Not worth it: Riccar/Simplicity tandem air uprights
hmm?
My chart was blank? It may be the fact that i've just rolled out of bed, but did the images not load or am I misreading that.
I'm unable to vacuum the back side of my carpeting as I'm using my installed living room carpet. I once had a rug but it was really nothing like typical installed carpet, the backing of it just didn't breathe properly, and the pile was a tish short. so I figured it was best not to use it for these type of things. That was the rug that I tried sand testing that Lindhaus Diamante on and got terrible results. I recall the Simplicity Wonder getting pretty bad results on that rug too.
I know my test was skewed by remaining dirt. There's no questioning that.
Post# 420067 , Reply# 18
The S40P box is blank.
Did you have a chance to view any of my "carpet reset" videos like the one posted above? In order to have valid results, the tester must FULLY reset the carpet to a extraordinarily clean level. Since you are unable to FULLY clean your installed carpet, dirt of all types (especially sand) is building up.
I would never test on an installed carpet because I could never guarantee the residual dirt levels, especially when testing with smaller amounts (i.e. 5g, 10g). On my test carpet, I can guarantee residual dirt levels usually around the 0.01g mark (rarely higher), which would mean a 0.2% error for sand testing and 0.1% for baking soda testing.
It saddens me greatly to see YouTube channels obtain 110% pickup when using 100g as the dirt amount. That would mean that carpet had up to an extra 10g wandering around the pile. Can you imagine if I was that sloppy? Since I only use 10g of baking soda, that could mean a pickup result of 200%!
Bottom line is please obtain a test carpet and do some dry pass pickup measurements so your results aren't skewed. I paid about $30 for my "plain jane" medium pile 5'x 7' Mohawk carpet back in 2017.
ooooh.
Oh that. Yeah I had a previous test result from that crappy rug I had but decided since I was changing the test carpet it wouldn't be consistent to keep using those numbers when they weren't tested on the same surface. So I just struck the result from my records and left the field open as it was only a matter of time before it was re-done in a manner consistent with the rest.
I get what you're saying and I understand that my method isn't going to be even close to the accuracy of your testing. Thing is I live in a fairly small space with limited hard flooring, I don't really want to keep a roll of carpet around. Even that rug was a pain.
Looking back on the initial rug tests the Simplicity Wonder TAP scored 69.2% on it, it performed much better on my carpeting. The S40P had the same issues where it would consistently pick up over 5G when the bags were emptied onto these trays we can see fibers and what I think was glue particles, it was a rather cheap rug and I just felt that it wasn't ideal for this type of testing.
Everything that's being said here ,got me crucified a couple years ago for on here.
Man has this place changed.
Glad to see people finally talking designing failures of Tacony tandem air Vacuums.
Let's put a few more nails in that coffin.
By the way I think every collector should still have one of these before they completely disappear and becomes scarce.
A huge problem with the design is, the direct air fan pushes the bag so hard once it starts to collect fine dust that the bag pushes the front door open slightly at the sides. This completely negates the clean air motor's suction and airflow. We saw that problem constantly. The clean air motor will reseal the front door once the dirty air motor stops. The small bags clog quickly. Also, you should see the CHEAP gasket that seals the airflow path from the dirty air motor up the back of the machine to the change over valve. Dust puffing out all along the back of the machine while running once the bag starts to clog. Air under pressure will find a path of least resistance. Ten years ago, when I was first fooled into taking a job with tacony (there's a whole story there), I told one of the engineers as well as the vice president of the floor care division that they should use a two speed clean air motor, so they could get 'wow' suction through the hose. Since a two speed clean air motor would cost more than $10 to buy from China, they didn't even want to consider it.
@vacuumdevil
I remember all the drama what was going on at the time.
It's just that you can get the same suction, airflow & cleaning performance with single suction motor vacuum. Like many have said. Unnecessary complexity is never a good idea. Just keep it simple and effective is my motto.
