Miele S8
joshdonnell
Hey Guys . I was just wondering of what you guys think about the new line of Miele's. Does anyone own one or thinking about buying one? Cons ?? Pros. I just wanna see what you guys think.
Miele S8 Marin......
I have both. The S8 Marin has a slightly longer cord, maybe 4 ft, the quietest vacuum I own, the tool compartment is much improved (less flimsy), the cord rewind is improved (one touch)just hold onto the cord while it retracts, the bumper is much nicer on the S8 and is curved upward to be more ergonomic. (It does help when bending over to pick it up.) Switches much easier to push than the S5's and it guides better.
Tools have not changed, wish they were bigger. Hose needs to be longer and the wands are still heavy, however, I still have the dark wand that first came out that I still use, when I need to do above floor cleaning.
Just my experience with the S8's.
Bud Mattingly
The miele S8 is suited for larger homes, you can add an extension cord like you will have to with most canister vacuums, if you don't want to switch more than one or two outlets. I like the machine, super quiet, durable and really deep cleans. You might want to also compare it to the Aerus Platinum or Sebo D4.
@ GM1982
I have to disagree with you George (GM1982).
Owning the Capricorn (not at all much different than the S8 UniQ top of the line).
This thing is not big enough at all.
The Capricorn and UniQ have the EXACT same "operating radius"...33 ft.
(cord end to power nozzle end)
(Miele wont even say what the cord length is).
I don't like using extension cords with vacuums.
Tools are tiny, exactly the same size as the Capricorns.
Hose too short...same as Capricorns.
They made a few cosmetic changes but nothing relevant that would be an improvement over the Capricorn.
George CT
not everyone has a 2,000-6,000 square foot home. People with smaller houses or condos like miele and they work out very well.... they updated the model. I will agree they should have made a longer hose, larger tools and perhaps a little longer cord. But their main focus is on keeping the weight of the machine under control. the more you add those features, the heavier the machine becomes.
On the other hand the miele upright has a longer cord than all of the canisters and most of the uprights out there... they are great for large American homes.
@georgect,
I hear where you are coming from but everyone's cleaning requirement is different. To some the short cord of Miele is a drawback, to others it is not a deciding factor. Hoses... well if you didn't get the capricorn or the uniq then the hose is actually longer on the other electronic hoses. I measure this for myself in the Miele showroom recently.
Weight is an issue for some... I have the Miele S8 Marin (cross shoped with Sebo D4, Aeurs, TriStar, Filter Queen, etc) and the weights are as follows:
S8 - Marin Canister (with empty new bag in it.. no hose attached) -- 11.8 lbs
S8 -- electric hose (no head attached) -- 2.6 lbs
Miele Electronic wand (SET 220) -- 1.8 lbs
Miele SBB-300 floor tool -- .6 lbs
Miele SEB236 power head -- 6.2 lbs
Put together for floor cleaning with SBB300 on scale -- 16.9 lbs
Put together for carpet cleaning with SEB236 on scale -- 22.6 lbs
Cord length (measured from bottom of prongs to entry into the cansister.) -- 21.3 ft
Miele S8 electronic hose measure with tape measure -- 7 ft.
Miele SET 220 electronic wand fully extended is -- 38.4 inches
cue003
which electronic hose is 7 feet? or model? It also amazing me how many people on here will bash a brand, just because it does not meet their cleaning requirements. If your home is so damn large and long cords or hoses are an issue, get a central vac!
@ GM1982
I don't own an extravagant house, just a Cape Cod style home.
Of course I'm going to bash what is supposed to be one of the best vacuums you can buy right now that can't do more or even the same as my Kenmore Progressive.
It should offer MORE than a Kenmore Progressive canister but it falls short by a lot.
In my finished attic, the Miele will not reach plugged in at one end of the room to the other side, while my Kenmore can. Hence a longer cord.
I can't reach up and dust the bathroom vent while the canister is on the floor, with the Kenmore I can. Hence a longer hose.
