Miracle Mate
I have a Miracle Mate system and I really like it. I'm still in the process of restoring my Tri-Star, so I can't compare the two. Which power nozzle came with yours? The current system uses a Sebo head. Before that, they briefly used one called the Edgelift, and before that they used a Lindhaus head. Also, did you get the XIF UV light for it?
I'll make some observations about my experiences with my Miracle Mate:
It is heavy, but very well built.
It is fairly easy to service.
You have to use Miracle Mate bags for it. The cardboard top helps seal the bag chamber. If I remember correctly, a one year supply cost about $60.
The cord is on the short side, although it does have a cord winder.
Very powerful suction. I've used the Lindhaus power nozzle on some of my other machines, such as my Filter Queen, Airway, or Silver King. With those machines, I can set the height adjustment all the way to the floor. However, with the Miracle Mate the red light will come on if I have it set all the way down. I've noticed this when using Tri-Star power nozzle on the Miracle Mate as well. With most machines, it doesn't matter if you have the air vents open or not, but if you don't open them up with the Miracle Mate it won't push across floor.
It maintains suction well.