11 years ago this coming June, I was asked by tacony's vice president as well as the marketing director, to give up my vacuum store that I had successfully run for 21 years. I had a customer every ten minutes or so. They wanted me to bring my vast collection of vacuums to the factory in St. James, where they were converting the tornado shelter (about 2500 square feet) into a museum with themed vignette rooms. You can't have a museum without a collection. And you can't have a collection without a collector. I also brought my vast collection of paper (instruction books, brochures, repair manuals, ads, etc.). Period carpet was placed in the vignette rooms as well as period wall paper, etc. Shelves were made for the vacuums to be display in their 'decade' rooms.
So what does one do with a successful store? And a home that still had ten years of mortgage left? I called a good friend and former VCCC member and asked him if he wanted to buy a successful store. I needed to make sure the store continued with the same quality services, and I knew it would continue to be a money maker in the hands of the right person. He moved from Boston and bought my store for the amount of money in inventory and fixtures I had in it. Basically, for a song. He has made it even more successful today by adding central vacuums.
The first problem with tacony is they never gave me a raise in ten years. I was to run the museum, give tours, restore and display additional vintage cleaner as well as run the Factory Outlet Store (that's how they were going to make the money to pay me - this was not discussed at the time I was asked to work for them). I was paid well enough, as I had told them how much I made a year running my vacuum shop. But after ten years and thousands of vacuums sold, and many many thousands of tours of the museum, I still did not have a raise.
Because I collect vacuums, I paid a great deal of attention to the factory as I made friends with the employees and had to walk through the factory multiple times per day. I noticed the tremendous amount of rejected parts, brush rolls that were not balanced, motors that sparked up start up, etc. All chinese parts. The failure rate was high. I was friends with, and went to dinner once a week with, the ladies who ran Quality Control. We ate on Thursdays at the mexican restaurant across the street from the factory because it was half priced margaretta night on Thursdays. After a few, they always started to talk. That's when I began to notice things. About that time, they had problems with Radiance motors failing right on the assembly line. One caught on fire on the assembly line, and they threw it down the concrete steps with employees running after it with fire extinguishers. I was right there and saw it come down the steps. A good friend was working on the line at that time and took pictures on his phone of the flaming machine.
They hired a new HR director who did NOT like old vacuums, did not like vacuum collectors, thought the museum was stupid, and put an end to the annual collectors convention (she did it in writing which I had to sign "the company does not wish to be associated with those kind of people". "those people" are you all - vacuum collectors. They limited the tour time to two hours, so people who were collectors couldn't come and stay all day trying out the different machines.
Then, they decided to cut my pay. My pay, remember, had not increased in ten years. That was the last straw. I did the book work for the Factory Outlet Store, I knew how many vacuums I sold, and I knew how much money I brought in. Since I also was in charge of employee sales (they sold to the employees for the company's cost with no profit), I knew how much everything cost. I knew how much a hepa filter cost as well as what they sold it for (you wouldn't believe the markup).
Cutting my pay, refusing to allow collectors into the museum for more than a few hours, no conventions, I saw the handwriting on the wall. I was most fortunate to meet a woman who bought a Spiffy Maid broom vac from me - she owned a building 8 miles from the factory in the next large town over from tacony. The retail space was 3500 square feet, more than enough for a vacuum store as well as a Museum (the old vacuums were always mine). I quit on April 19 and told tacony to shove it. They chained the doors, keeping me from my collection for a week. Long story, but my boss almost lost her job letting me in on a Saturday morning to get my vacuums.
The actual reason for the Museum wasn't to show it off to the public. That's not why they conned me out of my store. It was to have a place for the engineering department to study the old machines, to be inspired by them when inventing new ones. The engineers are too hard headed to think they didn't already "know it all" and wanted nothing to do with the vintage models. Only once did an engineer take an interest in any of the machines (it was the air-way upright and he did design a modern prototype). So now I was stuck, my successful store had been sold, and I was just an employee of an uncaring company who used me as a trained monkey.
