-designed PCB or just bypass the ruddy switch altogether :)
Well then if you want to keep your Eco Henry, I suggest buying a whole bunch of boards!
I was actually going to buy the exact Henry with the exact problem like Sam's one approx 2 months ago which went for £32 I think?
Thanks to MooJuice for his info - hopefully people will be able to find this thread in the future if their Henry suddenly "dies".
I think that with a heavy enough build up of carbon dust all over that circuit board, its bound to have caused a short somewhere, which was why Numatic had the majority of the circuitry turned round to the other side of the board, so that only the Triac faced the carbon dust flow.
Incidentally, there is a carbon filter wrapped round the motor, so maybe washing this out once a year might help reduce the instance of board failure?
Hilo - no afraid not. Don't use facebook, nor Skype. I'm too old to understand all this new-fangled technology used by your age group lol.
My Dads the same age, but he "apparently" uses it for the sale pages. He's such a Liar. Shame, are you on Youtube?
facebook
My cleaning lady recently uploaded me to facebook. I have four friends in my list. I like it that way. I am finding the internet to be both a treasure trove and a Pandora's box, in similar measures. I laugh at what I read on facebook. 20 years ago people were often 'ex directory' (if you are young and don't know that term, look it up on this wonderful internet) and yet today people cannot wait to spread their business around.
There was a woman who lived on the corner of the street where my parents house was. She was the equivalent of what we know today as the BBC News 24 channel. She is also long dead, yet I cannot help wonder what she would have made of the facebook.
Hi I have a henry and have recently changed for the red one,
Quick question
Before I changed pcb could get no power,just a light on the high low rocker
Now I've changed pcb henry lives again yay !
But no hi low function just one speed LOW
i wired it from wiring diagram
I've told the seller of the pcb but he says it must be the high low rocker switch
I'm just wondering did he send me the wrong wiring diagram for the light up rocker switch?
I have a Miele S5210, which is still doing sterling service as a daily. Except it doesnt get used much at the moment, as theres always another vacuum to use! Infact the last time I looked it was covered in dust in the hallway...
Here you go Leo, my mums S4, my S5 and an s3 I bought of eBay cheaply, refurbished and sold shortly after this picture was taken! Just received a service box each for mums and mine today actually!
