Never saw a DS80 like this before.
The poor things...
They're all having identity crisis ...they don't know who they are anymore..lol better check their green cards
wouldn't the green card,
Only apply to.the DS80?
Rose-wood cards, Brown cards, red cards, blue cards, Orange cards, the list goes on!
Yes...that's what I meant..hehehe it got lost in translation..at least try & get them back to original..not mosaic like I see some cars going by with different colour parts like a bonnet, boot, & doors.. LoL
Tradition attachements
When an outgoing Kirby model has its parts changed entirely like this, where every part from the then-current new model is installed to make the old model look identical to the newest model, would that be considered fraud? Who would be doing it? A vacuum store or a salesman's office trying to move old inventory out and pass it off as the newest model? I've encountered a few like this for various models. I just classify them as "clones" but I always wondered why it was done. It's a ton of work to do, and deliberate, so it isn't just parts being replaced as they break. I can't imagine the everyday vacuum owner ever noticing that their "new" Kirby is actually the past model with new model parts on it, since they usually all look identical after all.
Correct, and the original serial number plate is (often) either removed or scratched over, so for future reference, make sure you have the model and serial numbers of your cleaner as written by the original dealer handy.
Good to know. I just got a 517 that was converted into a DS80 and they actually went through the trouble to take apart the entire power switch and change that to a DS80 green switch, wheels, handle, nozzle, the works. Not by the seller - whoever owned it before the person I bought it from. It's been sitting in a basement likely 30, 40, 50 years. But it sure fooled me. It had all the correct attachments in the kit for the DS80, the manuals, I checked the photos carefully for things that didnt match and seen everything looked right.
But when I seen the OG 517 tag on the bottom I was like ????? That's when I had the thought that when people did that, their intention had to have been fraud, because that level of time and effort it took to do that and totally tear it down to rebuild it as a fake had to have taken a couple hours at least.
Some people did that back then as they wanted to have the advantages of the two-speed motor for hose use.
However, for models 516 to 562 a different O-ring was used for the hose because of the different hose motor coupling design (metal). Beginning with the Sanitronic VII, the plastic hose/Emtor coupling was used that was permanently mounted to the hose, and thus a different fan case gasket was used when attached to the front of the motor. Therefore, you need to buy not only the different hose (for models Dual Sanitronic 50, 80 or Classic 1-CR) but also the associated O-ring for it (122068A).
So I am in the process of trying to acquire the parts to convert my Avalir 2 to Avalir Platinum spec but using the insulated fill tube sold on the European models. I want a quiet Kirby. When I die and someone else gets that Kirby are they going to think I was doing something by way of fraud?
Leave a note somewhere inside.
I have too many Frankenvacs to do that. A lot of my working vacuums are modified various ways, different motors, added or improved filtration, hose creations ( like ten footers for the Metrovac and for old Eurekas ), even made a few custom expander cages ( those work ! ) to reduce the loss of airflow as the bag fills. A Frankenkirby is just part of the terrain here.
As I said in the earlier post, the clones I have are more than just a couple parts being replaced, it's every single part changed to make it look like a model it isn't. Wheels, bag, handle, handle color insert, handle grip, nozzle, power switch color, cord color, everything. And it was done that way decades ago when the model was new.
