Numatic Henry HVR 200 New In Box From 2001
1100w single fan motor, not the most reliable Numatic motor
But, it is an all metal casing! Nice motor sound insulation/carbon dust capture filter there.
You can see there motor was made on 7th May 2001
Not long before the machine was put together, remember the rating sticker said it was made in the 33rd week 2001, Numatic certainly didn't keep stock for long! shows how popular the machines are.
Anyway, back to what the original plan to do...
So, I smothered the contacts in grease, as they should be and the rewind is as smooth as anything now.
Machine is all back together and in it's box.
So I ask, should I use him, or keep him new? what are your opinions, I would like to hear. :)
Thanks for reading.
Alex.[this post was last edited: 6/25/2016-19:49]
Well spotted.
I know, it isn't, the hose pictured is off my Jack, I included it just for the photos.
Unfortunately, the filter, crevice tool and hose were missing, as the box was not factory sealed, despite the missing pieces, (which is no big deal) there is no argument that the machine and other tools etc have never been used! It is very evident they're new and unused, the seller said it had been moved a few times over the year and things may have accidentally got lost from various moves...Not sure I buy that as the reason for those parts missing but anyway, who knows!
I have tracked down an original type "permatex" filter, used, unfortunately, but you can't buy it anymore, after a wash through the washer, it should be whiter that white and good as new! I bought a 1.9m hose along with a short hose cuff to make it fully original again, I also bought a generic crevice tool, as the generic Numatic tools you buy now are the same as the old genuine ones, lol.
I am still puzzled as to why the hose, crevice tool and filter were missing but the machine is completely new, a mystery...The only thing I can think of, is that the original owner bought two Henry's at the time and stored this one as a spare, and the parts missing from this were used on the first one as they got used more.
Alex.
Why would you use him Alex?  It's not like you don't have other Henrys.   An <span style="text-decoration: underline;">un</span>used Henry is special.  A dirty Henry, call him a dirty boy, are so common.
I see Henry without his hat is merely a butch looking James, with a tough hair cut.
Any idea, Alex, what the blank cover was for?   Potential power nozzle plug?
All of our vacuums are "one in a million".   Look at that as either a compliment, or just the truth about our factory, mass produced lifestyle.
Wow.  Think of how many vacuums are made each year, and how many have been made since vacuums came into the lexicon of appliances.  And we all own probably, at least one.  Even if a person owns 50 (and I do), that's nothing in the grand scheme of things.
Yep, it is a blanking piece, this style of Henry was used between 1999-2002 it was the first of the standard Henry's to do away with the powerhead socket, all standard Henry's before 1999 had a power head socket. Numatic redesigned the motor housing slightly in 2003 so there was no blanking piece at all and added a push button on/off instead of a side mounted rocker switch.
In 2004 Numatic made Henry two speed, basically just added a hi/lo rocker switch on the left side and kept the push button on/off.
Numatic completely changed the switch layout in 2006-present, with, needless to say, the current Henry style, two rocker switches at the back on top, an on/off and hi/lo and with one central exhaust (a bit like the HVC200 with the central exhaust) unlike two side exhausts that had been used since 1985.
Numatic changed Henry to have an "Autosave" feature in 2009, which basically changed the hi/lo switch to a kettle design switch that would spring back when pressed, with a little light when you pressed it to tell you it was in hi, this had a slow start motor and always defaulted to low upon turn on. The "Autosave" Henry's proved pretty unreliable, so Numatic changed it back to the hi/lo switch again. Simpler.
Back to the this Henry...The motor housing on this 2001 Henry was first used on Henry's in 1991 and remained unchanged right up until 2002, of course, before 1991, there were two other types of motor housings used, the original non rewind HVC200 type, 1981-1985 and the first rewind models HVR200, 1985-1990. [this post was last edited: 6/28/2016-00:19]
Nice shot at the end
I see you got the missing parts.I noticed that your 01 Henry has the blanking piece.My old 2001 henry had the blanking port but the one I currently have doesn't have a piece.its a weird molding.I will take pics soon because its 2AM.
-Adam
Adam...
If it is a late 2002 - early 2004 style, with the same motor as this, (1100w push button) they did away with the switch and power head socket cut outs and just made the entire thing flat casing.
I wish I could find!
One over here. These are the only new vacuums that appeal to me at all.