Now, I'm happy again. My vacuum shop is lucky enough to be located a few hundred feet from the entrance to WalMart on a very busy street. I'm the only vacuum shop for 100 miles around. And I don't carry Simplicity or Riccar. I carry Aerus Electrolux and trade in every Riccar and Simplicity I can. I already know most of my customers, either from giving them a tour of the museum or having sold them a machine. Tacony also donated thousands of vacuums to charitable organizations (the VFW hall every year had a benefit and tacony would always donate vacuums). They donated to every fundraiser, benefit, etc. And I had to hand out the donated machine as well as take a picture of the people who picked up the donation and I had to write a press release about the donation which the company put in newspapers across the county. So I spend most of my days selling bags and belts or doing repairs on these many thousands of machines I had a hand in placing with their current owners.
"There's a reason your grandmother had an Electrolux" has sold a ton of them for me already and I've traded in more than 75 Riccar and Simplicity vacuums in the 10 months we've been open. I refuse to work on TandemAir models. I hate them with a passion. All has turned out good, I enjoy my new store and come to work in the morning with a song in my heart. I live my life with "no regrets" (that's tattooed on my arm) but I wish I had known then what I know now - NEVER WORK FOR ANY CORPORATION. They don't care about anyone. If I had known then what I know now, I would still have made the move - as I never would have met my husband if I had not moved here. Six years together, four years married. In the end, It was worth it. But what hell I had to live through working for tacony.
Dang. They really mistreated you, didn't they? I was going to recommend a Tacony cleaner to my mother, but I don't think I will anymore. Also, they might have committed a crime when they prevented you from accessing your personal property. Congratulations on your successful Aerus franchise!
Thank you Adin. I have had nothing but good times selling Aerus Electrolux cleaners. If the customer is unsure, I offer to bring it to her home on her next cleaning day and we'll use it together. Like an old time Electrolux salesman. I love it. They always buy one when I take it to their house. Such an easy company to represent - unlike Miele who make you run through hoops to be a dealer ($4000 initial order and can't sell the home care line for six months). I sell a good number of Perfect models (Electrolux copies) to the college here in town. The Perfect upright (lux copy) has the on-board tools and 95 inches of water lift. Drop in bags, lifetime belt. What's not to like in a commercial vacuum?
Tacony is probably doomed
I used to suggest the Riccar Prima and bought one for a friend of mine a while back. I never suggest their products anymore. Tom, they totally took advantage of you and their quality is awful. The Aerus classic is a great cleaner. I think the best brand you can buy now is Sebo, their quality is excellent, better than Miele I would say. The convention later this year should be awesome, I can't wait. I think the best upright cleaner you can get by far is the Sebo Felix. It walks the fine line between an upright and a canister, in many ways it's a power nozzle canister in the shape of an upright. I bet it would clean circles around one of those Tacony machines.
Mike
so, long story short - in the past there has been drama if you dared to utter criticism on Tacony because Tom was working for them, and now it's time to hate them passionately, because Tom has a problem with them.
He didn't get a raise, now toss your Primas and Wonders für $1000# your old friend has talked you into.
Always keep in mind that this is just one side of the story and there is no chance to doublecheck on this matter. I find it rather problematic to raise these internal claims in a public forum, but after all it's not me who might or might not get in trouble for this.
It's all so tiring and predictable - it makes you want Kirbyloverdan back.
Peace out.
Oh I’m sorry, did the gentleman from Germany say something??
If it’s all so tiring, perhaps you need to go sell some more forklifts , or maybe just go FORK OFF!
I seriously don’t think that you maintain loyalty to all of the equipment companies that you formerly worked for. How often do YOU change companies? I’ve seen you on Linked in, so I know you’re not loyal to anyone but yourself. You’re no different and certainly no better.
I had a tandem air Simplicity, I bought it for $100 from a Kirby dealer who got it as a trade in from an older woman. It hardly looked used, I doubt the bag was ever changed in it. I can't imagine anyone actually spending $1300 on one new, the cleaning performance was alright but it wasn't enough to justify the price. It was loud and heavy, hard to maneuver. I gave it away to an ex because it was better than his Hoover Air at least.
I do have a cordless Freedom which I got at a decently discounted price. It cleans well for a cordless and I am happy with it as a part of my collection, but the tandem air models are gimmicky. There are much better companies and cleaners out there than Tacony.