I brought all of these issue (and more) to Miele's attention but they obviously made the exact same canister with some more bells and whistles but with no real added features.
I can see where some may have an issue with wight of the machine (if you need to carry it) but I don't have that issue.
George CT
The miele has much better filtration and build quality than the Kenmore, if your not into using an extension cord, then I think the only canister with a very long cord is the Sebo D4. Perhaps, you should sell your Miele and Kenmore and get a Sebo D4? I agree with you that the hose could be longer and the cord, but that doesn't mean its not a good performer at removing dirt, its main function.
Just to put everyone in the picture - 21.6 ft equates to 6.4metres. The UK models that Miele sell have the following cord length:
S2/S2111: 5.5 metres.
S6/S6000: 6 metres.
S5 & S8: 6.5 metres.
Miele typically don't give cord lengths on their website. They have never had to, using the radius of a vacuum cleaner due to their bigger 1.8 metre length hoses AND their telescopic height adjustable tubing which is longer than a lot of rivals set at the highest height. However, SEBO usurp everything Miele produce in so far as able to supply the same cord length in their K series and 12 metres on their D series cylinder vacs. Hoses either measure 1.8 metres or 2.1 metres dependent on model. Bosch also fight their corner well with 9 or 12 metres of cable but its a pity most of their canister vacs aren't as well built as Miele or Sebo.
Much as I would love a central vac in my home, I much prefer having a canister vacuum that has the option of using a longer cord built in or only half as much - handy for use for cleaning out the car as well as areas in the home where a hose and just the floor head or tools is more convenient than run the risk of an upright falling over. Id sooner have a Miele canister with a much longer cord than the alternative - the extender SFS10 flex hose attachment that adds 1.5 metres to the 1.8 default length. The extender is a good idea but it is too heavy and not much use when it constantly wants to revert back into its holding.
I have
The Capicorn but i dont use it much . The 236 power nozzel cleans, but well its kinda hard to push sometimes . I hate the short cord and hose. And the S7's are too hard to push. I went back to my Kirby G6.
I just measured again...
TIP to TIP is 7 feet. Sorry for any confusion or alarm.
From end of handle (were the extendable wand attaches to plug in section to the vacuum is 80 inches or 6 feet 8 inches. This measurement includes the handle and the connector piece at the vacuum. This is NOT just the braided piece. I layed this hose out next to the Miele Uniq hose and the Capricorn hose and it IS than those hoses that have the full vacuum control on the handle. Those units that have full vacuum control on the handle will not turn on or operate if the hose is not connected. That in my opinion limits the flexibility of the vacuum. With my Miele I got a custom 6-24 foot hose that I can use for above the ground cleaning and also for cleaning my bare floors with wand attachment.
Forget the Miele, kenmore, and sebo d4, if you want long cord length, buy a commercial vacuum or get a kirby (if you don't want to pay $2000 for it, get a used kirby) and replace the 25 ft cord with a genuine kirby 50ft power cord.
Yes NYCWriter...It's a deal breaker
Maybe I'm spoiled by all my past canisters having a cord that was ample enough to let me plug it in at one end of the room and have the length to reach the other side.
The way my finished attic is designed, the only easily accessible outlets are located at each end of the room. Furniture covers all the other outlets that run the length of the room. So it's just easier to use the exposed outlets at either end.
I don't mean to sound like I'm whining but a longer cord makes my vacuuming a much better experience and make my life just a little easier and I don't think it's that much to ask of a vacuum manufacturer.
We always had an extension cord hooked up to our old Eureka upright (Golden Cordaway Rugulator 2083). It gave Mom an extra 6 feet that actually allowed her to plug in only once to do our entire main floor of our small bungalow. Though it bugged me to have it destroy the aesthetics of Old Goldie when stored in the closet, it indeed helped Mom do her daily run through the house. She just hung the extra length of extension cord over the handle near the box top of the bag.
