Hello, I'm looking for the part number for the motor bearings on a Electrolux Legacy canister vacuum. Anyone have a parts list ?
I second Kirbylux. The bearing will have it's size stamped on the race. You'll need a magnifying glass to read it though. Any quality bearing the same size will work. When I was looking for bearings for an old Panasonic Jet Flo motor I was surprised to discover the exact same size bearing is a popular front wheel bearing for quads.Hello, I'm looking for the part number for the motor bearings on a Electrolux Legacy canister vacuum. Anyone have a parts list ?
Thanks for the reply. Yeah I got the bearing off but can't read the number. I measured it and will try to find a couple on AmazonStratmaster, I don't believe Electrolux ever intended those double stage motors to be serviced. They would just sell you and install a new motor if yours failed out of warranty. Nowadays though, you can't even get the motor seal new.
I suggest taking the motor apart, pulling the bearings off, and taking a look at the number stamped on it. Then go online to a bearing supplier and find either the same one, or one that's the same size. You can also try contacting Doug Smith, collector2 on here, as he used to be a service manager and trainer for Electrolux Canada. He would definitely know how to find those bearings!
Not Amazon. Buy bearings from a reputable company like Schaeffer Group, Nachi, SKF, FAG or Timken. Don't waste money on cheap Chinese bearings from Amazon. They won't lastThanks for the reply. Yeah I got the bearing off but can't read the number. I measured it and will try to find a couple on Amazon
Is the motor a traditional full size two stage motor or one of the newer single stage motors from Johnson Electric?Thanks for the reply. Yeah I got the bearing off but can't read the number. I measured it and will try to find a couple on Amazon
older modelIs the motor a traditional full size two stage motor or one of the newer single stage motors from Johnson Electric?
That's the ticket thanks, I got a few online works like new now . Very easy to replaceHmm....The most common motor bearings i've seen are 608 which are 8mm inner diameter, 22mm outer diameter, and 7mm width.
Do yours have a rubber seal on them? When I can't read the numbers i'll wipe the seals off and then use my phone to zoom in on the text on them. But if that fails and I don't have any suitable replacements on hand I take it to a nearby business who measures them using a caliper.
