new very old eureka vacuum??
Someone demoed one of those Vibra-Beat nozzles at the convention...what a racket! Could anybody actually stand to use them for any period of time?!
Heh heh,
That demonstrator was me.....LOL
I brought that FNWB (fairly new with box)Eureka VibraBeat model 1010 that I found JUST before the convention last fall.
In fact I dislike it so much I've never used it since...the vacuum I have, but the Vibra-Beat I have not. I've found VibraBeat makes alot of noise, but isn't all that when it comes down to it. All bark, no bite.
The machine is very powerful tho, and while the hose is orig, the hose also leaks just enough where you can tell the difference from the suction end at the canister, and the attachment end. Someday I will ask Dear Friend Dave to assist me, or give me pointers on how to properly latex the innards of the hose, to renew the NEW suction strength.
You're right I think I had it on for like five minutes, then shut it down. LMAO, the noisiest thing to come out of a vacuum factory ever.
I was just gonna say...
I will bring the latex fixings and do a hose or two. Vinyl weave works best and is undetectable. Cloth weave is second choice as while not unsightly, the latex will seep through to the cotton threads and impart a slight darkening of the weave. But latex does dry and cure clear. On the vinyl weave hose the leached latex will simply rub off the vinyl leaving no exterior trace. Solid plastic or vinyl coil? - buy a new hose. :-)
We'll start when folks arrive - take about 20 minutes for the preparation, pour, drain and pressure impregnation and mop up, then we hang the hose vertical from the basement rafters with a running warm vacuum exhaust blowing through it - and by the middle of the afternoon it'll be cold cured and testable. All we need is one exhausted vacuum for each hose we do for the initial dry setting process, about an hour on warm exhaust.
bring a hose and we'll do'er, too.
Guess there's no need to bring along a Vibrabeat nozzle. LOL
Dave
Thanks so much for this link about the Cordaway Upright,,,this seller is less than 20 miles from where i live, so, i e-mailed them to find out if the machine is for sale,,,if so, i will get it!
Have never owned a Eureka Upright before,,it takes F&G bags im assuming?
Also, what kind of belt? Im assuming any vac shop should have them? Do they have a special name or model number?
What tips can you tell me about maintaining it, fresh bag, new belt, plenty of bristles on the brushroll, make sure its not missing any fan blades, ect? (im a Kirby man, so, if im dumb about Eureka's, you'll have to forgive me!), But im assuming all the things that are true of a Vintage Kirby also apply to a vintage Eureka.
Thanks guys!
Maitainence
You are correct Brian, The bags are F&G, and the belt is the round type like the Convertible only a bit bigger in circomferance. Wally world should have the bags and belts, they usualy do at mine but sometimes i have to order online from wally. Not much maintainence at all like you said a new bag,belt and no missing fan blades lol. Mabe a little wipe down now and then.
Hope this helps.
Kenny
Yes, it does, thanks Kenny! I called the seller, and am going to pick up the machine tonite after work!
Will let you know what kind of condition its really in after i get it home and play with it a little.
Turns out this seller lives less than 15 miles from me, HA,,guess it pays to be on the look out!
I just hope someone hasnt vacuumed up pet droppings or vomit with it!
A buddy of mine that owns a Vac service and supply center says you wouldnt believe the things people will vacuum up,,,especially with older vacs.
He opened up an old Rainbow D2 once where someone had vacuumed up ROTTING FISH GUTS and STINK BAIT after cleaning out an old fishing shack,,,,and couldnt understand what was wrong with their Rainbow! It always worked before!!! - GEEEEZ!
Got the Eureka!! The seller delivered it to my door!
It does need bags, of course, and a new belt,,,are there any special tricks to putting a new belt on this Eureka?
Again, you'll have to forgive my stupidity,,i know virtually nothing about Eureka Uprights.
The vac looks to be in very good clean condition.
The seller said it belonged to his eldery mother that just went into a rest home,,and she kept very good care of all of her posessions. There were no attachments. And it is a 2 speed.
The Cordaway is nice and tight,,but the plug has been replaced at some point.
There is hardly a scratch or nick on the vacuum anywhere, and the brushroll is in excellent condition.
I think its a VG1? Its golden brown in color, with the red beater bars. The brush bristles are long and full, so, im assuming that means it has seen little use, for being as old as it is.
Im anxious to get bags and belts for it, and give it a go!
Thanks for the heads up!
you bought the one above?
Well congratulations. It looks like a beautiful vacuum.
Reminds me of a Sanitare. But gold!
IIRC, the vibra groomers are bars with actual dents in the brush for the beaters. I dont think they have beater strips like on a hoover.
Who knows? I dont!
Oh I think you're gonna like it and even in the picture it looks pretty unscathed. They have such a nice sound to them I think, unmistakeably a Eureka sound
The Vibra Groomer I is on top.
the Vibra Groomer II in on bottom.
If yours has read plastic beater bars, its wooden.
Thank you! Yes, it has the red beater bars. Its a model 2081-A and has a serial number of 3888773. (According to the stamp on the bottom of the machine.) Im assuming made in 1973?
This is my FIRST Eureka,,,boy, if anyone tells me again how heavy a Kirby Classic is to push,,,they have never pushed one of these Eureka's! That things like a tank!! Good Grief!!
That machine is ALOT of Vacuum Cleaner!
I had no idea how much MORE machine that is, compareed to say a,,Kirby 500 series. WOW!
Yes, a new belt is definatly in order,i can tell that its weak, and the headlight is burned out,,,will get it all fixed this weekend.
Im assuming a new belt will make the machine easier to push?
Yes the motor has a beautiful hummmm, and sounds perfect powering up, and winding down,,,no growling , or bearing noise at all.
Evidently the ol gal that owned it didnt use it very often!
Brush rollers
Hi Brett I really like the brush roll # 2 looks like it would really do a wonderful job on the rugs. The older Eurekas really were nice machines. Take care Doug.
It shouldn't be too hard to push, they're not nimble though, are you sure you have the setting right,, like a Kirby start at the top and move down till you can hear it on the carpet. but you'll need that new belt first.