Would be interesting to know what were the lengths of the cord stored in 1960's cord reels.
GeorgeCT
We have been over this many times....the only canister that makes the longest cord (presently) is the Sebo D4. Outside of that vacuum brand, I am not aware of any that I know of that has a standard long cord, unless you go to uprights. They're just not making them that way today
Good Point...
George...you hit the nail on the head.
If Sebo can do it with a 40 ft cord (I don't know of any canisters that can match that length) and Riccar has a 28 ft cord (almost 30)...
Then it's totally feasible that other manufactures can do the same.
The short cord length is just a cost cuter to the manufacturer but it's a huge selling point to me and I would pay more for longer cord/hose length and larger tools.
I'm sure there are lots of others that would pay more for those features also.
It's not much to ask for.
The sebo has the longest cord. Then the common breakdown stops seem to be 28ft, 26/25ft, 22/21ft.
If you must have a long cord then sebo D4 is your only canister choice. Whether Or not you like that vac is another story. If you can live with shorter based on your room design/layout then Aerus, Riccar/Simplicity fall into the next category. A little shorter than that will be your Kenmores etc. Miele on the lower end at 21.5ft.
Since the Miele cord is too short then scratch it off your list and move to something else. For me I have plenty of outlets and have no issue moving my plug 1 time on each floor of my home when cleaning.
The D4 is a nice machine. I just preferred the miele S8 instead and the "short" cord didn't bother me. If I want a longer cord I will simply add an appropriately rated extension cord for the task. Some are against extension cords calling them unsafe etc. I think that is due to the fact that most people do t know how to choose the right extension cord for the length of run and the power draw. Not all cords are created equal. You can even get locking cords so the vacuum cord doesn't pull away from the extension cord.
http://gizmodo.com/5903218/how-to-choose-the-right-extension-cord-for-anything
Extension Cords
Eureka used to make a 10 ft extension cord designed for the upright cleaners. I used it on all of my 2000 Series uprights. Not sure if they still make them or not. Now days it is important to get an extension cord that can carry the number of amps your vacuum has. I had one for my Miele that I bought off of Ebay.
PR-21
The cord length is also part of the design priority for some manufactors. Every design has a trade off for someone whether it be the designer, builder, or customer. Can't please everyone. If you could there would only be one vacuum company. No need for others. :)
Silly Extention Cords...
Hummmm...if people are buying extension cords for their vacuums (hint, hint), then manufactures should pick up on the que (like Sebo, Riccar) and just make the cords longer.
You don't have to extend the cord all the way but it's nice if was there to use.
@georgect, your point has some validity to it but not everyone needs a longer cord. Hence the reason the Riccar isn't as long as sebo etc. Anyways, which vacuum did you end up purchasing to augment or replace your Miele?
What do y'all think about the miele autoeco? Does anyone have hands on experiences & opinions? Also the sebo d4 is an excellent machine with a longer cord. I have used the 2013 model and it has excellent filtration as well as suction. It performs on par with the miele canisters. SO, if cord length is important, give it a 30 day trial. The Aerus platinum is my favorite canister, with a respectable cord length, although not as long as sebo.
Some of our friends in Europe have mentioned a potential danger to running vacs with only part of the cord pulled out of the cord reel. Though I think this may be a quirk of 240volt vacuums with high wattages approaching 2000 watts, this may be the reason why European vac makers limit the length of cord stored on a cord reel. I am not an electrician, but I wonder if electrical safety and fire hazard factors put limits on the length of cord wound up on a cord reel. I know Sebo is German, and so I wonder if they have some sort of extravagant electrical protection system on the D4's cord reel.
On the other hand, there really is no excuse not to offer an 8 foot hose with all deluxe canisters. The standard height of a room in North America is 8 feet and so an 8 foot hose allows the user to dust the tops of wall units, and upper kitchen cabinets, and the tops of draperies, without having to carry the canister in one hand, or prop it on its backside. This should be the standard length for all suction-only canisters, at the very least.
