cheesewonton
Ideally I would move the anemometer probe around the circumference of the hose opening to see what the velocity reading is and take a reading at the center and average these but the length of the wire in the probe is nearly the diameter of many typical vacuum hoses so the best one can do is take a reading from the center. But I can see where I might get a high velocity reading from a given vacuum where someone using a vane anemometer 2 1/2 inches diameter with a hood would get an artificially low velocity reading. With hose openings as small as 28 mm I don't have a good work around unless there is an anemometer with a smaller sensor.
Japan has a method of rating vacuum performance they call Suction Work Rate that involves measuring total volume of air moved over a period of time. They don't use an instantaneous measurement of air velocity or airflow but instead measure volume in cubic meters over a period of time and this is accomplished at the end of the hose. They multiply this by, as best I can tell from the translation, a measurement of sealed suction at the hose end in Pascals and then by a factor to arrive at a value they express in watts. Some of the best Japanese bagged canister vacuums have pretty spectacular Suction Work Rate ratings.
