<a name="start_14218.150383">I have seen quite a few of these. There is a large developement here in Dix Hills, New York, that was built by a developer called Levitt, yes, he is the builder of Levittown, NY. This developement is an upscale developement that was built by Levitt, and Levitt used everything from General Electric, all the appliances, the heat and air conditioning, the intercom system, the door bell and yes, the central vacuum system. The unit actually was built by Beam, it is the same unit as a Beam only with the General Electric name, actually, the newer developement which was built in 1972 had a sort of generic unit, it looked the same as this one, only it was white and had a 12" round red GE logo in the center, that unit was definitely a Beam with a GE logo on it, but this one was in the earlier development which was built in 1967 to 1970. There was no power nozzle on them, they were straight suction, some of the houses had a air driven power brush with an adapter on it, the power brush was called a Preco Power Brush.</a>
I know nothing of central vac systems other then I'm a Master Plumber and the piping scheme kind of interests me. They just borrow the same principles we have in waste & venting, except the instals look pretty rough and unprofessional to me. About using a PN with these....wouldn't that require a live wire to every wall port and therefore the hose to have an internal wire as well?
Kevin
Kevin
