matt8808
Figured I'd do a little review of my swanky new tumble dryer... purely for the purposes of showing it off of course LOL
SO...
I decided my bog standard vented Hotpoint machine needed upgrading / replacing. I'd had it a year and a half and it had taken some hammering. I tumble dry EVERYTHING. Regardless of the weather.
I wanted somthing with a large capacity, sensor drying and most importanly given the high useage I wanted something that was going to be energy efficient. So this narrowed it down to a heat pump machine.
I was initially looking at buying a Miele TKB440WP as we own a Miele washing machine.
It was rated at A+ energy efficiency with an 8kg load capacity at £1099.
Then I saw the LG Hybrid RC9055BP2Z machine.
A++ energy rating, 9KG load capacity, a lot more features and only £749.
I did toy with the idea of holding on and saving the cash for the Miele, but at the end of the day the features of the LG machine appealed to me much more.
It was £749 with £50 off when you traded in your old machine. I then took out the 5 years extended warranty for £59 bringing it to a total of £758.
The first machine was a DISASTER. I can only assume the compressor for the heat pump was faulty as it wasn't removing any moisture from the items inside / wasn't condensing anything. The retailer I bought it from were very swift in collecting the faulty machine and delivering a new replacement.
Before they took the faulty machine away I had a quick look in the back. The extra heater element had 'AEG 1000W' stamped on it. So I'm assuming it is a part possibly supplied by AEG? And uses 1000W of power?
Anyway. On to the machine itself.
The eco hybrid system is simple. You can either dry in eco mode using only the heat pump - This gives you an A++ energy rating, or you can dry in speed mode using both the heat pump and a traditional heater element reducing drying times by around 30% and still giving an energy efficiency rating of 'A'.
The machine has a total input of 1800W, so assuming that the heater element itself is 1000W, running in eco mode with just the heat pump uses only 800w of power.
When you select a cycle, say cottons on eco mode, it estimates that it will take 3 hours, however the cycle usually drys a full load in around two hours. The speed mode does shorten the time, but not my a huge deal IMHO and I rarely use this mode.
I tend to dry using the mixed fabrics cycle. The basket of washing in the pictures is two loads from our 7KG Miele washing machine. As you can see the dryer swallows it nicely.
The mixed fabrics cycle has a maximim capacity of only 4KG and it estimates it will take an hour and a half to complete. I use this cycle as it barely applies any heat to the clothes, however given I've exeeded the advised loading capacity the load of washing pictured (heavy items - towels, jeans ect) actually took two and a half hours, an hour over the estimated time. Had I used the normal cotton cycle this time would of been much shorter.
I can dry a load of bedding with some bath towels ect on the cotton cycle set to eco and cupboard dry in around an hour and a half.
Build quality is superb, for example to door and hinge are VERY sturdy. There is the usual glass bowl and also a secondary plastic cover on the outside of the door to stop you being able to touch the hot glass bowl while the machine is in operation.
As this machine has a heat pump to condense the moisture there is no huge blast of hot air blown from the machine like a normal condenser machine does. Rather than having to use air from the room to cool a heat exchanger, the heat pump creates the cold surface for condensing the water. Similar to the way a fridge works - hence no blast of hot air being blown from the machine.
The machine is fully self cleaning other than the lint filter and it also come with a seperate drain hose should you wish to connect the dryer to a drain (to save you having to empty the water container).
I've included a picture of the moisture sensors in the drum, these are the two metal strips behind the filter.
Airflow through the drum looks to be very high, I've included a picture of a smaller load and as you can see, as the tea towel tumbles by the door it is partially sucked into the filter area.
I've not had any issues with small items becoming stuck to the filter as the other washing always knocks it free.
Oh and there is also a nifty drying rack included for drying delicate items and things like training shoes.
Noise is average. It sounds pretty much the same as a friends Miele condenser dryer, other than when the pump kicks in for the self cleaning mode to wash the heat exchanger - then it sounds a like a dishwasher as you can hear the water being sprayed about!
I did try looking into LG machines prior to purchase, and couldn't find a huge deal on them in this country. There were a few issues with drums on older 'normal' machines in places like America, however this machine has a totally different style of drum so hopefully it will give many years of trouble free service.
All in all I'm really pleased with it. It took a while to adjust to the longer drying times, but this is due to the superb energy efficiency.
Anyway here are a load of pictures and some links to the machine on the LG website ect ect....
Oh and please excuse the clutter around the dryer... It is located in what is essentially our 'junk room'. The dryer is also stood on the wooden plinth as the user guide says not to install it on carpeted floors.
http://www.lg.com/uk/tumble-dryers/lg-RC9055BP2Z
SO...
